Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
In praise of kludges...
by wings&wheels. 01/17/19 02:11 PM
Has Mobil 1 0w40 been discontinued?
by Doublehaul. 01/17/19 01:17 PM
Some questions for the home theater gurus
by grampi. 01/17/19 12:55 PM
Weird side problems after doing repairs
by mclasser. 01/17/19 12:31 PM
Shell Rotella Gasoline Truck.
by JHogan. 01/17/19 12:14 PM
Sears to stay open, for now
by addyguy. 01/17/19 11:35 AM
What Have I Gotten Myself Into?
by Gebo. 01/17/19 11:17 AM
Car stereo FM/ AM Reception Problems
by LazyDog. 01/17/19 11:13 AM
PPHM uoa requests
by aquariuscsm. 01/17/19 11:00 AM
Odd issue in Tacoma 3.5L V6 (2GR-FKS)
by 2019StingrayZ51. 01/17/19 10:58 AM
Alternative to Gillette Fusion razor
by gman2304. 01/17/19 10:55 AM
CAFE standards
by otis24. 01/17/19 10:01 AM
5w30 vs 5w40 Mercedes E220 BLUETEC
by Costas00. 01/17/19 09:56 AM
Moving mobility scooters
by supton. 01/17/19 08:59 AM
Car stumbling in idle
by dan765. 01/17/19 08:58 AM
Fiat 9.55535-GS1 Certification - Ravenol
by RamFan. 01/17/19 08:35 AM
Bigyetti83, Drava, supertrucker, neiltt, Drspel
66960 Registered Users
119 registered members (anndel, Andy636, addyguy, aquariuscsm, 28oz, AandPDan, 13 invisible), 2,179 guests, and 49 spiders.
Topics296,731
Posts4,957,830
Members66,960
Most Online2,577
Jan 14th, 2019
Odd transmission behavior #4537309
10/08/17 03:06 PM
10/08/17 03:06 PM
FL, USA
gregk24 Offline OP
gregk24  Offline OP
FL, USA
Yesterday when driving the Jetta the transmission seemed to malfunction, but it was only for a split second. I was acceleration from a stop light and I think it was right around 30 miles per hour when the transmission seemed to pause then clunked into the next gear. In my experience these transmissions (09G) are a bit clunky at low speeds, but it has never done this odd shift before. It felt almost like it couldn't decide which gear to go in then banged in, no drama after that. It is sitting at 32,000 miles now and the transmission fluid changed will be done at 40K.
2012 Honda Accord EX-L K24z3
54,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
40,xxx miles
Castrol OEM dealer fill / OEM filter
Re: Odd transmission behavior [Re: gregk24] #4537320
10/08/17 03:18 PM
10/08/17 03:18 PM
Orlando, FL
Mr Nice Offline
Mr Nice  Offline
Orlando, FL
OEM ATF probably needs replacement.
On a new car with ATF, I'll drain and refill at 30K miles. Lots of metal slime on the magnetic drain plug.
Re: Odd transmission behavior [Re: Mr Nice] #4537326
10/08/17 03:24 PM
10/08/17 03:24 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
This.
The first fluid change on an automatic removes the most gunk and really should be done sooner than the auto makers call for.
Me: 13' VW GTI 3 door 6 speed manual
Wanted: 2019 Ford Ranger
Re: Odd transmission behavior [Re: skyactiv] #4537330
10/08/17 03:37 PM
10/08/17 03:37 PM
VA
Gebo Offline
Gebo  Offline
VA
This.
THAT +2
AND make sure you use the proper ATF. They are NOT all the same. AND from I checked into, your Transmission takes a very special ATF.
'98 LEX LS400 280K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 60K
Amsoil in all engines, transmissions and differentials
Re: Odd transmission behavior [Re: gregk24] #4537348
10/08/17 04:14 PM
10/08/17 04:14 PM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
It's under warranty, right? Keep a pad of paper in the car and write down the time, date, and conditions when it happens. Let the dealer handle it.
Re: Odd transmission behavior [Re: gregk24] #4537406
10/08/17 05:43 PM
10/08/17 05:43 PM
Boston
lairdwd Offline
lairdwd  Offline
Boston
http://forums.mwerks.com/showthread.php?5488563-My-experience-with-the-09G-Transmission
tldr: yet another [censored] VW transmission, probably valve body. The worst of the worst.
Re: Odd transmission behavior [Re: lairdwd] #4537518
10/08/17 07:55 PM
10/08/17 07:55 PM
FL, USA
gregk24 Offline OP
gregk24  Offline OP
FL, USA
Hmm, I have read of this issue with MKV, but not MKVI Jetta's.
54,xxx miles
40,xxx miles
