Pennzoil Platinum 5w30 vs 10w30
by Snagglefoot
06/24/18 09:09 AM
LM MoS2. Honest, if not appropriately tested?
by wemay
06/24/18 09:03 AM
Brisket flat on charcoal
by 04SE
06/24/18 08:45 AM
Weird Oil level question
by audia6
06/24/18 08:27 AM
DNA test and opening a can of worms
by WhyMe
06/24/18 08:11 AM
Ghetto testing a wheel speed sensor
by Nayov
06/24/18 06:23 AM
dash cam
by DAC2018
06/24/18 05:08 AM
WoO driver Jason Johnson injured
by bdcardinal
06/24/18 01:08 AM
Plastic burning smell when WOT
by Jaha24k
06/24/18 12:57 AM
Duckham's 15w50 Oil 12 one liter bottles
by Lolvoguy
06/24/18 12:00 AM
Ruger LCP .380
by PW01
06/23/18 11:24 PM
Launching boat with stick shift
by troutfisher
06/23/18 11:22 PM
Free oil
by Spitter
06/23/18 10:53 PM
Porsche Panamera buying advice
by CharlieBauer
06/23/18 10:04 PM
RC cars
by red7404
06/23/18 09:36 PM
Any Good 4K Movies ?
by Warstud
06/23/18 09:06 PM
Gray on Oil Dipstick?
by chinee
06/23/18 08:41 PM
Clear plastic scratch remover?
by Quattro Pete
06/23/18 08:15 PM
Parking wars show.
by Chris142
06/23/18 08:15 PM
set for years
by 93cruiser
06/23/18 08:07 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
85 registered (04SE, 87sammy, 2015_PSD, 2004tdigls, 14ecocruze, 8 invisible), 1324 Guests and 46 Spiders online.
65303 Members
67 Forums
285897 Topics
Page 1 of 2 1 2 >
#4538523 - 10/09/17 09:13 PM what's a good way to keep a garage or shed warm?
motor_oil_madman Offline
Loc: Houston, Texas
Last winter we had like 5 days in a row where it stayed at like 25 degrees believe it or not and it was enough to freeze my washer fluid in my truck. I'm usually good about those kinds of things, but I guess I've been lacking so with winter not far away I figured I'd ask this. 25 degrees is about as cold as it will get, maybe 20 degrees. My question is if you have a storage shed with electricity what would be a good way to keep it just warm enough to prevent things from freezing? I know normally the inside stays warmer, from the sun beating down etc, but I'm still curious. I think a space heater is the best bet, but I hear so many stories about them catching things on fire. Plus they seem so cheaply made that I'm not really comfortable using one especially unattended.
Is leaving a few lights on enough to keep things a few degrees warmer?
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
#4538526 - 10/09/17 09:19 PM Re: what's a good way to keep a garage or shed warm? [Re: motor_oil_madman]
StevieC Offline
Loc: Ontario, Canada
Get a utility heater that is thermostatically controlled and that has a tip / overheat sensor (Most do now). Or get a radiant barn type heater that mounts to the ceiling and radiates heat downward (Out of the way of flammables).
TSC is a good store to look if you have something like that near you.
'15 Dodge Journey - 90,000 KM's - SSO 5w20
'06 Hyundai Santa Fe - 535,000km - SSO 0w30 (R.I.P)
#4538527 - 10/09/17 09:19 PM Re: what's a good way to keep a garage or shed warm? [Re: motor_oil_madman]
JHZR2 Offline
Loc: New Jersey
How about getting the right fluid mix for the temperatures?
Assuming the structure is not insulated, any heating is going to be a major waste!
#4538534 - 10/09/17 09:32 PM Re: what's a good way to keep a garage or shed warm? [Re: JHZR2]
dave123 Offline
Loc: wi
+1 or just dump in a bottle of heet per gallon washer fluid.
#4538535 - 10/09/17 09:34 PM Re: what's a good way to keep a garage or shed warm? [Re: motor_oil_madman]
Loc: Houston, Texas
well I'm not talking about washer fluid, sorry to throw you guys off. I'm just talking about things in general. Like my pressure washer pump etc. I'd just rather keep things from freezing in the first place.
#4538537 - 10/09/17 09:35 PM Re: what's a good way to keep a garage or shed warm? [Re: motor_oil_madman]
4WD Offline
Loc: Texas
A 250w heat lamp shining direct on some thick metal used to do this on a plow disk as a chill breaker for short periods in my shop (before putting a gas heater in) I have also used electric radiator heat at my camp so when the fire burns out while sleeping
Edited by 4WD (10/09/17 09:35 PM)
#4538544 - 10/09/17 09:50 PM Re: what's a good way to keep a garage or shed warm? [Re: motor_oil_madman]
JohnnyJohnson Online   content
Loc: Wet side WA
Unless its insulated as two have already asked about its going to be costly. But if its insulated keeping it above freezing should be very easy and inexpensive. One of those oil radiator type heaters use to keep my insulated 8' x 24' shop right at 60 degrees for about $30 a month all winter. Running it on the 600 watt setting. It would turn itself off and on.
