Rust-Oleum Driveway Sealer review
by SVTCobra. 09/22/18 01:24 PM
Flush OAT/IAT mixture
by OpenClose. 09/22/18 12:20 PM
And They Say Spelling is Not Important.
by PimTac. 09/22/18 12:06 PM
Toyota Genuine oil 10W30
by gordond. 09/22/18 09:27 AM
Good Dealers
by HowAboutThis. 09/22/18 09:12 AM
electric brakes rely on heat to work?
by motor_oil_madman. 09/22/18 09:09 AM
help please 7.25 briggs idle too fast
by edwardh1. 09/22/18 08:49 AM
Java update and Flash not working
by JLTD. 09/22/18 08:47 AM
Bought a Giulia
by RamFan. 09/22/18 08:38 AM
by gordond. 09/22/18 08:37 AM
Mobil 1 Extended Protection High Mileage Test
by njohnson. 09/22/18 07:57 AM
WPA 3 Wireless Security Coming
by StevieC. 09/22/18 01:16 AM
Robo Calls/Telemarketers
by Nick1994. 09/22/18 12:47 AM
What oil should be used!
by BigShug681. 09/22/18 12:28 AM
VW Electronic Parking Brake
by StevieC. 09/21/18 11:48 PM
Leak Sealing and Mould Treatments?
by Ducked. 09/21/18 11:44 PM
UPS / FedEx / USPS
by StevieC. 09/21/18 11:21 PM
Sarrge, Big_R, gordond, mrgreggn, JRMFt11
66040 Registered Users
67 registered members (A310, 2013ecof150, Anduril, 93cruiser, Ag76, 6 invisible), 1,896 guests, and 43 spiders.
Topics290,823
Posts4,851,054
Members66,040
Most Online3,590
Jan 24th, 2017
Oil Filter Question? #4538349
10/09/17 06:09 PM
10/09/17 06:09 PM
VA
maverickfhs Offline OP
VA
So I have a 2000 Yamaha R1, based on this site, #5 is recommended one :
http://www.calsci.com/motorcycleinfo/FilterXRef.html#5
Just did an oil and filter change, with L14610(white can) installed. Was wondering if I should keep for first 1000 miles and then change oil and filter together? Or just keep the filter for 2000 miles.
Also, can I use HONDA OEM A02 filter, instead of Purolator? 15400-plm-a02(https://www.amazon.com/Genuine-Honda-Filter-15400-plm-a02-Washer/dp/B00GUJ3Y4O)
Which one would be a better choice and are filter specification(media, filtration and anti drain)are same?
Thanks for all the help.
2006 Civic EX 202K/AT
2006 Acura TSX 180K/AT
Re: Oil Filter Question? [Re: maverickfhs] #4538355
10/09/17 06:18 PM
10/09/17 06:18 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
The Mobil and Purolator one in number 5 are both 99% plus filters at 20 microns.
2004 Corolla 124786
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74277
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 74705 4-22-18
Re: Oil Filter Question? [Re: JohnnyJohnson] #4538366
10/09/17 06:28 PM
10/09/17 06:28 PM
wv
krismoriah72 Offline
wv
Fram Ultra 7317 and Wix/NAPA 1356 are the 'best' filters imho for the money.
Re: Oil Filter Question? [Re: maverickfhs] #4538408
10/09/17 07:21 PM
10/09/17 07:21 PM
Maryland USA
rubberchicken Offline
Maryland USA
My Yamaha uses the same size filter. For long term, I would not use the Purolator white cans in this application. I would suggest ( in no particular order) instead using the Purolator Boss , Amsoil , Mobil 1 or factory spec Denso filters. I have opened up all of these and posted pics in the past, and found them to be better construction. The Purolator white can was fine for a low-end filter, but there are better filters out there. I have alternated between the Pure One filter and the Amsoil filter for a long time with good results. No need to toss out the Purolator can, just upgrade at next oil change.
Re: Oil Filter Question? [Re: rubberchicken] #4538425
10/09/17 07:33 PM
10/09/17 07:33 PM
VA
VA
Thanks, that's very helpful advice. Should I change L14610 at 1000 or 2000 mark? For normal street riding smile
Also, I have a Purolator Boss( Red one, I believe?) laying around too. It's same as L14610, if so, I can use it.
Any experience with Honda OEM A02 filter?
Re: Oil Filter Question? [Re: maverickfhs] #4538466
10/09/17 08:13 PM
10/09/17 08:13 PM
Ontario, Canada
StevieC Offline
StevieC  Offline
Ontario, Canada
Amsoil aren't the cheapest filter but they do flow a lot of oil and catch a lot of contaminants. The construction of them is very heavy duty inside as well. Just FWIW.
'18 Highlander - AMSOIL SS 0w20 / ATF / Severe Gear
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF (R.I.P)
Re: Oil Filter Question? [Re: maverickfhs] #4538538
10/09/17 09:39 PM
10/09/17 09:39 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Leave it on for 2000 miles, that's nothing for an oil filter. Unless you don't like the filter.
Re: Oil Filter Question? [Re: krismoriah72] #4538567
10/09/17 10:21 PM
10/09/17 10:21 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
if you have the room, the 3593A size is about the same length as the 7317, but is a larger diameter filter.
I bought a few of the TG3593A for my bike (PH6617A is the recomended Motorcycle filter, same size as a 6607, which is tiny) when they were on clearance at Walmart.
1994 Honda VT1100: Peak 15w-40/PSL/2500 mile OCI
2002 Ford F150: GTX HM 5w-20/EcoGard Syn/1yr OCI
2012 Scion xB: QSUD 0w-20/CQ Blue/5k OCI
Re: Oil Filter Question? [Re: maverickfhs] #4539411
10/10/17 06:02 PM
10/10/17 06:02 PM
VA
VA
Thanks all, will keep it for 2000 miles and then will change it.
