Michelin jack won't lift a load
by 10WSmuckers. 09/23/18 01:32 AM
Synthetic for a 30 year old engine?
by geissjr. 09/23/18 01:02 AM
Phone Books
by csandste. 09/23/18 12:11 AM
Inside the Fuel Tank / EVAP system
by StevieC. 09/22/18 10:31 PM
Toyota Pink + RMI-25 10 years
by burla. 09/22/18 10:27 PM
Cartridge filter?
by Camprunner. 09/22/18 10:23 PM
Should have changed it?
by parshisa. 09/22/18 10:14 PM
Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
Redline D6 ATF substituting for Toyota WS
by Patrick0525. 09/22/18 05:29 PM
XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
HondaTech250, SandCruzer, sbgti96, cosmoblau, Sarrge
66044 Registered Users
22 registered members (CT8, 10WSmuckers, BlakeB, csandste, Bailes1992, Duke), 854 guests, and 36 spiders.
Topics290,867
Posts4,851,556
Members66,044
Most Online3,590
Jan 24th, 2017
Will load range help sidewall roll? #4538161
10/09/17 03:07 PM
10/09/17 03:07 PM
Hudson, NH
LeakySeals Offline OP
Hudson, NH
Working from home more and not using the highway as much is nice, but not for my tires. The current set of Bridgestone Dueler H/L Alenza P275/55R20 111S all season tires have been great. They went 50k with no issues. Now, with the majority of daily use on roads with sharp corners, slopes, back roads, hills, the sidewalls have worn out almost to the belts in a few short months. Which is a shame because the tire center tread could make another winter. I have to buy tires. What should I consider for the new environment this truck operates in? Help prevent rolling on the sidewall. Does the load range matter? What tire should buy to minimize roll?
06 Escalade 6.0L LQ9 AWD 165k M1 5w30
03 Maxima 3.5L POS 152k ST HM 10w30
Re: Will load range help sidewall roll? [Re: LeakySeals] #4538166
10/09/17 03:09 PM
10/09/17 03:09 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Pump up the pressure and check out the bushings.
2015 Hyundai Sonata 2.4L 84k Mobil 1 AFE 0w30 & OEM
2000 Toyota Camry 2.2L 230k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Re: Will load range help sidewall roll? [Re: LeakySeals] #4538278
10/09/17 04:52 PM
10/09/17 04:52 PM
Kevil,Ky
vwmaniaman Offline
vwmaniaman  Offline
Kevil,Ky
I have an 07 Dodge 1500 quad Laramie and just got new tires last week. Local tire place here recommended Falken tires for it and can take 51 psi at max load. I pull my 5th wheel with it and wanted stiffer sidewalls for better control. So far they feel great though haven't pulled trailer with them yet. Wildpeak Falken HT is what they are. Had Coopers in same size you have before. Lasted OK but were very noisey.
Don't waste your time on a slipshod repair.
Re: Will load range help sidewall roll? [Re: vwmaniaman] #4538312
10/09/17 05:36 PM
10/09/17 05:36 PM
Hudson, NH
Hudson, NH
Tire rack doesn't sell them in my size, but I did find them on a site called SimpleTire. They are XL load range, 117H. I think that means more sidewall stability, anyone know?
Re: Will load range help sidewall roll? [Re: LeakySeals] #4538322
10/09/17 05:43 PM
10/09/17 05:43 PM
Nebraska
Duffyjr Offline
Duffyjr  Offline
Nebraska
When I inherited my truck (see sig) it had P rated tires on it that were a about half worn down but I figured I could get a few more miles out them but corning and handling was awful, it felt like I was leaning way to far on turns and I thought the handling was bad just going down the road straight. When I put new tires on I went with LT tires which is what it calls for on the door sticker. Way better handling and corning, so ya I think it would help you.
Cooper AT3's with 50 psi is what they told me to run. Does it ride a little rough, maybe but it is a pickup.
89 GMC Sierra T5 10w30/Wix
08 Lucerne CX NAPA Blend 5w30/Napa Gold
18 Toro Super Recycler T5 10w30
Re: Will load range help sidewall roll? [Re: LeakySeals] #4538412
10/09/17 07:27 PM
10/09/17 07:27 PM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
Maybe, maybe not...my story:
My E450 came with Michelin LTX M/S E range from the factory. Due to a recall, I got a free set of LTX M/S2 this year. After installation I found the truck had a lot more flex in the tires even though they are the same load range and inflation.
I did some research and found Ford has a spec LTX tires for this fitment with different construction. I got used to the delay in steering response but it would be better with a stiffer tire.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: Will load range help sidewall roll? [Re: LeakySeals] #4538766
10/10/17 07:14 AM
10/10/17 07:14 AM
Somewhere in the US
CapriRacer Offline
CapriRacer  Offline
Somewhere in the US
First, that's just the way steer tires wear. You should plan on rotating tires more often as the rears (drive) tend to wear in the center.
You could try more inflation pressure in the front, but I wouldn't use more than 10 psi over the placard.
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: Will load range help sidewall roll? [Re: Nick1994] #4538775
10/10/17 07:20 AM
10/10/17 07:20 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
+1
Re: Will load range help sidewall roll? [Re: LeakySeals] #4538814
10/10/17 08:10 AM
10/10/17 08:10 AM
NJ
UG_Passat Offline
UG_Passat  Offline
NJ
The Alenza is a tire for more comfort and wear.
Get a more aggressive street tire.
https://www.tirerack.com/tires/TireSearc...rearDiameter=17
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Will load range help sidewall roll? [Re: LeakySeals] #4539242
10/10/17 03:28 PM
10/10/17 03:28 PM
Hudson, NH
Hudson, NH
Another question I was wondering about. Does it matter what PSI the tires are balanced at, or aligned at? Whoever I buy tires from will probably go by the book, which is a lot less than what I need.
Re: Will load range help sidewall roll? [Re: LeakySeals] #4539860
10/11/17 07:30 AM
10/11/17 07:30 AM
Somewhere in the US
CapriRacer Offline
CapriRacer  Offline
Somewhere in the US
Ah ..... Mmmmmm ......
No! Not balance!
However, tire uniformity (think runout and you'll be close!) does depend on inflation pressure - BUT - the machines used at the store level don't generate enough load on the road wheel to matter - assuming they are using that feature.
CapriRacer
Re: Will load range help sidewall roll? [Re: CapriRacer] #4540124
10/11/17 11:54 AM
10/11/17 11:54 AM
Hudson, NH
Hudson, NH
No! Not balance!
Would a 117 load rating improve tire roll over a 111?
Re: Will load range help sidewall roll? [Re: LeakySeals] #4540980
10/12/17 08:34 AM
10/12/17 08:34 AM
Somewhere in the US
CapriRacer Offline
CapriRacer  Offline
Somewhere in the US
Not really, but more inflation pressure will.
Why? Because the change in stiffness due to inflation pressure is so much larger than the casing stiffness, that the casing stiffness gets lost in the mud. The only time you feel it is when you are doing transients.
CapriRacer
