2005 Chevy Silverado 5.3 vortex
by MSpeer. 12/17/18 12:01 PM
Comma X-Tech 5w30 oil, any good?
by BobGoblin. 12/17/18 11:40 AM
Modern Engine's Grenading?
by Nickdfresh. 12/17/18 11:15 AM
Magnetic Smartphone Holders
by willbur. 12/17/18 11:06 AM
1991 Caprice 5.0l hard starting in the AM
by WyrTwister. 12/17/18 10:55 AM
Question about new Peak OEM coolants
by PD001. 12/17/18 10:21 AM
Rev X
by Big_3_Only. 12/17/18 10:04 AM
Modern engines put less contaminants in the oil?
by WyrTwister. 12/17/18 08:12 AM
Gear whine
by odotb. 12/17/18 07:38 AM
Honda Pilot Oil specs US vs Overseas
by parshisa. 12/17/18 06:23 AM
Advisory on Roku TV's
by LoneRanger. 12/17/18 05:44 AM
Chevy Commercial Parody
by 02SE. 12/17/18 02:37 AM
Fluctuating Tachometer Fixed!
by jerseyguy123. 12/17/18 02:10 AM
2015 MB GLA250: OEM oil vs Mobil1 Formula M
by SlavaB. 12/17/18 12:39 AM
Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
harvey_01, Gordon_Walter, MikeSheng, stantaur, Brandon9797
66703 Registered Users
109 registered members (Anduril, aba4430, 4WD, 11 invisible), 2,079 guests, and 48 spiders.
Topics295,186
Posts4,929,414
Members66,703
Most Online2,553
Oct 27th, 2018
Ruger LCP 380ACP #4538068
10/09/17 12:39 PM
10/09/17 12:39 PM
n.c.
gman2304 Offline OP
gman2304  Offline OP
n.c.
I ordered my wife one from PSA for her CCW. She had some difficulty racking the slide on one at the gun shop, but hopefully it will loosen up after a few range sessions. Iím also considering buying An LCP for myself as a pocket carry. PSA and Buds have them for $169. They were double that price only a year or so ago. Do any of you have any experience with these small CCW in 380 acp? If youíre in the market for a hand gun, it seems to be a good time to buy.
Re: Ruger LCP 380ACP [Re: gman2304] #4538080
10/09/17 12:52 PM
10/09/17 12:52 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
I have a S&W PPKS in 380 ACP reasonably accurate and the slide is not hard for me at all. But my wife has some Arthritis issues and for her I got a S&W Model 60 in 38 Special which is much simpler for her and has more stopping power. She shoots it amazing well.
2004 Corolla 126884
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74478
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Ruger LCP 380ACP [Re: JohnnyJohnson] #4538087
10/09/17 12:55 PM
10/09/17 12:55 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
J frames are nice !
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Ruger LCP 380ACP [Re: gman2304] #4538164
10/09/17 02:09 PM
10/09/17 02:09 PM
San Antonio, TX
E150GT Online content
E150GT  Online Content
San Antonio, TX
I dont care for the trigger on the LCP. My brother has one. I have a Taurus TCP and I feel the trigger is nicer. Either way, you cant go wrong for a self defense pistol.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: Ruger LCP 380ACP [Re: gman2304] #4538174
10/09/17 02:13 PM
10/09/17 02:13 PM
n.c.
gman2304 Offline OP
gman2304  Offline OP
n.c.
The J frame 638 Airweight is plan B for her. She likes the simplicity of it. I'm planning on taking the LCP to the range a few times and if it doesn't loosen up enough for her, I'll use it as a pocket carry.
Re: Ruger LCP 380ACP [Re: gman2304] #4538206
10/09/17 02:46 PM
10/09/17 02:46 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
I used to own a IO Hellcat .380 which was a clone of the KelTec 380.. which the Ruger LCP is just a refined version of..
Great size if you need to carry while jogging, but very snappy recoil and you better not miss because 6+1 isn't much against the wrong kind of dirtbag.
I now have a Glock 43 which is marginally larger but also more tolerable to shoot and in a caliber with more ammo options.
Re: Ruger LCP 380ACP [Re: gman2304] #4538232
10/09/17 03:12 PM
10/09/17 03:12 PM
Al
cashmoney Offline
cashmoney  Offline
Al
Recent made LCPs reputedly have what some folks consider a dangerously short trigger pull for a firearm without a manual safety. The older versions from 3-4 years ago had a long relatively stiff trigger pull. The LCP is easy to conceal and carry but it is a very snappy gun even with .380 and no fun at all to shoot and practice with. They are also pretty lightly built so if you plan to but enough rounds through it to actually be good with it I'd plan on getting a second one.
I switched to a SW M&P .380 a couple of years ago because it's just a little stronger built and runs more smoothly for me. Just slightly heavier but shoots way easier on the hand and more accurate for me personally although the trigger pull is a country mile. Have put 2k rounds through it to date with zero signs of wear or tear and maybe 2-3 FTF/FTE total. The gun allows me to reliably shoot 6 inch groups in double tap mode at 7-10 yards.
