Mixing oils
by bfleeman. 12/15/18 10:51 AM
Ebay 10% off Tech 15% off everything else*.
by demarpaint. 12/15/18 10:39 AM
Milwaukee Fuel M12 Ratchet 1/4” vs 3/8”
by Snagglefoot. 12/15/18 10:16 AM
Hifly Hf 805
by chrisri. 12/15/18 10:00 AM
Preferred 5.3L L83 Oil Filter
by zfasts03. 12/15/18 09:58 AM
sonata plastic fork starter failed three times.
by JustinH. 12/15/18 09:17 AM
HVAC Problems
by WTJackalope. 12/15/18 09:15 AM
Rough Idle after short trip
by Datarock. 12/15/18 09:07 AM
Homelite 360
by mobilaltima. 12/15/18 09:04 AM
Lovin' the Etec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Spkrdctr, torchredone12, JNG, Edmundo, NEKGuy
66688 Registered Users
80 registered members (93cruiser, bbhero, 77GrandPrix, 53' Stude, 4WD, andrewp1998, 9 invisible), 2,179 guests, and 38 spiders.
Topics295,106
Posts4,927,928
Members66,688
Most Online2,553
Oct 27th, 2018
Fleetguard LF3947 CUT OPEN #4536977
10/08/17 09:21 AM
10/08/17 09:21 AM
NJ
italian68 Offline OP
NJ
i thought the lf3947 was supposed to be a stratapore filter. it does not say stratapore anywhere on it and it does not look like a stratapore element. different line of filter from fleetguard or possible fake?
07 BMW 530i 50k Castrol Edge 0w40 Mann
06 Ram 2500 5.7 109k QSUD 5w30 51515
05 Camry 2.4 112k QSUD 5w20 51516
Re: Fleetguard LF3947 CUT OPEN [Re: italian68] #4536995
10/08/17 09:34 AM
10/08/17 09:34 AM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
Looks fine. How many miles and what kind of oil? Off your Ram 2500?
2004 Corolla 126813
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74478
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Fleetguard LF3947 CUT OPEN [Re: italian68] #4537002
10/08/17 09:39 AM
10/08/17 09:39 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
All signs point to a Champ Labs made filter. Champ thread end bypass design used on many M1 and FoMoCo 'factory filters'. Champ uses louvered centertube too and what I can see of yellow date code looks like Champ Labs too. Same adbv design and leaf spring design used on some Champ Labs made filters like the FoMoCo factory filters. And the stamped M on baseplate is found on some Champ made filters like STP blue.
FoMoCo Factory Filter
Can't tell you if 'all' Fleetguard are supposed to be stratapore, but apparently this one isn't. Given the choice, don't think it's fake, just a different line.
Looks like it got the job done.
Re: Fleetguard LF3947 CUT OPEN [Re: italian68] #4537245
10/08/17 01:41 PM
10/08/17 01:41 PM
NJ
NJ
2006 ram 2500. 3k mi. run on supertech 5synthetic 5w30
Doesn't seem like it caught nearly the amount of dirt as my last run with wix 51515 did
Re: Fleetguard LF3947 CUT OPEN [Re: italian68] #4537374
10/08/17 04:50 PM
10/08/17 04:50 PM
Wet side WA
Wet side WA
That's a pretty short OCI for Synthetic if you last OCI was also Synthetic you may have already clean a lot of junk out of your engine. Were both those OCI's the same duration or close?
2004 Corolla 126813
2006 Duramax 74478
Re: Fleetguard LF3947 CUT OPEN [Re: italian68] #4537408
10/08/17 05:47 PM
10/08/17 05:47 PM
Michigan, USA
Bighorn2500 Offline
Bighorn2500  Offline
Michigan, USA
Definitely looks different than the strapore application for the Cummins diesel, Ive cut mine open and the spring was coiled not the leaf spring type.
2012 Ram 2500 SLT 6.7L Cummins 4x4
2015 Jeep Cherokee 3.2L Latitude 4x4
Re: Fleetguard LF3947 CUT OPEN [Re: italian68] #4537426
10/08/17 06:04 PM
10/08/17 06:04 PM
Bad Axe, MI
daman Offline
daman  Offline
Bad Axe, MI
A stratapore filter will say "stratapore".. on the filter
"Always"....Mobil 1
Current fill: AFE 0w30
Re: Fleetguard LF3947 CUT OPEN [Re: italian68] #4537583
10/08/17 09:40 PM
10/08/17 09:40 PM
NJ
NJ
yes 3k run on both. pp 5w20 the oci before last
Re: Fleetguard LF3947 CUT OPEN [Re: italian68] #4537683
10/09/17 05:45 AM
10/09/17 05:45 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
While it may not be an FG Stratopore/micro glass, IMO it looks to be a well made filter. Based on this one, I'd have no concerns about running one, in fact I'd do so with confidence.
As for the comparative appearance of particles caught, not much science to that. Mostly subjective. And at 3k mile oci/fci about what one would expect in appearance with well maintained engine. ST Synthetic and this filter easily good for 5k+ mile ocis. Your call though.
As reference Donaldson too sells another similar to topic filter line besides it's full synthetic filter line.
Re: Fleetguard LF3947 CUT OPEN [Re: Sayjac] #4590644
12/01/17 07:19 AM
12/01/17 07:19 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
How odd.... never thought Fleetguard would sub out to Champ Labs?
Any guesses on what efficiency the filter media is?
Re: Fleetguard LF3947 CUT OPEN [Re: italian68] #4590748
12/01/17 09:11 AM
12/01/17 09:11 AM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
One giveaway is if one inlet hole is larger. Luber Finer makes a lot of Champ Labs heavy duty filters, or Champ makes them and puts Luber Finer on the can.
https://www.zoro.com/luberfiner-oil-filter-6-5164inh-3-1316india-ph299/i/G9761035/
Re: Fleetguard LF3947 CUT OPEN [Re: Linctex] #4590749
12/01/17 09:12 AM
12/01/17 09:12 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
No idea of efficiency. Perhaps an email to them might provide some information. Though reading their website seems a vague meets or exceeds oem specs.
As for the topic application being made by Champ Labs, for all the reasons listed in first post here, I'd put my confidence in the upper 90% that it is accurate. All of them have including but not limited to the stamped M on baseplate have been posted on this subforum in the past.
Edit. Seeing the added mention of LuberFiner, LF is noted as a Champ Labs filter brand on their website.
http://www.champlabs.com/brands/
Re: Fleetguard LF3947 CUT OPEN [Re: Sayjac] #4591033
12/01/17 01:22 PM
12/01/17 01:22 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Yes, that is established.
But........... this is a FleetGuard -
a filter that typically costs a bit more than Luber Finer and is supposed to have media similar (or identical to) the Donaldson Synteq media.
Re: Fleetguard LF3947 CUT OPEN [Re: daman] #4591037
12/01/17 01:26 PM
12/01/17 01:26 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Yes..... but these are supposed to be "Microglass" media, not paper.
It does make a difference when you think you are paying extra for Synteq media, but get paper instead.
