Homelite 5000 Generator (6500 running)with a Subaru Robin motor won't start. Last time I did start it was in CT before selling my house up there in Northeast a year ago. Now in NC, I did everything I could, clean carbu, change spark, change oil, I did spray a little starting fluid inside the choke and is trying but...... I read this generator motor has a sensor for the low oil, so I would like to bypass it and get the motor running. The reason I dont take it to the shop ( here in the Triad ) is [censored] heavy and I dont really use it a lot, but I ve been working in updating my lawnmowing equipment since I have a lot of green to cut. Thank you for you time.
