New Valvoline Synpower MSDS sheet
After a quick look, I don't see the oils I'm interested in. Motorcycle 20-50 and 5-40MST. Also am I correct in assuming these oils are Group 3 based?
I readjusted the search parameters and have a whole list of Valvoline oils. The list is scrollable. I hope this helps in your search.
The SDS I picked originally was for Synpower 0w-20. I noticed it has a ester component along with another type of component which I don't know how to classify. Normally you don't see these things in the SDS. It will just state mineral oil or a range of oils for the base. There has been some guessing that Synpower has esters and this SDS may well prove that.
