Originally Posted By: i_hate_autofraud
If the fixture in enclosed, the lamp may be over heating, some fluorescents bulbs with screw bases don't take
heat well in the 'overhead' position, but do well in table lamp applications.
More rare is a voltage/ wiring problem, check various outlets near the light to see that 115 /120V is between
the flat slots with one slot giving full voltage to the ground socket, the other slot (neutral) should
be 2V or less to the same ground. A selection of sockets in the house should read nearly identical
if you check them one after the other.
If you have a screw-in socket converter with an outlet, you can measure voltage in the light fixture directly safely.
Good point about the enclosure.
Also, if it is an enclosure, some LEDs will overheat and burn out quickly. Must use an LED designed for enclosures. Will state so on package.
