I was going to try the Lucas Hot Rod & Classic Car Motor Oil SAE 10W-40 but the zddp of 2100 is a bit high for me. So I did a 50/50 mix of M1 0/40 fs and M1 V-Twin 20/50. According to two mixing calculators this should be very close to M1 10/40 HM 16cSt 107cSt(16.2cSt 109cSt for the mix). Both oils have close to the same add pack, 0/40 MO-71 B-280 CA-3255 MG-15 Z-1005 P-978 And V-Twin 20/50 MO-82 B-233 CA-2472 MG-24 Z-1745 P-1600. So a 50/50 mix should give me more anti-wear add pack and still keep the good detergent package plus keep the oil close to a 10/40.
I'm not going to put SN oil in my S2000, I've been running M1 10/40 HM SM(with a can of MoS2) for the last 100k miles because it had more ZDDP and I've seen first hand and read about way to many engines(F20C and F22C) eating bearings and/or scored cylinders. This mix will give me around 1400-Z and 1300-P which is close to what the old M1 10/40 SM had. I will get a uoa on this mix at 6000 miles(usually run 7500 miles) and post back.
ROD
ROD
