Service champ filter CUT OPEN
by 53' Stude. 09/25/18 05:05 PM
Pressure washer pump life just 23 hours?
by HawkeyeScott. 09/25/18 05:01 PM
STP S 10590 CUT OPEN
by 53' Stude. 09/25/18 05:00 PM
2003 BMW M5-Unknown oil 2500 mi
by Audios. 09/25/18 04:54 PM
FRAM ULTRA XG 3593A CUT OPEN
by 53' Stude. 09/25/18 04:51 PM
MG 201-7, 7,500 MILES CUT OPEN
by 53' Stude. 09/25/18 04:44 PM
MG 301-1, 10,800 miles CUT OPEN
by 53' Stude. 09/25/18 04:34 PM
Anyone regret their cordless electric OPE?
by dlundblad. 09/25/18 04:21 PM
Which Performance Filter?
by rooflessVW. 09/25/18 03:33 PM
Optimal Compression Ratio for 91 Octane Fuel
by NICAT. 09/25/18 02:01 PM
Anyone used Amsoil DZF 0w40 ?
by ofelas. 09/25/18 01:33 PM
No more Turo - What now?
by dogememe. 09/25/18 01:08 PM
Military small arms ammo
by Camprunner. 09/25/18 12:03 PM
Pennzoil must not be selling , OR ?
by Kjmack. 09/25/18 11:51 AM
New black car, light swirls and water spots
by Redright9. 09/25/18 11:37 AM
Rust Belt vs Sun Belt cars
by ZZman. 09/25/18 11:33 AM
Enginer rebuilder's view of GDI intake issues
by Brigadier. 09/25/18 11:09 AM
Oil for '84 Caddy w/HT-4100
by StillLearning. 09/25/18 10:41 AM
Pat_Roberts, Peppz, Jfa02, ibsfusion, Fearcat707
66070 Registered Users
109 registered members (Ablebody, 2010Civic, 2013ecof150, Aero540T, 53' Stude, 28oz, 9 invisible), 1,444 guests, and 42 spiders.
Topics291,006
Posts4,854,234
Members66,070
Most Online3,590
Jan 24th, 2017
New Mix for My S2000 #4538378
10/09/17 06:40 PM
10/09/17 06:40 PM
SACRAMENTO, CA
rrounds Online content OP
rrounds  Online Content OP
SACRAMENTO, CA
I was going to try the Lucas Hot Rod & Classic Car Motor Oil SAE 10W-40 but the zddp of 2100 is a bit high for me. So I did a 50/50 mix of M1 0/40 fs and M1 V-Twin 20/50. According to two mixing calculators this should be very close to M1 10/40 HM 16cSt 107cSt(16.2cSt 109cSt for the mix). Both oils have close to the same add pack, 0/40 MO-71 B-280 CA-3255 MG-15 Z-1005 P-978 And V-Twin 20/50 MO-82 B-233 CA-2472 MG-24 Z-1745 P-1600. So a 50/50 mix should give me more anti-wear add pack and still keep the good detergent package plus keep the oil close to a 10/40.
I'm not going to put SN oil in my S2000, I've been running M1 10/40 HM SM(with a can of MoS2) for the last 100k miles because it had more ZDDP and I've seen first hand and read about way to many engines(F20C and F22C) eating bearings and/or scored cylinders. This mix will give me around 1400-Z and 1300-P which is close to what the old M1 10/40 SM had. I will get a uoa on this mix at 6000 miles(usually run 7500 miles) and post back.
ROD
'06 S2000
'00 SSEi sold at 252k miles
'08 Ford F53 V10
'13 Jeep Sahara 2 door
Re: New Mix for My S2000 [Re: rrounds] #4538388
10/09/17 06:54 PM
10/09/17 06:54 PM
The Midwest
skyactiv Online content
skyactiv  Online Content
The Midwest
Why not just use what will work like something that meets the Porsche A40 spec such as Castrol 0W40, Pennzoil 0W40 or 5W40 or even Mobil1 0W40. Does the rare for the time 10W30 recommendation from Honda make it hard for you to accept a 0 or 5W whatever?
Me: 13' VW GTI 3 door 6 speed manual
Re: New Mix for My S2000 [Re: rrounds] #4538398
10/09/17 07:09 PM
10/09/17 07:09 PM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
Yeah that sounds like a lot of work.
A second that an A3/B4 oil would be perfect.
