My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
78 registered members (agpatel, alphadog, Aichiguy, bbhero, AdditiveOCD, 9 invisible), 1,392 guests, and 62 spiders.
Topics286,436
Posts4,908,161
Members67,622
Most Online2,967
Mar 10th, 2019
Advice on brake pads for towing #4538194
10/09/17 03:36 PM
10/09/17 03:36 PM
wv
krismoriah72 Offline OP
wv
I have had my 2003 suburban for about a year, when i bought it, it needed rotors and pads all way around because my buddy knew he was selling it. He helped me install all new before i purchased it though on my dime which was fair.
I am towing a trailer loaded with a sidebyside up and down twisty mountains and hills to get to my riding destination and the braking power isnt much..takes a long way to get slowed down if a deer or critter crosses my path let alone an emergency stop.
I put all new rotors which have no warpage, but i went with the cheap pads from a brick and mortar.
So my question is would switching pads to a semi-metallic or ceramic be best? Should i opt for severe duty pads? Is AC Delco better than house brands?
I am not saying what is on there now to not jade the advice.
Re: Advice on brake pads for towing [Re: krismoriah72] #4538197
10/09/17 03:39 PM
10/09/17 03:39 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
Trailer brakes? I've had the best luck with the NAPA severe duty pads, has it ever had the brake fluid flushed?
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Advice on brake pads for towing [Re: krismoriah72] #4538202
10/09/17 03:44 PM
10/09/17 03:44 PM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
Good semi-metallic are best for towing and ceramic are best for keeping wheels clean and quiet brakes.
Raybestos has a hybrid pad sold at rockauto that I have installed on some trucks. They complained about brakes when towing or hauling a lot of weight. Its a good middle of the road between both that seems to work well.
yup
Re: Advice on brake pads for towing [Re: bullwinkle] #4538210
10/09/17 03:50 PM
10/09/17 03:50 PM
wv
wv
No its a 6X10 single axle trailer. So no trailer brakes.
Yes last week i busted a brake line (pushed the pedal hard to get to a stop at a yellow light)..So i had to flush all the old out.
Re: Advice on brake pads for towing [Re: krismoriah72] #4538212
10/09/17 03:54 PM
10/09/17 03:54 PM
ME
eljefino Offline
eljefino  Offline
ME
Pads have friction ratings... FF, GG etc. Higher is better.
Will it lock 'em all up if you stomp on it? Sounds like something's subpar.
Re: Advice on brake pads for towing [Re: krismoriah72] #4538217
10/09/17 03:57 PM
10/09/17 03:57 PM
CA
user52165 Offline
user52165  Offline
CA
"No trailer brakes"...........Put brakes on it or use another trailer with brakes. You're trying to compensate for a deficiency. Just putting on better pads won't make enough difference if the whole system is weak.
Are those drums on the rear? If rear discs, are they vented?
Re: Advice on brake pads for towing [Re: krismoriah72] #4538223
10/09/17 04:05 PM
10/09/17 04:05 PM
California
nthach Offline
nthach  Offline
California
I would say semi-metallic fleet/police pads if they fit your calipers. But there's a small catch and people here will point this out - temperature/friction coefficient rating - the 2-letter code in a brake pad's edge/plate markings. It's a measure of how well a brake lining can handle heat before brake fade happens.
Even though semi-met pads are better at handling heat than a organic pad("ceramic" pads fall into the NAO category), most of them are EE-rated but marketed as heavy-duty. It may or may not better with a reputable brand. I installed 2 sets of Wagner ThermoQuiet semi-mets into a friend's Explorer that sees some of the same duty your truck is getting and they seem to be working fine despite the EE-rating. YMMV. You could also try a ceramic upgrade in ThermoQuiet or Akebono but those pads work differently on a friction level. The big difference would be cleaner wheels and less brake fade.
http://faculty.ccbcmd.edu/~smacadof/DOTPadCodes.htm
AC Delco sources friction from various suppliers - AFAIK, they get their friction from BPI/Raybestos in the Professional/Advantage lines.
Re: Advice on brake pads for towing [Re: krismoriah72] #4538282
10/09/17 04:59 PM
10/09/17 04:59 PM
Reno, Nevada
Langanobob Offline
Langanobob  Offline
Reno, Nevada
I think trailer brake laws vary from state to state but from your description of the mountain roads and poor braking you need trailer brakes regardless of whether you may be legally required to have them.
About your vehicle, I use Hawk Performance pads on my F250 and they work well for towing, but I also have brakes on my trailers. Easy to add brakes if your axle has the backing flange for them. Etrailer.com sells the necessary parts and there are plenty of other trailer parts dealers.
Re: Advice on brake pads for towing [Re: Langanobob] #4538324
10/09/17 05:45 PM
10/09/17 05:45 PM
wv
wv
Without a trailer my suburban is about 5800lbs.
My sidebyside and trailer only weighs 1100lbs.
So without a trailer it still takes a while to stop.
Re: Advice on brake pads for towing [Re: krismoriah72] #4538331
10/09/17 05:49 PM
10/09/17 05:49 PM
wv
wv
This is the kind of trailer i have just a small utility trailer..
Re: Advice on brake pads for towing [Re: krismoriah72] #4538351
10/09/17 06:13 PM
10/09/17 06:13 PM
New Jersey
THafeez Offline
THafeez  Offline
New Jersey
Wagner Severe Duty. Meant for commercial heavy duty applications. They're semi metallic, try to find the best price online and if not they're available at pepboys.
2004 Toyota Solara SE 2.4 2AZFE
187,000 miles
Castrol Magnatec Semi-Syn 5W30 3 quarts and 1 quart of Valvoline Syn-Power 5W30 that I had left over
Fram Ultra XG3600 oversize 1st run
Re: Advice on brake pads for towing [Re: krismoriah72] #4538423
10/09/17 07:33 PM
10/09/17 07:33 PM
Maryland USA
rubberchicken Online content
rubberchicken  Online Content
Maryland USA
Which brake line, and how did you fix it ? I had same thing happen on a 97 Suburban, and used nicop to fix it.
Re: Advice on brake pads for towing [Re: krismoriah72] #4538424
10/09/17 07:33 PM
10/09/17 07:33 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
Brakes on a trailer that small are the Band-Aid... not trying to improve your vehicle's brakes to stop well empty or lightly loaded.
I put Napa Premium rotors and, IIRC, SS pads on my '85 C3500 about 2 years ago and I'm pleased with their performance. No shortage of braking power from the front end.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: Advice on brake pads for towing [Re: krismoriah72] #4538426
10/09/17 07:35 PM
10/09/17 07:35 PM
USA
slacktide_bitog Online content
slacktide_bitog  Online Content
USA
Wagner Severe Duty or OEX. Akebono ASP is also good.
Re: Advice on brake pads for towing [Re: krismoriah72] #4538436
10/09/17 07:40 PM
10/09/17 07:40 PM
Texas
4WD Offline
4WD  Offline
Texas
Put PowerStop Truck & Tow pads on Callahan slotted rotors 9 months now and they been far better than stock
No rust like factory rotors either
