Mobil @ Bomgaars sale
by Duffyjr. 09/23/18 04:45 AM
More California BS!
by dogememe. 09/23/18 04:04 AM
Optimum No Rinse Wash and Wax or Shine?
by anndel. 09/23/18 03:44 AM
Michelin jack won't lift a load
by 10WSmuckers. 09/23/18 01:32 AM
Synthetic for a 30 year old engine?
by geissjr. 09/23/18 01:02 AM
Phone Books
by csandste. 09/23/18 12:11 AM
Inside the Fuel Tank / EVAP system
by StevieC. 09/22/18 10:31 PM
Toyota Pink + RMI-25 10 years
by burla. 09/22/18 10:27 PM
Cartridge filter?
by Camprunner. 09/22/18 10:23 PM
Should have changed it?
by parshisa. 09/22/18 10:14 PM
Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
HondaTech250, SandCruzer, sbgti96, cosmoblau, Sarrge
66044 Registered Users
27 registered members (bmod305, Char Baby, carviewsonic, Bailes1992, Blkstanger, 3 invisible), 691 guests, and 33 spiders.
Topics290,869
Posts4,851,591
Members66,044
Most Online3,590
Jan 24th, 2017
Front differential Leak 2008 GMC Envoy V-8 #4537607
10/08/17 11:30 PM
10/08/17 11:30 PM
Western usa
Ammofirst Offline OP
Western usa
Inspecting my motherís envoy I noticed a small drip of gear oil right below the drain plug on the front differential. I checked for the correct torque on the plug seems fine. I believe the leak is actually the front drive shaft differential pinion seal. Canít be sure because I didnít have all my tools to remove cross member etc.. I can see a fair amount of black oil gunk on the propeller shaft right behind the front diff. I donít want the dealer ripping her off, they quoted $2000 to fix the leak. Anybody have an idea how many hrs a job like this should take? Iím assuming a new pinion seal itself Isnít much. Thanks
Re: Front differential Leak 2008 GMC Envoy V-8 [Re: Ammofirst] #4537620
10/09/17 12:38 AM
10/09/17 12:38 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
2K$ will buy an awful lot of diff lube. I 've never replaced a pinion seal. The Rat's seal is gone, I go through a pint of lube a yr. I recommend keeping an eye on the level. Also, I believe that the old method of filling until it runs out of the hole is a mild over fill and will blow misted lube out of the vent.
Thick oil is better grin2
Re: Front differential Leak 2008 GMC Envoy V-8 [Re: Ammofirst] #4537624
10/09/17 01:04 AM
10/09/17 01:04 AM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
Is there an independent shop that specializes in drivelines in your area?
Re: Front differential Leak 2008 GMC Envoy V-8 [Re: OneEyeJack] #4537634
10/09/17 02:54 AM
10/09/17 02:54 AM
Western usa
Western usa
There might be idk. Unfortunately they live pretty far away which makes it hard for me to just keep an eye on it. The car sits too much. Its a 2008 with 22k on it. I just canít imagine it being more than a 5-6 hr job.
Re: Front differential Leak 2008 GMC Envoy V-8 [Re: Ammofirst] #4537651
10/09/17 04:39 AM
10/09/17 04:39 AM
Reno, Nevada
Langanobob Offline
Langanobob  Offline
Reno, Nevada
Oil around the fromt differential could be coming down from somewhere up above. Seems unlikely that the pinion seal would be leaking at 22,000 miles even if it is a 10 year old vehicle. I'd sure absolutely confirm where the leak is coming from before having the seal replaced.
Re: Front differential Leak 2008 GMC Envoy V-8 [Re: Ammofirst] #4537655
10/09/17 05:19 AM
10/09/17 05:19 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
I had a Mercury years ago leak at the pinion. Wasn't bad but under warranty and had the dealer "fix" it. Wish I never did. Wound up with a noisy differential and still listen to it to this day. They said it is normal.I have an F150 which has a pinion leak. Sprays a fine mist of oil all over underneath. I top it off with such a small amount every few years, probably a sippy cup full. My suggestion, leave it alone, maintain the level. If it leaks a puddle on the pavement, then I would have it fixed.
The "thinking" man's friend.
