New Fram air filter?
by irv. 09/20/18 09:15 AM
Any golf cart experts?
by HawkeyeScott. 09/20/18 09:15 AM
EU Subaru 2.5 FB engine oil
by IMPALA08. 09/20/18 08:16 AM
02 Focus head replacement
by Eric Smith. 09/20/18 08:08 AM
A5/B5 or A3/B3
by ka9mnx. 09/20/18 07:53 AM
2018 Mazda 3 2.5 Castrol or Mazda Moly
by mazdamonky. 09/20/18 07:44 AM
What fuel are you running?
by Matagonka. 09/20/18 07:25 AM
Be careful what you wish for...
by Shannow. 09/20/18 04:40 AM
Debating repowering my tower.
by Colt45ws. 09/20/18 01:10 AM
Oil filter for GM 8.1l V8?
by KenO. 09/19/18 11:10 PM
Help! No high beam
by wolf_06. 09/19/18 11:02 PM
Heading for divorce
by barkingspider. 09/19/18 11:02 PM
Oil recommendation: 1991 Nissan D21 truck
by RDY4WAR. 09/19/18 10:04 PM
Cold starting and CCS etc.
by CT8. 09/19/18 10:03 PM
Whine->Dead car(electrical)
by madRiver. 09/19/18 09:59 PM
Differential Allen Drain Bolt Buggered
by Gebo. 09/19/18 09:41 PM
Pick my oil. 25k miles a year
by Serge. 09/19/18 09:41 PM
Ok to use in Kubota? Pennsoil 0w-40
by racinjason. 09/19/18 09:35 PM
Road Hugger GTP A/S Tires
by Bud_One. 09/19/18 09:16 PM
Gravity Bleeding Clutch?hel
by Spetz. 09/19/18 09:10 PM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
86 registered members (Ablebody, beanoil, BAJA_05, ABomb369, 10 invisible), 1,518 guests, and 42 spiders.
Topics290,706
Posts4,848,658
Members66,021
Most Online3,590
Jan 24th, 2017
Homelite 5000 Generator puzzle #4536914
10/08/17 09:14 AM
10/08/17 09:14 AM
Stokesdale, NC
lebrimal Offline OP
lebrimal  Offline OP
Stokesdale, NC
Homelite 5000 Generator (6500 running)with a Subaru Robin motor won't start. Last time I did start it was in CT before selling my house up there in Northeast a year ago. Now in NC, I did everything I could, clean carbu, change spark, change oil, I did spray a little starting fluid inside the choke and is trying but...... I read this generator motor has a sensor for the low oil, so I would like to bypass it and get the motor running. The reason I dont take it to the shop ( here in the Triad ) is [censored] heavy and I dont really use it a lot, but I ve been working in updating my lawnmowing equipment since I have a lot of green to cut. Thank you for you time.
Honda Civic 2007
Tacoma 1996
Infinity IQ 2000
Toro Timesaver
JD J30 with Predator motor
chipper 6.5 HP
Homelite 5000 Generator (no starting)
Re: Homelite 5000 Generator puzzle [Re: lebrimal] #4536923
10/08/17 09:23 AM
10/08/17 09:23 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
Just some basics, #1 is the sparkplug getting wet with fuel and #2 is it getting a strong spark? Fresh fuel is key too.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Homelite 5000 Generator puzzle [Re: lebrimal] #4536941
10/08/17 09:39 AM
10/08/17 09:39 AM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
Carb is clogged with ethanol goo junk. You need a carburetor rebuild.
For future reference, dont store generators with fuel. I like to run a quart of non-ethanol fuel threw the tank/carb until it runs out of fuel.
That gets all the ethanol goo out of the carb and they usually start right up next time you need it.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
12 Suzuki S40 Rotella 15W40
10 Acura TSX 2.4 PZL Plat 5W30
06 GMC Sierra Nextgen 10W30
Re: Homelite 5000 Generator puzzle [Re: lebrimal] #4536956
10/08/17 09:52 AM
10/08/17 09:52 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
I always start with the basics.
1) do you have spark?
2) have you tried a different spark plug?
3) Add fuel to the intake (starting fluid) and it runs for a time?
4) Have you tried disconnecting the wires to the oil level sensor?
That's a great little engine BTW.
If in fact it runs on starting fluid, and you have the fuel valve on the bottom of the tank open, try ensuring there is fuel flow through the pump. You could also try feeding the carb with fuel via an external hose to the fuel fitting on the carb. Could be your fuel pump is dry or inop.
