VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Zahndkile, duradick, Harold1031, Skendread, NGK
67590 Registered Users
51 registered members (billt460, 4WD, avi1777, antik, AurionX2, 97K15004WD, 6 invisible), 741 guests, and 55 spiders.
Topics286,270
Posts4,905,654
Members67,589
Most Online2,967
Mar 10th, 2019
EngineFlush.Reasons not to use the full bottle? #4539022
10/10/17 11:59 AM
10/10/17 11:59 AM
SouthernCaliforniaDesert,USA
PalmSpringsSCal Offline OP
Basic background
My 2001 mitsubiti montero sport recently developed a light ticking noise that sound alot like lifter noise Ive heard in engines with lifters. (BTW it has about 245K odo)It only does it on cold startup when the ambient temp is below 60 F then goes away after 2 min idle. If I place a 75 watt drop light on it a couple hrs before starting it doesnt tick at all.
THE ISSUE
The one part of the directions that makes me question dumping the full quart in as directed is under the cautionary NOTE on the bottle
NOTE: On engines with 75000 miles,remove,drain and clean out the oil pan,to minimize the risk of engine damage.
Really dirty engines full of gunk may require repeat treatment.
The montero requires more labor to R&R the oil pan than the typical pan I have seen and Im not willing to go that far without more hours of thinking about it. Im going to be fairly stubborn on that point until I consider this "Is there another likely way to do accomplish this ticking issue ?"
To minimize the risk of clogging the passages up further or even clogging up the oilpump screen,I think I may just try flushing with 1/4 of the quart bottle( that still might be too much as Im just flying by the seat of my pants on this one so far). My thoughts are that the mild start up ticking of my engine, as described at the beginning of this post,may not require the whole qt to quiet it down, so why increase the risk of additional problems Ive already mentioned.
Ill just repeat this flushing process every 3000+- miles with each oil change.How doeds that conservative approach sound? Really,I welcome any other insight .
If you must know the name of the product: Ive used one or more words in my post that may give you a clue.
Re: EngineFlush.Reasons not to use the full bottle? [Re: PalmSpringsSCal] #4539036
10/10/17 12:10 PM
10/10/17 12:10 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
I have taken apart a lot of sludger engines with my dad and we have always thrown in a flush product before doing the really hard work. The best we have found is the Amsoil Flush product. Pour it in a warm engine, idle for 10-15 minutes, drain oil and refill.
There are videos online showing clean oil going in with the flush product and disgusting black oil coming out with chunks 10-15 minutes later.
I would probably put in some cheap conventional oil with the flush into a warm engine with a new filter and idle for 10-15 minutes, then shutdown and change again. Just in case there is a lot of junk sitting in there waiting to come out. It will minimize clogging.
Just FWIW. Cheers2
'18 Dodge Grand Caravan GT - 25k KM - AMSOIL SS 0w20
Fear 20wt oils if you want your engine to last. smirk2
Re: EngineFlush.Reasons not to use the full bottle? [Re: PalmSpringsSCal] #4539037
10/10/17 12:11 PM
10/10/17 12:11 PM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
I would think a good full synthetic oil would be way less evasive to your engine than that flush you're using. Have you given any thought to a blend like Havoline that is supposed to get rid of things like sludge and vanish?
2004 Corolla 130017
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: EngineFlush.Reasons not to use the full bottle? [Re: PalmSpringsSCal] #4539058
10/10/17 12:26 PM
10/10/17 12:26 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
The Car Talk have mentioned using I think 50% oil and 50% diesel fuel as a flush. They said it had worked for someone they knew. But it trashed the engines they tried it in.
2015 Ford F250 w/Powerstroke
Re: EngineFlush.Reasons not to use the full bottle? [Re: PalmSpringsSCal] #4539066
10/10/17 12:31 PM
10/10/17 12:31 PM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
Auto-RX. Follow instructions.
Re: EngineFlush.Reasons not to use the full bottle? [Re: PalmSpringsSCal] #4539085
10/10/17 12:43 PM
10/10/17 12:43 PM
Phoenix, Arizona - USA
SirTanon Offline
SirTanon  Offline
For me, doing an oil change with a quality high-detergent oil, and replacing a quart of oil with MMO, then driving for a couple thousand miles with that mix in, has worked very well.
When I had my '03 Sable LS, I ran a 5000 mile OCI like this and it came out DARK at the end. Definitely did some cleaning. To make sure that the oil wasn't too thin from the MMO, I upped the oil weight a tad to offset it - 10w40 plus the MMO, instead of the normal 5w30.