"Zed's dead baby, Zed's dead."
Re: New Mix for My S2000 [Re: skyactiv] #4538413
10/09/17 07:28 PM
10/09/17 07:28 PM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
I think he explained clearly why he was doing what he was doing. Did you not follow it?
As to why not 0w, the fact he doesn’t live in Alaska is reason alone. He wants “oil” and not a significant percentage of fragile polymers that degrade and don’t lubricate well.
Interesting approach worth noting for certain cars.
Re: New Mix for My S2000 [Re: rrounds] #4538467
10/09/17 08:13 PM
10/09/17 08:13 PM
Texas (south)
FermeLaPorte Offline
Texas (south)
As long as it's Mobil (American-owned), you don't have to worry 👌
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: New Mix for My S2000 [Re: rrounds] #4538475
10/09/17 08:23 PM
10/09/17 08:23 PM
Dallas,Tx USA
aquariuscsm Offline
aquariuscsm  Offline
Dallas,Tx USA
Aren't these roller cam engines? SN levels of zddp will be just fine. Grab a jug of your fave 10W30 (per Honda spec) and you'll be good to go.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 5W20
Re: New Mix for My S2000 [Re: Oro_O] #4538701
10/10/17 05:52 AM
10/10/17 05:52 AM
The Midwest
The Midwest
_
Re: New Mix for My S2000 [Re: skyactiv] #4538959
10/10/17 10:53 AM
10/10/17 10:53 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
That's kind of where I'm leaning.
Good thinking though Rod..... TOO MUCH ZDDP is actually a bad thing.
Re: New Mix for My S2000 [Re: rrounds] #4538960
10/10/17 10:53 AM
10/10/17 10:53 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
They are roller cam engines. However, they are also FRM (fiber reinforced metal) cylinder material. So the bores are not conventional cast iron or a variation of nikasil. Furthermore the very high RPM of these engines does put a heavy burden on the bearings. The use of very light oils in these engines will result in cylinder scoring and accelerated bearing wear. I use 15W-50 M1 in my Turbo S2000 with excellent results. Considering the hard use it's seen, I'm surprised it's held up this long on the original engine. Something I can't say for the differential and transmission.
407 RWHP at 19.5 pounds boost.
You might like the pic of my S2000 pinion gear! (prob not intended for 450 crankshaft HP)
Re: New Mix for My S2000 [Re: Cujet] #4538963
10/10/17 10:54 AM
10/10/17 10:54 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted By: Cujet
407 RWHP at 19.5 pounds boost. You might like the pic of my S2000 pinion gear! (prob not intended for 450 crankshaft HP)
YIKES!!!!
Re: New Mix for My S2000 [Re: Cujet] #4539409
10/10/17 06:01 PM
10/10/17 06:01 PM
SACRAMENTO, CA
SACRAMENTO, CA
Cujet,
I'd have that pinion mounted on my wall LOL
Plus you know its hard to find a shop that can rebuild one correctly and finding a good used one(AP2 '06) is starting to be a(rhymes with cap) shoot.
'06 S2000
'08 Ford F53 V10
Re: New Mix for My S2000 [Re: Cujet] #4539466
10/10/17 06:58 PM
10/10/17 06:58 PM
Douglas County, Colorado
bigj_16 Offline
bigj_16  Offline
That will buff right out! smile
Re: New Mix for My S2000 [Re: rrounds] #4539470
10/10/17 07:02 PM
10/10/17 07:02 PM
'Stralia
Shannow Online content
Shannow  Online Content
'Stralia
That's beautiful...
Re: New Mix for My S2000 [Re: rrounds] #4539595
10/10/17 08:55 PM
10/10/17 08:55 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
Originally Posted By: rrounds
Cujet,
Hahaha, I chucked it immediately. I installed a different ratio (3.63) , which is much nicer for the turbo's power. I did the overhaul myself, and used the proper reinforcement parts from a well known S2000 diff guy. The job came out well and has been working perfectly ever since.
Re: New Mix for My S2000 [Re: Shannow] #4539599
10/10/17 08:57 PM
10/10/17 08:57 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
Originally Posted By: Shannow
That's beautiful...
Yup! I wanted to add that the gear teeth were distorted enough that I could hear "problems" coming from the differential. When lightly on the throttle, a very noisy clickety-clickety sound was evident, and a weird whine when off the throttle at speed. I knew it was a minute from catastrophic failure and nursed it home.