Edited by JohnnyJohnson (10/09/17 09:54 PM)
2004 Toyota Corolla 121790
Out: QSUD 5W-30 Purolator One 5030
In: Valvoline ML 5w-30 TG4967 117530 2-8-18
2006 Duramax 74047
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73752 4-22-18
#4538546 - 10/09/17 09:53 PM Re: what's a good way to keep a garage or shed warm? [Re: motor_oil_madman]
dave123 Offline
Loc: wi
water stored in a pump is a bad idea anytime of the year. Should be using RV or EG antifreeze for any length of storage.
#4538550 - 10/09/17 09:55 PM Re: what's a good way to keep a garage or shed warm? [Re: JHZR2]
Kuato Offline
Loc: Colorado
+1 for both! If uninsulated a heater will do nothing.
If cold weather washer fluid is not available in your area you can always put a mixture of 70% isopropyl alcohol in with the mix.
Thick vs Thin test: 15k / 43k miles complete
#4538554 - 10/09/17 09:59 PM Re: what's a good way to keep a garage or shed warm? [Re: motor_oil_madman]
ArcticDriver Offline
Loc: USA
As has been said above, uninsulated spaces are costly to heat.
Do you have sunny days when it is 25* F ?
If so then the solar gain likely heats the space during the day and you just need to break the chill at night.
A block heater for your vehicle?
A torpedo heater with kerosene for a few hours before you go to bed?
The heat is going to rise immediately to the rafters unless you have the ceiling rocked out.
Multiple Diesel and Gasoline vehicles
#4538560 - 10/09/17 10:10 PM Re: what's a good way to keep a garage or shed warm? [Re: motor_oil_madman]
mattwithcats Offline
Loc: Virginia
I use a DeLonghi oil filled heater,
has a "*" thermostat setting, below "1",
which is antifreeze, about 40-45 degrees F...
I set it on 600 watts, there is also a 900 watt setting too. Both is 1500, but that may trip the breaker or overheat the wiring, used long term...
Keeps the outside storage unit warm, and my water heater and pipes from freezing.
I did insulate the pipes and walls...
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
#4538565 - 10/09/17 10:19 PM Re: what's a good way to keep a garage or shed warm? [Re: motor_oil_madman]
jhellwig Offline
Loc: Ottumwa, Iowa
Simply insulating your shed will help more than trying to heat it. You have to slow the loss of heat since you don't have many cold days. No need to heat a shed in Texas.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2008 Chevy Suburban 5.3
1983 Chevy K5 350
#4538600 - 10/09/17 11:24 PM Re: what's a good way to keep a garage or shed warm? [Re: motor_oil_madman]
blupupher Offline
Loc: Katy, Republic of Texas
I was going to tell you to move south, but you already are.
Exactly what type of building are you trying to heat?
As others have said, if not insulated (which it probably not is since it froze inside with our mild winter temps), just insulate it. There should be enough radiant heat after that to prevent freezing.
If you really want to warm it up (after insulation, otherwise it would be an impossible battle), get one of the oil heaters mentioned above, they work really well and have minimal fire hazard.
Look at some of these
Another option is a few 500w halogen flood lights, but the oil heater is more efficient.
1994 Honda VT1100C: Peak 15w-40/TG/2500 mile OCI
2002 Ford F150: GTX HM 5w-20/EcoGard Syn/1yr OCI
2012 Scion xB: QSUD 0w-20/CQ Blue/5k OCI
#4538640 - 10/10/17 12:36 AM Re: what's a good way to keep a garage or shed warm? [Re: motor_oil_madman]
Nick1994 Offline
Loc: Phoenix, AZ
Freezing things isn't going to hurt them, it isn't that cold. You can winterize pressure washers and put some antifreeze in the pump.
2015 Hyundai Sonata 2.4L 79k PU 5w30 & OEM
2000 Toyota Camry 2.2L 228k M1 AFE 0w30 & Wix
1996 Jeep Cherokee 4.0L 146k M1 HM 10w40 & Fram Ultra
#4538679 - 10/10/17 04:56 AM Re: what's a good way to keep a garage or shed warm? [Re: Nick1994]
krismoriah72 Offline
Loc: wv
Look up chicken coop heater on amazon.
Page 1 of 2 1 2 >
