Originally Posted By: dslofti
Anyone use the cleaner wax they have ?
I used to use the cleaner/wax. But the deal is once you do a polish, the surface is so smooth, the wax goes on so smoothly and quickly it is hardly a bother. So it’s not twice as hard/long to do separate steps. More like 1.4 times the effort. And the results are much better and longer lasting.
Even when I used to do it by hand, I preferred at least the two step to one combined cleaner/wax.
I have discovered plumber’s putty makes an excellent medium clay. If you are hesitant to try clay because of cost or tracking some down, just try that. You will be surprised how easy it is, and then how easy it makes the next steps (presuming you need that level of prep).
