6500 watt Generac generator for $150??
by chainblu
3 minutes 47 seconds ago
Tier III fuel is on the way
by ZZman
5 minutes 28 seconds ago
ACDelco Dexos 0W20 UOA
by DanMiller
Today at 10:44 AM
Mopar window regulator (some assy. rqd.)
by dlundblad
Today at 10:27 AM
5.3L Silverado Water Pump Torque Specs
by Gito
Today at 10:25 AM
Rhino Ramps at Canadian Tire 50% off
by Snagglefoot
Today at 10:18 AM
What to do when your Glock jams
by bigj_16
Today at 10:13 AM
Pennzoil Platinum 5w30 vs 10w30
by Snagglefoot
Today at 09:09 AM
LM MoS2. Honest, if not appropriately tested?
by wemay
Today at 09:03 AM
Brisket flat on charcoal
by 04SE
Today at 08:45 AM
Weird Oil level question
by audia6
Today at 08:27 AM
DNA test and opening a can of worms
by WhyMe
Today at 08:11 AM
Ghetto testing a wheel speed sensor
by Nayov
Today at 06:23 AM
dash cam
by DAC2018
Today at 05:08 AM
WoO driver Jason Johnson injured
by bdcardinal
Today at 01:08 AM
Plastic burning smell when WOT
by Jaha24k
Today at 12:57 AM
Duckham's 15w50 Oil 12 one liter bottles
by Lolvoguy
Today at 12:00 AM
Ruger LCP .380
by PW01
Yesterday at 11:24 PM
Launching boat with stick shift
by troutfisher
Yesterday at 11:22 PM
Free oil
by Spitter
Yesterday at 10:53 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
79 registered (AP9, 93cruiser, AdmdeVilleneuve, andyd, AnthemBassMan, 8 invisible), 1483 Guests and 54 Spiders online.
65303 Members
67 Forums
285904 Topics
#4539442 - 10/10/17 06:32 PM DIY Wheel Alignment Question
Rock_Hudstone Offline
Loc: New Jersey
I replaced the struts and R inner tie rod on my Dodge Grand Caravan. I was able to get the driver side aligned pretty close to specs, However, the right side is visibly toed out and the steering wheel is off center at the one o'clock position, When I corrected that toe out condition the wheel became ever further off center.
Does there need to be a compensating adjustment on the left side toe to center the steering wheel and get things drivable until I can get in for an alignment? If so, wouldn't that throw left side toe off as well?
#4539447 - 10/10/17 06:35 PM Re: DIY Wheel Alignment Question [Re: Rock_Hudstone]
LotI Offline
Loc: America's Dairyland
If the wheels are pointed close to the intended direction, it will get you to an alignment shop. Steering wheel straightness doesn’t matter
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
#4539454 - 10/10/17 06:45 PM Re: DIY Wheel Alignment Question [Re: LotI]
Loc: New Jersey
Right side is toed way out and a little unstable on curves as well. I won't be able to get in for alignment until sometime next week and don't want to chew up the new tires.
#4539523 - 10/10/17 07:56 PM Re: DIY Wheel Alignment Question [Re: Rock_Hudstone]
eljefino Online   content
Loc: ME
Why did you do what you did to the driver's side?
Do your struts have oblong holes which can effect camber?
Do this:
#4539527 - 10/10/17 08:01 PM Re: DIY Wheel Alignment Question [Re: Rock_Hudstone]
George7941 Offline
Loc: Toronto, Canada
Well, pull the right wheel in close to where it needs to be with the adjustment at the tierod.
I changed a inner tierod end some weeks back and very carefully set the toe to specs using string. I am satisfied with the end result and did not bother taking the truck in to an alignment shop.
2006 GMC Sierra 4.3l, NV3500,G80 , Mobil 1 5W30, Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
#4539607 - 10/10/17 09:03 PM Re: DIY Wheel Alignment Question [Re: Rock_Hudstone]
WobblyElvis Offline
Loc: Toronto Canada
Park the vehicle with parking brake set and the trans in neutral. This will relieve any load from the front wheels. Steering wheel should be straight. Get down on your knees and look across the outer surface of the front tires toward the rear tires. Your should see a little of the rear tires along both sides, perhaps an inch of tire showing. Adjust the tie rods so this is so on both sides and you are done.
