First Paint Correction
by RayCJ. 09/23/18 08:33 PM
2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
Counterfeit MANN filter???
by IllinoisSparky. 09/23/18 06:54 PM
The smell of an oil: VME adds?
by fdcg27. 09/23/18 06:48 PM
Classic road brake pads
by buck91. 09/23/18 06:18 PM
Air up your vehicle's tires
by Papa Bear. 09/23/18 06:07 PM
A cool litttle Fall foliage site
by Papa Bear. 09/23/18 06:02 PM
Suggestion: "Likes"
by SnowDrifter. 09/23/18 05:36 PM
Condensation in headlights?
by irv. 09/23/18 05:06 PM
Nissan VQ V-6 Engines
by Al. 09/23/18 04:57 PM
List of dexos licensed oils?
by k1xv. 09/23/18 04:24 PM
High flow oil pump? Thinner oil?
by SnowDrifter. 09/23/18 04:06 PM
Is Tiger back?
by gman2304. 09/23/18 03:51 PM
Castrol Edge Pro OE LLIV FE 0W20 for VW508
by BrandonT. 09/23/18 03:33 PM
Value of 90's stereo equipment
by wrcsixeight. 09/23/18 03:28 PM
Wisdom of BITOG'ers wanted- 19 Avalon Hybrid oil
by scion_xb. 09/23/18 02:36 PM
Lilshady, SevenDu, sigpro, RayCJ, yellow97tt6spd
66055 Registered Users
99 registered members (alphadog, 1.8Tango, Ablebody, 77GrandPrix, 92saturnsl2, 93cruiser, 12 invisible), 1,654 guests, and 36 spiders.
Topics290,914
Posts4,852,404
Members66,055
Most Online3,590
Jan 24th, 2017
Weather Stripping Adhesive Failure #4536911
10/08/17 09:11 AM
10/08/17 09:11 AM
FL, USA
shurguywutt Offline OP
FL, USA
I have a painted steel frame/door on my garage that has some gaps in it that allows rain inside. I have cleaned the frame and applied the weatherstripping (foam) but it keeps coming off. Is there a trick to this? I have even superglued it in certain areas where it was peeling off but it still keeps sticking to the door then peeling off when opening. Thanks for any tips.
2008 Pilot 2WD J35Z1 148k
Maxlife Blend 10w-30
FRAM Ultra Synthetic
Fumoto F106SX
Re: Weather Stripping Adhesive Failure [Re: shurguywutt] #4536961
10/08/17 10:03 AM
10/08/17 10:03 AM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Is this on the bottom of the door? Pictures would help.
Re: Weather Stripping Adhesive Failure [Re: shurguywutt] #4537108
10/08/17 12:37 PM
10/08/17 12:37 PM
FL, USA
FL, USA
No, its adhered to the doorstop around the door but the problem is that it keeps sticking to the door when I open it.
Fumoto F106SX
Re: Weather Stripping Adhesive Failure [Re: shurguywutt] #4537125
10/08/17 12:54 PM
10/08/17 12:54 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
If it's the yellow 3M stuff, they want you do let one side dry and then apply a second coat before assembly.
Re: Weather Stripping Adhesive Failure [Re: shurguywutt] #4537210
10/08/17 02:07 PM
10/08/17 02:07 PM
USA
ArcticDriver Offline
USA
Did you paint the door recently?
Sounds like the paint is dry but still a little tacky when pressed firmly against the foam and this bond becomes stronger than the adhesive.
So e paints can take a month to really dry. You could expedite with a blow dryer.
Multiple Diesel and Gasoline vehicles
Re: Weather Stripping Adhesive Failure [Re: shurguywutt] #4537212
10/08/17 02:08 PM
10/08/17 02:08 PM
USA
USA
Much better adhesives than Super Glue.
The only thing that stuff should be used for is a suture.
Re: Weather Stripping Adhesive Failure [Re: shurguywutt] #4537813
10/09/17 10:06 AM
10/09/17 10:06 AM
FL, USA
FL, USA
Thanks for the replies. The door has been painted for months so I don't think the issue is the paint. Maybe it is the actual weatherstripping, I am using a foam weatherstripping that seems to stick to the door more than the actual adhesive sticks to the doorstop. I have sprayed the nonadhesive side with silicone lubricant spray which seems to help but dries up after a while and it continues to stick after. Maybe I need to get a rubber weatherstripping. What other adhesives can I use that are better than superglue for this application? Thanks.
Fumoto F106SX
Re: Weather Stripping Adhesive Failure [Re: shurguywutt] #4537992
10/09/17 12:52 PM
10/09/17 12:52 PM
USA
USA
Which side is the adhesive stuck to? The door?
I have used this product in the past but I always stick it to the door frame/jamb.
Re: Weather Stripping Adhesive Failure [Re: shurguywutt] #4538516
10/09/17 09:01 PM
10/09/17 09:01 PM
FL, USA
FL, USA
Adhesive side is stuck to the doorstop on the door frame.
Fumoto F106SX
