Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
74 registered members (Bailes1992, alarmguy, avi1777, aquariuscsm, Astro_Guy, bcossa2001, 7 invisible), 1,080 guests, and 48 spiders.
Topics286,107
Posts4,902,713
Members67,563
Most Online2,967
Mar 10th, 2019
Oil for Honda GX270 pressure washer? #4537303
10/08/17 03:57 PM
10/08/17 03:57 PM
USA
Avery4 Offline OP
Avery4  Offline OP
USA
I found a 3200 PSI pressure washer in the garbage with a Honda GX270 engine on it. The only thing that was wrong with it was it was hydrolocked with oil. I removed the spark plug, cranked the engine a few times to push the oil out, and it started right up and ran perfect! The motor does not leak or burn oil and has great compression. The pump works great too. My question is what type and brand of oil to use? I live in a hot climate, so I am thinking a synthetic 10w30 or 10w40 would work well. I want the engine to last as long as possible, so I would like to use the best oil that I can use. I don't have a problem paying for quality.
Re: Oil for Honda GX270 pressure washer? [Re: Avery4] #4537323
10/08/17 04:21 PM
10/08/17 04:21 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
You'd have to use it commercially quite awhile for the engine to wear out. You'll never wear the engine out for typical home owners use. I owned a motorcycle that had a faulty petcock that let gas seep into the cylinder which hydro locked it. Oil? If you get 20 responses you will get different answers. None of us know which is best. Me? I'd like to think something that meets the Porsche A40 spec will be best. Buy a quart of Pennzoil Platinum Euro 5W40 at Advance Auto.
Me: 13' VW GTI 3 door 6 speed manual
Re: Oil for Honda GX270 pressure washer? [Re: Avery4] #4537329
10/08/17 04:36 PM
10/08/17 04:36 PM
VA
Gebo Offline
Gebo  Offline
VA
I use one of the Amsoil Small Engines oils (10w30 or 10w40) and their Compressor Oil ISO 100-SAE 30/40 in the pump.
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Schaeffer in the first two.
Re: Oil for Honda GX270 pressure washer? [Re: Avery4] #4537334
10/08/17 04:51 PM
10/08/17 04:51 PM
OBX & Central FL
NormanBuntz Offline
NormanBuntz  Offline
OBX & Central FL
My Honda GC160 manual specs 10w-30 synthetic. My pressure washer is 2600 psi.
2017 Honda Odyssey SE, 18K
2013 Honda Accord LX, 59K
2007 Honda Ridgeline RTS, 89K
2007 Infiniti M35, 107K
Re: Oil for Honda GX270 pressure washer? [Re: Avery4] #4537336
10/08/17 04:58 PM
10/08/17 04:58 PM
Port Orange, Florida
Panzerman Offline
Panzerman  Offline
I've found my Honda engines like a thicker oil.
I like straight 30HD.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: Oil for Honda GX270 pressure washer? [Re: Avery4] #4537337
10/08/17 05:03 PM
10/08/17 05:03 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
A good quality straight 30 wt. changed annually (assuming just occasional use) should protect it long past when other components give out. You can use more expensive or specialized multi-viscosity oils if it suits you, but a stout SAE30 will hold up well in warm climates.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: Oil for Honda GX270 pressure washer? [Re: Avery4] #4537342
10/08/17 05:12 PM
10/08/17 05:12 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
I am using valvoline vr1 10w30 syn in mine.. but I had it in the garage.
Re: Oil for Honda GX270 pressure washer? [Re: Avery4] #4537394
10/08/17 06:19 PM
10/08/17 06:19 PM
New England
NibbanaBanana Offline
New England
I have the Honda GX340 engine on my two wheel tractor. Bought about 7 years ago IIRC. The manual says 5w-30 or 10w-30 depending on temperatures. I assume it would be the same for the GX270. You live in a hot climate so use 10w-30. I use M1 personally.
1993 Ford E350 5.8L, 68K
2002 Ford E150 4.2L, 85K
2006 Chevy Aveo 1.6L 215K
2013 Kia Reo 1.4L, 101K
7500 OCI, M1 5-30 winter, M1 10-30 summer
Re: Oil for Honda GX270 pressure washer? [Re: Avery4] #4537475
10/08/17 08:06 PM
10/08/17 08:06 PM
Richmond, BC, Canada
mechjames Offline
mechjames  Offline
10w30 in engine, sae30 ND (non detergent) in pump
86 Mustang 5.0L 170km - Amsoil XL 5w30 / Baldwin B2-HPG
14 Ram 1500 5.7 - Amsoil XL 5w20 / Baldwin B7443
98 Jeep ZJ 5.9 - Amsoil OE 10w30 / Baldwin B34
Re: Oil for Honda GX270 pressure washer? [Re: mechjames] #4537497
10/08/17 08:35 PM
10/08/17 08:35 PM
USA
Avery4 Offline OP
Avery4  Offline OP
USA
Why non detergent oil for the pump?
Re: Oil for Honda GX270 pressure washer? [Re: Avery4] #4537503
10/08/17 08:38 PM
10/08/17 08:38 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
I like SAE30 or 15W40 for that application. Synthetic 10W30 is also good.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: Oil for Honda GX270 pressure washer? [Re: Avery4] #4537507
10/08/17 08:41 PM
10/08/17 08:41 PM
Northeast
Finz Offline
Finz  Offline
Northeast
Personally, I'd use an SAE30... Supertech would be my choice. Just make sure to keep it topped up and perform routine OCIs and it should run for years and years
God Bless America
Re: Oil for Honda GX270 pressure washer? [Re: Avery4] #4537685
10/09/17 06:49 AM
10/09/17 06:49 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
Use any quality oil with a high HTHS. The oil viscosity under very high temps is important in air cooled engines. That's why straight 30 is a good suggestion. Other oils with a high HTHS include 10W-40 M1 HM, 10W-40 M1 motorcycle (a superb oil) , 5W-40 M1 TDT, 15W-50 M1 and so on.
Re: Oil for Honda GX270 pressure washer? [Re: Avery4] #4537769
10/09/17 08:49 AM
10/09/17 08:49 AM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Id put 10w-30 synthetic in it (Amsoil ACD is the best), or else a 30wt.
Re: Oil for Honda GX270 pressure washer? [Re: Avery4] #4537888
10/09/17 11:08 AM
10/09/17 11:08 AM
MB - Manitoba
FastLane Offline
FastLane  Offline
MB - Manitoba
I use M1 10W30 in my 2800 psi Honda powered pressure washer.
2010 Silverado 4.8 4x4 Mobil 1 5W30 ACDelco PF48E
2002 Mustang GT 4.6 Mobil 1 5W30 MC FL-820S
1966 Cessna 150 Phillips 20W50
2013 Mercury 30hp Mystic 25W40