Re: Front differential Leak 2008 GMC Envoy V-8 [Re: Lubener] #4537670
10/09/17 06:18 AM
10/09/17 06:18 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
cry
Re: Front differential Leak 2008 GMC Envoy V-8 [Re: Ammofirst] #4537711
10/09/17 07:14 AM
10/09/17 07:14 AM
Texas
4WD Offline
4WD  Offline
Texas
Is the oil a 90 with opportunity to go 140? Thatíd be a chance to add a small amount of seal conditioner too
Re: Front differential Leak 2008 GMC Envoy V-8 [Re: Ammofirst] #4537785
10/09/17 09:24 AM
10/09/17 09:24 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
The dealer is either trying to cut a fat hog or is quoting you the price to replace the whole front diff. In theory the diff crush sleeve should be replaced whenever you remove the pinon nut. It's very easy to get the preload wrong and cause noise or burn the bearings up.
In reality lots of ppl just replace the seal, put the nut back on where it was and go about their day. Book time for this is a couple of hours plus the seal. I am guessing $30 for the seal and 2 hrs @ $100/hr.... $230ish.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Front differential Leak 2008 GMC Envoy V-8 [Re: Ammofirst] #4537788
10/09/17 09:31 AM
10/09/17 09:31 AM
Texas
GMBoy Offline
GMBoy  Offline
Texas
If you are talking the output shaft seal - let's hope it is not the right side! Here is the GM labor guide:
3010110 Output Shaft Seal Replacement - Right Side
Effective Date: Oct 1, 2017
LABOR CODE: 3010110
Base LABOR TIME: 6.3
Engine Codes H, M and P LABOR TIME: 4.8
To Replace Left Seal ADD TIME: 0.1
3010130 Output Shaft Seal Replacement - Left Side
LABOR CODE: 3010130
Base LABOR TIME: 1.5
Re: Front differential Leak 2008 GMC Envoy V-8 [Re: Ammofirst] #4537805
10/09/17 09:58 AM
10/09/17 09:58 AM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
Going through this currently. In my case the front diff vent tube fell off the plastic fender well, causing the diff to fill with water, salt, sand, etc. over time. The damage is done internally, the PO didn't see it for "years". Anyways, I swapped out the fluid with the correct viscosity synthetic (M1 75w90) and after the second drain and fill, the leak stopped. The drip came back when I had the bright idea of trying 75w140 in an attempt to quiet howling at specific speeds. So I went back to 75w90 syn, no leak. So check the diff vent, make sure its not kinked or fell underneath. Change the fluid with spec and importantly make sure the level is correct. its not necessarily "1.8qts". Its (check manual) some measurement below the fill hole cold. This allows for expansion without filling up the vent hole with fluid, causing a pressure problem, bursting fluid out that seal.
After looking at the costs of repairing only whats wrong the existing diff, I intend to shotgun the entire unit with a eBay reman at some point. You can get them for approx $1,000.
06 Escalade 6.0L LQ9 AWD 165k M1 5w30
03 Maxima 3.5L POS 152k ST HM 10w30
Re: Front differential Leak 2008 GMC Envoy V-8 [Re: LeakySeals] #4537811
10/09/17 10:05 AM
10/09/17 10:05 AM
Texas
4WD Offline
4WD  Offline
Texas
In the meantime just exercise your right bestowed upon you by your BITOG handle ... that $1000 remanufactured plan is good when you do the wrenching Ö did one on a Dana 44 way back and it was stronger than what I broke Ö
Re: Front differential Leak 2008 GMC Envoy V-8 [Re: 4WD] #4537849
10/09/17 10:42 AM
10/09/17 10:42 AM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
FYI a quick google suggests others experienced a leak from the differential case seal in your years. You will see something lower right, below the pinion seal. Try cleaning it up real good and watch. Either way, I would be doing a drain and fill.
Re: Front differential Leak 2008 GMC Envoy V-8 [Re: LeakySeals] #4537889
10/09/17 11:09 AM
10/09/17 11:09 AM
Texas
4WD Offline
4WD  Offline
Texas
OP or me?
Re: Front differential Leak 2008 GMC Envoy V-8 [Re: Ammofirst] #4537952
10/09/17 12:20 PM
10/09/17 12:20 PM
Western usa
Western usa
The little drip felt like 90wt oil. I will inspect above just in case. I did take notice of the vent tube & it looks to be upright in orig. condition. Sounds like a job thatís easy to foul up which has me concerned. Wish I knew how to use the quote function ?