You need to look up the track for front and rear axles to do a more accurate job of toe in/out adjustment. Set both left and right to look similar with the steering wheel straight ahead and you shouldn't have any crooked wheel while driving down the road.
#4539653 - 10/10/17 09:52 PM Re: DIY Wheel Alignment Question [Re: eljefino]
Loc: New Jersey
Yes, I installed camber adjustment bolts last time I brought it to Firestone for alignment.
Not happy with their work, the tires developed inside shoulder wear, which by the time it becomes noticeable the alignment is out of warranty and they say you must have hit a pot hole (on both sides of course). Althought it did track and ride well but wore out a set of 70,000 mile tires in 50,000 miles.
Thats why I'm not a big hurry to pay good money and time for sloppy alignments that lead to premature tire wear.
#4539743 - 10/11/17 12:29 AM Re: DIY Wheel Alignment Question [Re: Rock_Hudstone]
2strokeNorthstar Offline
Loc: PR CA, USA
Firestone is like a DIY alignment. It may be close maybe not. I got their lifetime alignment and it is consistently bad. The wheel isn't straight or it pulls or tracks..... Had it done at an alignment shop and didn't do any of that. I don't have any idea what they are doing at Firestone. They don't either I guess.
#4539783 - 10/11/17 04:56 AM Re: DIY Wheel Alignment Question [Re: WobblyElvis]
George7941 Offline
I looked in the FSM for track widths for my truck and did not find it anywhere. Inspecting it visually the front and rear widths seem to be the same for my truck.
1987 BMW R80 - sold
2015 Honda CBR300R
#4539790 - 10/11/17 05:29 AM Re: DIY Wheel Alignment Question [Re: Rock_Hudstone]
WobblyElvis Offline
Loc: Toronto Canada
Specs here - https://www.edmunds.com/gmc/sierra-1500/2006/features-specs/
Assuming your truck is rear wheel drive only, and tires front and rear are the same. You should have a little toe in and specs say the rear track is an inch wider than the front. An educated guess tells me as you look along the outside edge of the front tires toward the rear tires, all the edges should line up. In other words, as you look across the outer surface of the front tires toward the back of the vehicle, the line you are looking down should just intersect the outside edge of the rear tires. Truck should be in neutral, level ground, rear park brake set, steering wheel centred.
This will put you in the ball park.
#4539841 - 10/11/17 07:13 AM Re: DIY Wheel Alignment Question [Re: Rock_Hudstone]
Traction Offline
Loc: iowa
Sounds like you turned the wrong tie rod is all. Just turn both tie rods an equal amount to center the steering wheel is all you need to do, making one shorter, and the other longer. Assuming the toe-in is set. Of course every time I've done it, I usually turn them the wrong direction on the first attempt.
Edited by Traction (10/11/17 07:17 AM)
Tire Industry Association Certified Tire Service Instructor since 2009
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
12 Camry
81 Camaro
55 Chevy C4
#4540235 - 10/11/17 01:31 PM Re: DIY Wheel Alignment Question [Re: WobblyElvis]
George7941 Offline
Thanks for the Edmunds link. It may or may not apply to my truck since mine is a reg cab rwd and the three trucks listed by Edmunds are all crew cabs. When I aligned the front end using string I was operating under the assumption that the front and rear tracks were the same and I did get a couple of inexplicable readings. I need to take another look at my truck.
1987 BMW R80 - sold
2015 Honda CBR300R
#4540491 - 10/11/17 06:26 PM Re: DIY Wheel Alignment Question [Re: Traction]
Loc: New Jersey
Okay I'll try that.
#4540503 - 10/11/17 06:36 PM Re: DIY Wheel Alignment Question [Re: 2strokeNorthstar]
Loc: New Jersey
I think they don't have any alignment specialists, at least at the Firestone I've used. From what I could see whatever tech was working on your vehicle was the also the guy that did the alignment.
Not good, as these guys have a bad habit of using impact wrenches to torque wheel nuts. I couldn't loosen most of the nuts on the front wheels with my own impact wrench at full power, had to use a breaker bar.
