Inside the Fuel Tank / EVAP system
by StevieC. 09/22/18 10:31 PM
Toyota Pink + RMI-25 10 years
by burla. 09/22/18 10:27 PM
Cartridge filter?
by Camprunner. 09/22/18 10:23 PM
Should have changed it?
by parshisa. 09/22/18 10:14 PM
Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
Redline D6 ATF substituting for Toyota WS
by Patrick0525. 09/22/18 05:29 PM
XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
transmission fluid and filter exchange
by Dennisistheman. 09/22/18 04:53 PM
Why people should change oil+filter!
by 53' Stude. 09/22/18 04:50 PM
Household lubricants (general purpose) differences
by 92saturnsl2. 09/22/18 04:35 PM
HondaTech250, SandCruzer, sbgti96, cosmoblau, Sarrge
66044 Registered Users
61 registered members (2015Corolla, 1.8Tango, 2010Civic, 4WD, 53' Stude, 6 invisible), 1,041 guests, and 33 spiders.
Topics290,864
Posts4,851,540
Members66,044
Most Online3,590
Jan 24th, 2017
good small gas cans..which? #4539112
10/10/17 01:20 PM
10/10/17 01:20 PM
indianapolis in
bmwjohn Offline OP
bmwjohn  Offline OP
indianapolis in
HI:
I have 2 DD, old 1994 Dakota and 1992 240. Neither has working gas gauge, one lacks odometer as well. In an abundance of caution, I think it might be wise to get 2x 2.5??? gal gas cans. I might pay a little more for semi nice ones, with the fond hope that they won't disappear like good jumper cables do. Any thoughts or suggestions? Thanks!
Re: good small gas cans..which? [Re: bmwjohn] #4539120
10/10/17 01:30 PM
10/10/17 01:30 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
You are going to REALLY love these:
Re: good small gas cans..which? [Re: bmwjohn] #4539124
10/10/17 01:32 PM
10/10/17 01:32 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Yes one more:
Buy or make a small lockable truck storage box.
Re: good small gas cans..which? [Re: bmwjohn] #4539160
10/10/17 02:08 PM
10/10/17 02:08 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Get some proper metal ones. You can get them down to a quart.
For plastic cans I go to Canada so I can get cans without those horrible spouts.
Re: good small gas cans..which? [Re: bmwjohn] #4539167
10/10/17 02:16 PM
10/10/17 02:16 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
The one Linctex is showing you is pretty good; just don't expose them to temperature swings.
Re: good small gas cans..which? [Re: bmwjohn] #4539174
10/10/17 02:24 PM
10/10/17 02:24 PM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
Your trip meter work? I always reset that for a fill up anyways and in my normal driving the trip meter is very consistent for knowing when to fill up. Also maybe look into something like a scanguage for OBD1? A scangauge can replace all functions of a dash board with accurate numbers and read codes so its worth the money IMO.
I won't carry gas in a car everyday for "just in case", heck you could get an old GPS unit and track trip mileage with that.
07 Focus ZXW, 5spd manual, 210km M1 5W30
18 Outback 2.5 CVT 10km 0W20 "bulk subaru" whatever that is
Re: good small gas cans..which? [Re: bmwjohn] #4539202
10/10/17 02:50 PM
10/10/17 02:50 PM
The Motor City
Kestas Offline
Kestas  Offline
The Motor City
I use a discarded metal can of mineral spirits or something similar. I know that you should have a gas can seal air tight, but this typically hasn't been a problem for me unless we get really hot weather. Then I just burp the can once in a while.
Re: good small gas cans..which? [Re: bmwjohn] #4539272
10/10/17 03:49 PM
10/10/17 03:49 PM
Pittsburgh,PA U.S.A.
