So I have a 2000 Yamaha R1, based on this site, #5 is recommended one :
http://www.calsci.com/motorcycleinfo/FilterXRef.html#5
Just did an oil and filter change, with L14610(white can) installed. Was wondering if I should keep for first 1000 miles and then change oil and filter together? Or just keep the filter for 2000 miles.
Also, can I use HONDA OEM A02 filter, instead of Purolator? 15400-plm-a02(https://www.amazon.com/Genuine-Honda-Filter-15400-plm-a02-Washer/dp/B00GUJ3Y4O)
Which one would be a better choice and are filter specification(media, filtration and anti drain)are same?
Thanks for all the help.
