Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
Finally Found Factory Ammo my 308 Bolt Gun Likes
by Fastzntn. 03/24/19 08:10 PM
Umarex Glock 19 Co2
by Sonic. 03/24/19 07:57 PM
I put in 2 1/2 qts, damage?
by JLawrence08648. 03/24/19 07:21 PM
How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
90 registered members (97prizm, Bailes1992, ARCOgraphite, avi1777, 240_Ed, 2010Civic, 8 invisible), 1,711 guests, and 61 spiders.
Topics286,387
Posts4,907,349
Members67,614
Most Online2,967
Mar 10th, 2019
Looking for a fuse time curve #4537866
10/09/17 10:51 AM
10/09/17 10:51 AM
Great Lakes
Quattro Pete Offline OP
Great Lakes
I'm looking at a DMM that uses a 10A/600V (5 x 20mm) fast blow fuse. That's all the info I've got. I'm having a hard time googling a time curve for it. Is it because this is insufficient information to identify this fuse?
I'm trying to understand for how long I can continuously monitor a 3 Amp DC current without blowing this fuse.
Thanks!
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: Looking for a fuse time curve [Re: Quattro Pete] #4537881
10/09/17 11:02 AM
10/09/17 11:02 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
Well at 3A a 10A fuse should never blow.
Here's a fuse chart and their meanings.
http://bussfuses.net/
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Looking for a fuse time curve [Re: Quattro Pete] #4537893
10/09/17 11:14 AM
10/09/17 11:14 AM
USA
mk378 Offline
mk378  Offline
USA
The time curve describes how quickly the fuse will blow at various currents above the fuse rating. Currents below the rating can be carried indefinitely.
Re: Looking for a fuse time curve [Re: Quattro Pete] #4537910
10/09/17 11:25 AM
10/09/17 11:25 AM
Great Lakes
Great Lakes
Got it. Thanks.
Re: Looking for a fuse time curve [Re: Quattro Pete] #4537986
10/09/17 12:47 PM
10/09/17 12:47 PM
Canada
i_hate_autofraud Offline
Canada
Key point is stick with FB fuses, a SB fuse even with a lower rating will blow the internal fuse.
If the DMM is an expensive one, it may have a internal fuse too that's hard or expensive, like a
Buss "BBS-_" Midget cartridge 'meter' fuse costing $15 - $23 each!
Figure that SB fuses are 4 -5 times slower and pass higher current before letting go.
Re: Looking for a fuse time curve [Re: Quattro Pete] #4538503
10/09/17 08:50 PM
10/09/17 08:50 PM
Greenville SC
George Bynum Offline
Greenville SC
Thanks!
I don't know who makes it, and until my friend Google came through would have bet there were no 600V fuses that size ... but see http://cci-parts.com/product_info.php?manufacturers_id=&products_id=317.
As others have said, a 10A fuse will carry 10A "forever"
Re: Looking for a fuse time curve [Re: George Bynum] #4538555
10/09/17 10:06 PM
10/09/17 10:06 PM
Great Lakes
Great Lakes
So what's this warning in the DMM owners manual all about?
Quote:
Input Limits:
10A Current AC or DC: 30 seconds max. every 15 minutes)
Re: Looking for a fuse time curve [Re: Quattro Pete] #4538655
10/10/17 02:25 AM
10/10/17 02:25 AM
Sequim, WA
edhackett Offline
edhackett  Offline
Sequim, WA
Quote:
Input Limits:
That's the limitation of the meter's circuitry. It's been my experience that cheap meters serve as protection for the fuse.
The Fluke 170 series, for example is also rated at 10A AC or DC. They can read an overload of 20A for 30 seconds. That's just one differences when you step up to a quality meter.
Ed
Never attribute to engineers that into which politicians, lawyers, accountants, and marketeers have poked their fingers.
Re: Looking for a fuse time curve [Re: Quattro Pete] #4538795
10/10/17 07:42 AM
10/10/17 07:42 AM
Great Lakes
Great Lakes
Thanks. But if I just pass 3A current through the meter, can I do it indefinitely?
Re: Looking for a fuse time curve [Re: Quattro Pete] #4539095
10/10/17 12:55 PM
10/10/17 12:55 PM
Greenville SC
Greenville SC
You should be able to with no problem. Power (heat) is proportional to current squared, so 3 amps would generate about 10% as much heat as 10 amps. The 30 seconds every 15 minutes sounds like a hear issue.
Re: Looking for a fuse time curve [Re: Quattro Pete] #4540022
10/11/17 10:19 AM
10/11/17 10:19 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
Quote:
Input Limits:
Probably more because of the wire size of the leads.
Re: Looking for a fuse time curve [Re: George Bynum] #4540024
10/11/17 10:24 AM
10/11/17 10:24 AM
Great Lakes
Great Lakes
A hear issue?
Re: Looking for a fuse time curve [Re: Quattro Pete] #4540196
10/11/17 01:06 PM
10/11/17 01:06 PM
Canada
Canada
"Input Limits:
10A Current AC or DC: 30 seconds max. every 15 minutes)"
The reason for this is a cheap meter will have a "shunt resistor" to get a voltage drop that
indicates the current. They get hot. so that's the reason for the time limits.
On expensive DMMs, they'll have a current shunt made from Manganin alloy (84% copper, 12% manganese, and 4% nickel)
that can handle a full current with no time limits. The alloy allows accurate measurements
even when the shunt gets warm.
Re: Looking for a fuse time curve [Re: Quattro Pete] #4540406
10/11/17 04:28 PM
10/11/17 04:28 PM
Greenville SC
Greenville SC
hear here ... I'm not hot unlike the HEAT I should have used. Thanks for catching my mistake.
George
Re: Looking for a fuse time curve [Re: George Bynum] #4540421
10/11/17 04:57 PM
10/11/17 04:57 PM
Great Lakes
Great Lakes
George
Thanks for clarifying.
I wasn't trying to nitpick. I figured it was a typo, but I truly couldn't figure out what it was supposed to be. Now it all makes sense. Thank you. smile
