Tire leaking from bead/rim
by Brybo86. 09/25/18 09:39 AM
2000 4Runner 3.4L
by ka9mnx. 09/25/18 08:59 AM
VW 508 Spec 0w20 Updates?
by Zee09. 09/25/18 08:36 AM
Laptop Recommendations
by buster. 09/25/18 08:24 AM
Mac OSX Mojave - vid card requirements
by OVERKILL. 09/25/18 08:05 AM
Age of first drive
by madRiver. 09/25/18 08:02 AM
Please, maintain your tires properly
by 53' Stude. 09/25/18 06:58 AM
Cycling health
by CourierDriver. 09/25/18 06:08 AM
Stupidest thing you've ever done (or not done)
by Speak2Mountain. 09/25/18 06:01 AM
First Time Hyundai Owner - Coolant Confusion
by tony1679. 09/25/18 05:16 AM
European Formula: Supertech and Mobil 1
by Snagglefoot. 09/25/18 02:19 AM
KFE brake pads?
by deoxy4. 09/25/18 01:16 AM
GM Marine Engine wont start
by Gito. 09/24/18 11:59 PM
New TV bad picture some channels part2
by raaizin. 09/24/18 10:46 PM
Another Bad PCM on a Buick 3.8L!
by clinebarger. 09/24/18 10:17 PM
Funny pictures thread
by JLTD. 09/24/18 08:40 PM
Redline 15w40: Low or Mid Saps?
by SavagePatch. 09/24/18 06:59 PM
fortim, albert001, LG_Electronics, TCam, OzFrog
66063 Registered Users
89 registered members (4WD, BAJA_05, ArrestMeRedZ, Bailes1992, 10 invisible), 1,696 guests, and 33 spiders.
Topics290,982
Posts4,853,750
Members66,063
Most Online3,590
Jan 24th, 2017
Limiting power steering assist? #4536652
10/07/17 11:12 PM
10/07/17 11:12 PM
Australia
Spetz Offline OP
Spetz  Offline OP
Australia
Hi everyone,
Is there a way to limit the level of assist power steering provides?
I saw some people limiting the amount of PS fluid going into the pump for this but I am not sure if this may cause problems in the long run?
What would happen if some of those fins from inside the pump were removed?
2003 Mitsubishi Diamante 6G74 3.5L. 5 Speed auto. 155,000 miles. Shell Helix Ultra 5W40 at 6k OCI
Re: Limiting power steering assist? [Re: Spetz] #4536659
10/07/17 11:22 PM
10/07/17 11:22 PM
Chicago, IL
dparm Offline
dparm  Offline
Chicago, IL
Depending on the car, it might be changeable via software.
2017 Chevrolet Corvette Grand Sport
Re: Limiting power steering assist? [Re: Spetz] #4536675
10/07/17 11:39 PM
10/07/17 11:39 PM
Australia
Spetz Offline OP
Spetz  Offline OP
Australia
It's for an old car. Definitely not configurable via software
Re: Limiting power steering assist? [Re: Spetz] #4536681
10/07/17 11:47 PM
10/07/17 11:47 PM
CA
CharlieBauer Offline
CA
If you want the steering to feel heavier, then you could reduce the tire pressure.
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Re: Limiting power steering assist? [Re: Spetz] #4536687
10/07/17 11:51 PM
10/07/17 11:51 PM
New Zealand
Silk Offline
Silk  Offline
New Zealand
Old Hondas used to have a control valve on the gearbox, they had less power assist at road speed, more for parking.
1987 BMW R65 - Penrite V Twin 20/50
2005 Nissan Expert - Gulf Western 10W-40
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: Limiting power steering assist? [Re: Spetz] #4536825
10/08/17 07:07 AM
10/08/17 07:07 AM
Colorado
Kuato Offline
Kuato  Offline
Colorado
Reducing the amount of fluid in the ps system will cause problems eventually, the same as any hydraulic system with insufficient fluid.
IMO you'd need a different pump with a lower pressure output.
Removing fins would reduce volume as well as pressure so not a good option.
Thick vs Thin test: 15k / 43k miles complete
Re: Limiting power steering assist? [Re: Spetz] #4536863
10/08/17 08:15 AM
10/08/17 08:15 AM
New England
555 Offline
555  Offline
New England
Complete conjecture here, you've been warned.
What about a pulley for the PS pump that slows the pump down? You would have to work out the size of the pulley compared to original and keep an eye on the ratio to the crank pulley. This could in theory make your steering feel less light but could also affect how quickly the PS system recovers from left to right turning motions.
84 XJ6 M1
92 Mustang 5.0 Redline
99 Tahoe 2 door Castrol Edge
99 MX5 Miata Anniversary Edition M1
04 Subaru STi Motul
Re: Limiting power steering assist? [Re: Spetz] #4536872
10/08/17 08:30 AM
10/08/17 08:30 AM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
Originally Posted By: Spetz
Hi everyone,
I have done this to tracked cars in the past. It can help with the system overheating and can improve the "feel", just remember that it is a mirage. It's really just heavier.
Where it seems risky to me is on the street. If you need a QUICK transient there may be no power assist and it will feel like you hit a wall.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: Limiting power steering assist? [Re: Spetz] #4536892
10/08/17 08:50 AM
10/08/17 08:50 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
Is there a pressure sensor in the system?
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Limiting power steering assist? [Re: Spetz] #4536894
10/08/17 08:52 AM
10/08/17 08:52 AM
ME
eljefino Offline
eljefino  Offline
ME
Hydraulic power steering spends most of its time in bypass. It has to be strong enough to let you parallel park at idle. If you reduce the pump output it'll be terrible at idle and not much different at speed.
If you want "better road feel" look elsewhere.
How do we know this clunker doesn't have bad, loose ball joints etc?
Re: Limiting power steering assist? [Re: Spetz] #4538276
10/09/17 04:51 PM
10/09/17 04:51 PM
Indiana, USA
Smoqueed Offline
Smoqueed  Offline
Indiana, USA
WHAT? That's terrifying. Sounds like how to cause PS pump failure 101.
Re: Limiting power steering assist? [Re: Spetz] #4538956
10/10/17 10:47 AM
10/10/17 10:47 AM
KY
MCompact Online content
MCompact  Online Content
KY
On older GM recirculating ball PS systems you could adjust the assist level by changing the spool valve. On modern EPS systems it can only be adjusted via software.
Mine:
2014 M235i
1999 Wrangler Sahara
1995 318ti Club Sport
Wife's:
2009 Cooper Clubman
Son's
2009 328i
Buy what makes you smile...
Re: Limiting power steering assist? [Re: Spetz] #4538972
10/10/17 11:01 AM
10/10/17 11:01 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
I had a set up on my '97 Taurus SHO that would kill the PS sensor at WOT. It would reduce the variable assist. The older SHOs had a stepper motor that would change with speed. Many would get it to the level off assist (by speed) they wanted and kill it there providing a stiffer steering all the time.
Re: Limiting power steering assist? [Re: Spetz] #4539839
10/11/17 07:12 AM
10/11/17 07:12 AM
Southeast
meep Online content
meep  Online Content
Southeast
ditto spool valve. or changing the torsion bar inside the spool valve. I have a feeling it's a part which can be sourced with enough research.
2018 F150
2015 crv (wifey!)
Re: Limiting power steering assist? [Re: 555] #4541013
10/12/17 09:06 AM
10/12/17 09:06 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
I would think you would want more assist parking than at speed . Therefore , changing the pully size would seem to reduce pressure when the engine id rotating slowly and tou need it most ?
Wyr
God bless
Wyr
God bless
