Inspecting my mother’s envoy I noticed a small drip of gear oil right below the drain plug on the front differential. I checked for the correct torque on the plug seems fine. I believe the leak is actually the front drive shaft differential pinion seal. Can’t be sure because I didn’t have all my tools to remove cross member etc.. I can see a fair amount of black oil gunk on the propeller shaft right behind the front diff. I don’t want the dealer ripping her off, they quoted $2000 to fix the leak. Anybody have an idea how many hrs a job like this should take? I’m assuming a new pinion seal itself Isn’t much. Thanks