JimPghPA Offline
JimPghPA  Offline
Pep-Boys sells a long skinny gray plastic funnel that is ideal for adding gasoline into most vehicles. If I remember right is is $2.99 + tax.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: good small gas cans..which? [Re: bmwjohn] #4539297
10/10/17 04:02 PM
10/10/17 04:02 PM
ME
eljefino Offline
eljefino  Offline
ME
No OBD-I scan gauge is going to show fuel level; the computer doesn't care.
If you have a can in the trunk I'd go for a trunk-certified model... forget what they're called. Fumes will drive you nuts, might make you sick.
Re: good small gas cans..which? [Re: bmwjohn] #4539400
10/10/17 05:49 PM
10/10/17 05:49 PM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
Regular carry of gas should be in a metal can. Plastic is simply not durable enough for the job (even though many use them, potential problems still exist even if someone hasn't experienced them).
I like metal "Jerry" style (WWII German Military style); they handle very easily, are simple to secure-store (chain, for example) and are durable. New or surplus, your choice. Probably limited to IMP 5 Gal [US 6 Gal / 20~25 litres] but that's your goal with two smaller cans.
If you *really* need small cans due to some space / storage / handling limits, I personally would then look at aluminum fuel bottles designed for camping and gas stoves. A 1 litre size should be easy to find, perhaps 4 of them (slightly larger than 1 USG) would be good enough for you.
If they seem too expensive, buy one or two and keep adding at that same rate until you have the 4 or 8 litre capacity you need. They are legal (red anodized, typically) fuel containers, which solves some potential issues you might have with non-gas cans (legally, the filling station is supposed to prohibit you from filling it if it's not a "gas" can or the right colour).
Would fit upright and nicely in typical car carrying stuff from bags (with a bungee cord) to boxes.
I've carried JetB in one for literally 20 years on a daily basis, an MRI 1 litre one (use for emergency fire starter) and that includes in the passenger compartment of aircraft on a regular basis (DeHaviland Otter, mostly). Pilot is absolutely fine with it, and just so you know he's not cavalier about safety, he would not let me carry Bear Spray until I found a crash-proof container to hold it. "If that stuff gets out somehow, the plane crashes because I won't be able to fly it" or something like that. Note that Bear Spray is many times more concentrated than what the police etc can legally carry.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: good small gas cans..which? [Re: eljefino] #4539853
10/11/17 07:22 AM
10/11/17 07:22 AM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
No, but you can track your gas usage from full and once you calibrate it a couple times, it would be close enough, even in varied driving conditions.
Re: good small gas cans..which? [Re: eljefino] #4539938
10/11/17 08:57 AM
10/11/17 08:57 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
On both my cars I can read fuel level with the ODBII scanners use.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: good small gas cans..which? [Re: SHOZ] #4542449
10/13/17 06:02 PM
10/13/17 06:02 PM
Ottumwa, Iowa
jhellwig Offline
jhellwig  Offline
Ottumwa, Iowa
Yes but obd1 does not.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2014 Toyota Sienna
1983 Chevy K5 350
Re: good small gas cans..which? [Re: bmwjohn] #4558641
10/29/17 06:31 PM
10/29/17 06:31 PM
Lakeside CA
another Todd Offline
Lakeside CA
All the newer "no spill" types seem to be junk, take forever to pour, can damage plastic fuel tanks threads (lawnmowers etc.), and spill fuel constantly. They do however keep fuel fresh longer due to the lack of a vent.
2015 Ford F250 Diesel Crew Cab FX4
2017 Ford Escape 2.0
2002 GMC Yukon
2015 Hyundai Accent
2008 Yamaha Rhino 700 FI
Re: good small gas cans..which? [Re: bmwjohn] #4558642
10/29/17 06:31 PM
10/29/17 06:31 PM
Lakeside CA
Lakeside CA
All the newer "no spill" types seem to be junk, take forever to pour, can damage plastic fuel tanks threads (lawnmowers etc.), and spill fuel constantly. They do however keep fuel fresh longer due to the lack of a vent. Metal is your friend for fuel storage.
2002 GMC Yukon
2015 Hyundai Accent