Re: Homelite 5000 Generator puzzle [Re: lebrimal] #4536976
10/08/17 10:20 AM
10/08/17 10:20 AM
texas
danez_yoda Offline
danez_yoda  Offline
texas
if there was old gas in the tank and it was E10 then dump the tank and change the fuel filter.
You may have gotten phase separation and that non-combustive good sink to the bottom to get picked up by the pickup tube. The first think hit with it is the fuel filter. After that it is the carb.
Re: Homelite 5000 Generator puzzle [Re: lebrimal] #4536985
10/08/17 10:24 AM
10/08/17 10:24 AM
ME
eljefino Offline
eljefino  Offline
ME
Does this have an Automatic Voltage Regulating circuit that can kill the spark? I feel since it won't even sputter on starting fluid you have a safety switch shutting things down. AVR should bypass to let it get going but you never know. Trace all the stuff back to the "kill wire", it should all be teed in together there.
Re: Homelite 5000 Generator puzzle [Re: lebrimal] #4537026
10/08/17 11:17 AM
10/08/17 11:17 AM
Central Wisconsin
dwendt44 Offline
dwendt44  Offline
Central Wisconsin
Clean oil level sensor if possible, could be mucked up.
Run a little high on oil level won't hurt if test running.
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: Homelite 5000 Generator puzzle [Re: lebrimal] #4537074
10/08/17 11:58 AM
10/08/17 11:58 AM
Canada
i_hate_autofraud Offline
Canada
Be sure your spark plug gap is not over spec, in my case I gap plugs .003" tighter, improves starts.
Re: Homelite 5000 Generator puzzle [Re: lebrimal] #4537109
10/08/17 12:38 PM
10/08/17 12:38 PM
MI
joeparker54 Offline
joeparker54  Offline
MI
Oil level sensor is just a basic on/off float switch on most small engines (uses a magnet in float - when it drops low enough, the magnet triggers a reed switch that opens up and disconnects negative/ground to spark. Try disconnecting it, or short across connector with a jumper (if it's a single wire, tie the wire that plugs into the switch (not the one ATTACHED to the switch) to ground. Otherwise, if you have a multimeter than you can confirm that the main kill switch and oil switch are working properly - anything more than about 2 ohms (ideally 0) of resistance and they should be replaced. oil level sensors usually don't need to be cleaned (at least not the magnetic type) - I've only ever seen one get gummed up on an engine that was THOROUGHLY abused - over 100 hours of almost constant runtime.
Otherwise, don't be so quick to assume that your carb is dead/gummed up like some others here have. There's a million and one problems that can cause a no-start solution, but the first and easiest to identify is ignition/spark.
Re: Homelite 5000 Generator puzzle [Re: lebrimal] #4537111
10/08/17 12:40 PM
10/08/17 12:40 PM
USA
mk378 Offline
mk378  Offline
USA
You have to do a basic fuel vs spark diagnosis first. If you don't have starting fluid put a few drops of gas in the intake and pull the cord to see if it will fire at all. If it does fire, the problem is going to be that the carb is clogged up. This is by far the most common reason for not starting after a period of storage.
If no spark, look for a small electrical wire coming from the coil (which is under the flywheel cover). This is the so-called "kill wire". If the wire is left open circuit, the engine can run. If anything connects it to ground, the engine will stop. Thus you can bypass all the potential stopping systems by disconnecting the wire from any switches, sensors, etc. and making sure it doesn't ground out.
Re: Homelite 5000 Generator puzzle [Re: Cujet] #4538897
10/10/17 09:46 AM
10/10/17 09:46 AM
Canada
boraticus Offline
boraticus  Offline
Canada
Excellent diagnosis list.
I had a spark plug once that would spark outside of the cylinder but wouldn't work installed. Always have a known working spare plug.
If the engine has a good plug and the low oil shut off is functioning properly with proper oil level, the carb likely needs a thorough cleaning.
Far too often people fail to completely clean jets and galleries in carbs. I've done it myself. As much as it's often disparaged, using a very thin flexible wire is often a must to properly clean jets, galleries and orifices.
I like to strip the paper/plastic from garbage bag ties and use the wire to clean carbs. The wire is very thin and will take a lot of bending before it will break. The last thing you want is to break off a piece of wire in a bad spot.