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 271,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 62,000mi
Re: EngineFlush.Reasons not to use the full bottle? [Re: JohnnyJohnson] #4539089
10/10/17 12:50 PM
10/10/17 12:50 PM
Ya know I havent, Ill look into it.
Ive heard of putting a quart of diesel in the oil,you or anyone else done that?
Re: EngineFlush.Reasons not to use the full bottle? [Re: PalmSpringsSCal] #4539094
10/10/17 12:54 PM
10/10/17 12:54 PM
Seattle
Superflop Offline
Superflop  Offline
Seattle
I have used the liquimoly engine flush before, it did a good job and i would use it again if necessary. Ive heard and seen alot of dumb stuff done to engines and never once have i learned of an oil passage becoming clogged due to a flush. Pick up screens and improper oil and oci is a totally different subject however.
With the LM engine flush pour it in idle for 10 minutes and then drain.
When i did it i wanted to see what was coming out so i dropped the oil and filter out super cheap stuff back in/on and then did the flush. I took my drain pan to the solvent tank and cometely cleaned it then wiped it dry. The oil that came out and was only 10 minutes d was blackish/brownish and there was a lot of heavier substances that sat and clung to the bottom of the pan. Not surprisingly the oil stayed cleaner looking for much longer. This engine had ~190,000 miles on it at the time of flush and is still going strong
Re: EngineFlush.Reasons not to use the full bottle? [Re: Donald] #4539096
10/10/17 12:57 PM
10/10/17 12:57 PM
That a good one. You just never know..really do ya? And here I am on the internet getting opinions. You know haw that is. Its a calculated risk like most everything else,oh and of course theres your own judgement when it comes to discriminating all claims and advice that could end in a fatal mistake.
Re: EngineFlush.Reasons not to use the full bottle? [Re: Donald] #4539098
10/10/17 12:59 PM
10/10/17 12:59 PM
yeah,Off hand even I would worry about the loss of lubricity of a 50% dilution.
Re: EngineFlush.Reasons not to use the full bottle? [Re: SirTanon] #4539101
10/10/17 01:03 PM
10/10/17 01:03 PM
Interestin...I just read about using MMO on YT, The name in itself is suspicious enough,but good to hear you appear to have not suffered any known dmg. Im not eliminating it from possible use yet
Re: EngineFlush.Reasons not to use the full bottle? [Re: Superflop] #4539103
10/10/17 01:06 PM
10/10/17 01:06 PM
I assume the M is moly?
Re: EngineFlush.Reasons not to use the full bottle? [Re: PalmSpringsSCal] #4539115
10/10/17 01:21 PM
10/10/17 01:21 PM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
Originally Posted By: PalmSpringsSCal
My 2001 mitsubiti montero sport recently developed a light ticking ....(BTW it has about 245K odo)
Can you take a picture through the oil fill hole and post it here?
Re: EngineFlush.Reasons not to use the full bottle? [Re: PalmSpringsSCal] #4539117
10/10/17 01:23 PM
10/10/17 01:23 PM
Waco, TX
Waco, TX
It is EXACTLY what you buy when you buy the silver quart cans of Gunk Engine Flush.
Re: EngineFlush.Reasons not to use the full bottle? [Re: PalmSpringsSCal] #4539130
10/10/17 01:39 PM
10/10/17 01:39 PM
Indiana
Phishin Offline
Phishin  Offline
Indiana
My 1990 truck was sludged bad when I got it. I did 2000 mile oil changes and right before changing the oil, I'd pour in 1 quart of kerosene and and let the truck run for 10-20 minutes. Then change the oil. I did this for my first three oil changes. But it wasn't doing the job.
Here's what I did:
A.) Drained oil and replaced with fresh filter.
B.) DISCONNECT THE IGNITION SYSTEM: For me, I just removed the connection between the coil and the distributor cap
C.) In this 6 quart sump, I poured in 6 quarts of Kerosene and 2 quarts of Mineral Spirits
D.) I cranked over the engine for approximately seconds to get the solvents to begin to pump through the engine. I let the starter rest for 10 seconds, and cranked it over again for another 10 seconds. And then I did it one more time.
E.) I repeated this 2-3 times a day for 3 days.
F.) I drained out the nasty cruddy solvent mess, installed a new filter and fresh oil. I ran it for 200-300 miles, and then changed the oil and filter again.
This should have really cleaned up the oil pan, the oil pick-up screen, and some of the engine's internals.
This really seemed to make a big improvement.
2018 Chevy Silverado 3500HD 6.0L Gas: RLI 10w30
2010 Accord-LX K24: MaxLife 5w30 + Torco MPZ
2014 CR-V LX K24: M1 0w30