Re: Ruger LCP 380ACP [Re: gman2304] #4538262
10/09/17 03:39 PM
10/09/17 03:39 PM
Elizabethtown, Pa
Al Offline
Al  Offline
Elizabethtown, Pa
It won't loosen up. Having said that..if she can't rack an LCP then not sure she could rack anything. Obviously, you could rack it ahead of time.
Still a bad plan though..she needs a wheel gun.
Not trying to be sexist but too many guys are too anxious to put a defensive firearm in the hands of their significant other without the level of training comensurate with this responsibility. Not aimed at the OP.
Re: Ruger LCP 380ACP [Re: gman2304] #4538277
10/09/17 03:51 PM
10/09/17 03:51 PM
N.C.
RHALL Offline
RHALL  Offline
N.C.
Iíve got a LCP that Iíve carried daily for several years. Itís definitely not a target pistol , but accurate enough for what itís designed for. My wife has trouble racking the slide too, but she can shoot it fairly well. Our house gun is a Ruger GP100 357 magnum, and sheís very good with it.
"Stupid Is As Stupid Does"- Forrest Gump
Re: Ruger LCP 380ACP [Re: gman2304] #4538283
10/09/17 04:00 PM
10/09/17 04:00 PM
Marietta, GA
TOMJ Offline
TOMJ  Offline
Marietta, GA
I looked at the LCP a few years ago and could barely rack the slide myself. It was just too small for me as well.
I ended up with a Glock 42. This was before they came out with the 9 mm 43.
I'm happy with my 42 and it's my EDC. It's easy to shoot and not too snappy. Being a Glock, it is pricey. I would consider the Taurus TCP. They can be had for less $200.00.
Never mind, I see that you already have a plan B.
1992 GMC C1500 Mobil 1 HM
1993 Honda Civic Mobil 1 HM
2007 Honda VTX1300 R Mobil Delvac 1300
2006 Sea Doo GTI SE Mobil Delvac 1300
2008 Yamaha F115 Mobil Delvac 1300
Re: Ruger LCP 380ACP [Re: gman2304] #4538288
10/09/17 04:04 PM
10/09/17 04:04 PM
Kevil,Ky
vwmaniaman Offline
vwmaniaman  Offline
Kevil,Ky
I also have a concealed carry IO Hellcat. Works good. Bought a Diamond Back 380 that is easier to rack and hold onto but has a country mile trigger pull. Pretty accurate though.
Don't waste your time on a slipshod repair.
Re: Ruger LCP 380ACP [Re: gman2304] #4538294
10/09/17 04:17 PM
10/09/17 04:17 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Having shot a gun or 30 at the gun range, I think those pocket .380's are a poor choice for anyone on the weak side, female or male. They have nasty recoil and are harder to shoot well than heavier pistols in larger calibers.
But having a small gun that you'll carry is better than not having one on you at all. The Glock model 42 is not a pocket pistol.
There are people who own those guns and are not holstering them properly which is a bad idea since it lacks a safety.
My local gun shop, Vances, has the Ruger LCP II on sale for $229.99 and it includes a pocket holster. I'd get a DeSantis Nemesis pocket holster if I was to carry the old LCP.
Me: 13' VW GTI 3 door 6 speed manual
Wanted: 2019 Ford Ranger
Re: Ruger LCP 380ACP [Re: gman2304] #4538405
10/09/17 06:18 PM
10/09/17 06:18 PM
pa
benjy Online content
benjy  Online Content
pa
the ruger LCR is a good choice + comes in several flavors, + revolvers are great for anyone, very simple + most reliable. the LCR has a great trigger pull as advertised very smooth!!
Re: Ruger LCP 380ACP [Re: skyactiv] #4538784
10/10/17 06:29 AM
10/10/17 06:29 AM
Marietta, GA
TOMJ Offline
TOMJ  Offline
Marietta, GA
You state that the Glock 42 is not a pocket pistol and that a .380 is a poor choice as an EDC due to the recoil. My 42 shoots very well. I can shoot 50-100 rounds at the range no problem.
I wouldn't want to try that with a LCP.
I carry my 42 in my pocket every day in an Uncle Mike's pocket holster. I can't say that I forget it's there but it does fit in jeans pockets very well.
Also, check out this video.....https://www.youtube.com/watch?v=GNtPHYwcDts
These .380 rounds pass the F.B.I. 12 -18" penetration protocol.
Guess what's in my .380 right now....
A .380 in my pocket is better if I ever need it than my 9mm sitting at home.
Re: Ruger LCP 380ACP [Re: TOMJ] #4538846
10/10/17 07:56 AM
10/10/17 07:56 AM
Glendale, Arizona
billt460 Offline
billt460  Offline
Glendale, Arizona
Originally Posted By: TOMJ
You state that the Glock 42 is not a pocket pistol and that a .380 is a poor choice as an EDC due to the recoil. My 42 shoots very well. I can shoot 50-100 rounds at the range no problem. I wouldn't want to try that with a LCP.
While I don't own a .380. If I were to buy one, it would be either a Glock 42 or a Beretta Cheetah 13 round double stack. The LCP is too tiny for my hands. Micro pocket pistols don't interest me. But I will admit to owning a couple of North American Arms .22 Mini Revolvers. They are a cute, well made novelty.
