New Struts and Springs
by Mathew_Boss. 04/21/19 05:36 PM
Float chargers?
by buck91. 04/21/19 05:32 PM
Toyota factory pink mixed with zerex coolant
by Rohan. 04/21/19 04:48 PM
Schaeffer 204SAT and 205A
by Gebo. 04/21/19 04:32 PM
Oil for old Chevy TBI 350
by RonRonnster. 04/21/19 04:19 PM
2012 chevy equinox transmission fluid
by krdoss. 04/21/19 03:50 PM
How Often Change Fuel Filters?
by Gebo. 04/21/19 03:17 PM
New Hyundai Elantra tell me all I need to know
by DONWATERS. 04/21/19 02:28 PM
How much balance weight is too much
by Hitman70. 04/21/19 02:02 PM
bought steel cut oats by mistake
by andyd. 04/21/19 01:50 PM
Mobil1 Synthetic Lubricating Spray
by EvanR. 04/21/19 01:01 PM
List of cars you've owned
by SLO_Town. 04/21/19 12:30 PM
Email Notice
by borgward. 04/21/19 12:14 PM
Why would 10w burn more than 5w?
by D1dad. 04/21/19 11:57 AM
02 Silverado 5.3L, LT, Low Oil Pressure
by Gito. 04/21/19 11:54 AM
0 to 60 in 1.9 seconds...
by JeffKeryk. 04/21/19 11:16 AM
Luxury Car Owners Switching to Pickup Trucks
by SubLGT. 04/21/19 11:05 AM
Easiest Way to Gravity Bleed Brakes
by jims5600. 04/21/19 10:55 AM
Newcastle Brown Ale replacement?
by Reddy45. 04/21/19 10:31 AM
Texas72, RamblerReb, rchapin, js1956, krdoss
67865 Registered Users
119 registered members (alphadog, AdditiveOCD, 2015_PSD, 53' Stude, 2009Edge, 14 invisible), 1,927 guests, and 29 spiders.
Topics287,855
Posts4,935,626
Members67,865
Most Online2,967
Mar 10th, 2019
Dewalt Drill - New Brushes? #4539048
10/10/17 12:17 PM
10/10/17 12:17 PM
Scituate MA
coopns Offline OP
coopns  Offline OP
Scituate MA
19 v Dewalt Cordless Drill. 12 or more years old.
Recently feeling like it is stripped inside. When changing bits, I hold the 'circle thing' (real technical eh?) and engage it forward or back. Feels
like it is stripped and not engaging. Would that be bushings? Did a little google and that is all I could figure. I also couldn't screw in a longer screw,
just made the cranking sound. Turned but then gave out.
Worth trying to repair? Difficult?
Coop
Re: Dewalt Drill - New Brushes? [Re: coopns] #4539053
10/10/17 12:20 PM
10/10/17 12:20 PM
Oklahoma
CELICA_XX Offline
CELICA_XX  Offline
Oklahoma
Time for one of their new brush-less models !
15 Toyota Prius - M1 EP 0w20 SN+
06 Acura MDX - Valv MaxLife Syn 5w20 SN+
02 Toyota ECHO - Valv MaxLife Syn 5w30 SN+
97 Lexus LX450 - M1 EP HM 5w30 SN+
93 Lexus LS400 - Valv MaxLife Syn 5w30
Re: Dewalt Drill - New Brushes? [Re: coopns] #4539072
10/10/17 12:33 PM
10/10/17 12:33 PM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
Is there screw mode and drill mode? Mine has an adjustable slip clutch in screw mode which limits torque. Drill mode locks out the clutch and it won't slip. Check that first as usually these drills outlast the batteries unless you pour sand into them.
07 Focus ZXW, 5spd manual, 230km M1 5W30
18 Outback 2.5 CVT 22km 0W20
Re: Dewalt Drill - New Brushes? [Re: coopns] #4539099
10/10/17 01:00 PM
10/10/17 01:00 PM
Scituate MA
coopns Offline OP
coopns  Offline OP
Scituate MA
I have a 1 and 2 at the top of drill. Where could I find screw/drill mode?
Coop
Re: Dewalt Drill - New Brushes? [Re: coopns] #4539109
10/10/17 01:17 PM
10/10/17 01:17 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Re: Dewalt Drill - New Brushes? [Re: coopns] #4539163
10/10/17 02:11 PM
10/10/17 02:11 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
There should be a picture of a drill bit like Linctex is showing you. grin2
Re: Dewalt Drill - New Brushes? [Re: coopns] #4539170
10/10/17 02:18 PM
10/10/17 02:18 PM
Where the wind comes sweepin'
Reddy45 Online shocked
Reddy45  Online Shocked
That's probably the "gear". My Porter Cable has that and it just controls the max speed of the drill. You need to fiddle with the clutch adjustment like the others said.
Re: Dewalt Drill - New Brushes? [Re: coopns] #4539241
10/10/17 03:27 PM
10/10/17 03:27 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Some of these drills have a clutch. Is it releasing based upon the clutch setting? Is it operational?
Could be stripped gears; I suspect there is one nylon one in there designed to give up first. Open it up!!
Re: Dewalt Drill - New Brushes? [Re: coopns] #4539254
10/10/17 03:36 PM
10/10/17 03:36 PM
Cincinnati, USA
Dave9 Offline
Dave9  Offline
Cincinnati, USA
It is very unlikely there is a sacrificial nylon gear meant to give up first.
Drills are not terribly complex. I've no idea what you're trying to describe but you should be able to tear it down and inspect each component. Then again if it's running off now old NiCd packs you might benefit greatly from moving to a modern Li-Ion based drill, even if it isn't the shiniest, newest brushless model. Brushed vs -less makes a lot less difference than NiCd to Li-Ion.
Re: Dewalt Drill - New Brushes? [Re: Reddy45] #4539301
10/10/17 04:06 PM
10/10/17 04:06 PM
Oshawa, Ontario Canada
JC1 Online content
JC1  Online Content
+2 on the clutch setting. I have the dewalt 20v li-ion driver and hammer drill. I've framed a shed and my entire basement with that impact driver and its still going strong. The Date codes on the battery are from 2011 and they still hold a perfect charge.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Dewalt Drill - New Brushes? [Re: coopns] #4539424
10/10/17 06:13 PM
10/10/17 06:13 PM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
You can replace the chuck with one that has a clutch.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Dewalt Drill - New Brushes? [Re: Dave9] #4539618
10/10/17 09:15 PM
10/10/17 09:15 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Ok.
https://www.plasticsportal.net/wa/plasticsEU~es_ES/portal/show/common/plasticsportal_news/2010/10_374?doc_lang=en_GB
Im all fir engineering plastics, but I'd trust a metal drivetrain to last the duration over plastic parts.
Not saying this is what it is... just could be...
Re: Dewalt Drill - New Brushes? [Re: coopns] #4545188
10/16/17 01:57 PM
10/16/17 01:57 PM
Parts Unknown
UG_Passat Offline
UG_Passat  Offline
Parts Unknown
sounds like you need a new chuck for the drill.
Black & Decker uses powdered metal geartrain for DeWalt products. B&D branded ones are plastic. It all based on the type of customer that uses which brand of tools.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
