Oil filter for GM 8.1l V8?
by KenO. 09/19/18 11:10 PM
Help! No high beam
by wolf_06. 09/19/18 11:02 PM
Heading for divorce
by barkingspider. 09/19/18 11:02 PM
Oil recommendation: 1991 Nissan D21 truck
by RDY4WAR. 09/19/18 10:04 PM
Cold starting and CCS etc.
by CT8. 09/19/18 10:03 PM
Whine->Dead car(electrical)
by madRiver. 09/19/18 09:59 PM
Differential Allen Drain Bolt Buggered
by Gebo. 09/19/18 09:41 PM
Pick my oil. 25k miles a year
by Serge. 09/19/18 09:41 PM
Ok to use in Kubota? Pennsoil 0w-40
by racinjason. 09/19/18 09:35 PM
Road Hugger GTP A/S Tires
by Bud_One. 09/19/18 09:16 PM
Gravity Bleeding Clutch?hel
by Spetz. 09/19/18 09:10 PM
Drunken Watch?
by StevieC. 09/19/18 09:01 PM
New Forum Member New Truck Owner
by FarmerDude. 09/19/18 08:35 PM
Valvoline DOT 3/4?
by DJ. 09/19/18 08:22 PM
Best grease for AWD actuator disconnect?
by Bman90. 09/19/18 08:14 PM
Reconditioning a 2-Stroke Snow Blower
by Finz. 09/19/18 07:55 PM
Liquimoly Anti Friction - $6.83 Shipped/ Can
by ad244. 09/19/18 06:57 PM
ACEA spec for old Toyota??
by alexmarjanovic98. 09/19/18 06:54 PM
3.5EB Gen II: Oil & Interval
by Gene K. 09/19/18 06:09 PM
Are there any cable techs here?
by Reddy45. 09/19/18 06:02 PM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
43 registered members (Astro14, AdRock, Ablebody, Abax25, ArrestMeRedZ, 3 invisible), 776 guests, and 38 spiders.
Topics290,696
Posts4,848,430
Members66,021
Most Online3,590
Jan 24th, 2017
The best "UNIVERSAL" catalytic converter???? #4536592
10/07/17 10:01 PM
10/07/17 10:01 PM
USA
crazy_raccoon Offline OP
USA
I figure you guys could help me out on this one. I'm on the market for a very good universal catalytic converter that I could weld to a custom mid-pipe I plan on getting made and would like to pass emissions. Piping will be 2.25" in the custom mid-pipe. Even though I will be in an emission free county I would still like to pass. I recently installed a aftermarket header that removes my primary cat on my '07 Scion TC and I'm still currently running my OEM mid-pipe with the secondary cat on there. I do get that go-kart smell when I'm in idle though.
I'm curious if there are aftermarket cats that actually lasted a long time and of are good quality? Feed back from your experiences would be highly appreciated.
'07 Scion tc
- 98K miles
- Valvoline FS w/ML 0W-20 D1G2
- FRAM Ultra
'07 Honda Accord coupe 4cyl
- 128K miles
- FRAM TG
Re: The best "UNIVERSAL" catalytic converter???? [Re: crazy_raccoon] #4536632
10/07/17 10:47 PM
10/07/17 10:47 PM
Birmingham, AL
01rangerxl Offline
01rangerxl  Offline
Birmingham, AL
I installed a Walker direct fit y-pipe with 2 converters on my '02 Ranger somewhere around 4 years/60K miles ago and it's still doing good. I have used other Walker and Dynomax parts and have nothing but good to say about them.
2002 Ford Ranger XLT | 3.0 V6 / 5-Speed Automatic / 2WD | 216K miles
1994 Ford Ranger STX | 4.0 V6 / 5-Speed Manual / 4X4 | 199K miles
Re: The best "UNIVERSAL" catalytic converter???? [Re: crazy_raccoon] #4536642
10/07/17 11:01 PM
10/07/17 11:01 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
If you cared about the environment or the air you and your neighbors breathe, you wouldn't have taken it out.
The problem with aftermarket cats is that they don't have to meet the same warranty requirements as OEM. The manufacturers have to make their cats last 8/80k under federal emissions warranty and they're designed to last at least that long and usually much longer if properly maintained. To do that, there's a lot more material in the converter which makes it more expensive. No aftermarket convert is going to meet the same standard because it's going to cost a lot more and by the time you hit the aftermarket, the owners are looking for something cheap. That's why they typically only have a 25k warranty on the converter and a 50k warranty for structural integrity. The EPA figures that by the time the 2nd one really goes, that's going to be about it for the car.
Re: The best "UNIVERSAL" catalytic converter???? [Re: Wolf359] #4536708
10/08/17 12:22 AM
10/08/17 12:22 AM
Cali
Malo83 Offline
Malo83  Offline
Cali
I have a Magnaflow 3" HiFlow cat on my 83 Silverado that I have been running for 10 yrs now, driving in Cali I have to do smog tests every 2 yrs, no failed tests yet. thumbsup
Re: The best "UNIVERSAL" catalytic converter???? [Re: crazy_raccoon] #4536726
10/08/17 12:56 AM
10/08/17 12:56 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
You don't say where you live but if you're in CA like me, the number on the converter must match the number on the hood sticker. Getting a universal will not pass.
Re: The best "UNIVERSAL" catalytic converter???? [Re: crazy_raccoon] #4536896
10/08/17 08:55 AM
10/08/17 08:55 AM
ME
eljefino Offline
eljefino  Offline
ME
If it doesn't get hot enough it won't work. IDK if a 2.25" pipe will flow "too well" for it to get hot, but coupled with distance from the engine, that could be your issue.
If your rear o2 sensor is in front of the rear cat (like my camry) a spark plug anti fouler will take care of the light.
Re: The best "UNIVERSAL" catalytic converter???? [Re: eljefino] #4537068
10/08/17 11:55 AM
10/08/17 11:55 AM
USA
USA
I was wondering about the heat issue as well for it to perform correctly. The rear O2 sensor is mounted on the pipe about a foot away from the secondary cat. I already have a CEL 90 degree elbow eliminator where the rear O2 sensor mounts so the CEL is not activated. I just wasn't sure if there is a universal cat that would be good for my setup I'm going for.
'07 Scion tc
- 98K miles
- FRAM Ultra
- 128K miles
- FRAM TG
Re: The best "UNIVERSAL" catalytic converter???? [Re: crazy_raccoon] #4537999
10/09/17 12:58 PM
10/09/17 12:58 PM
California
nthach Offline
nthach  Offline
California
Unless you get a CARB-compliant cat - and Ozone Transport Commission states that follow most of CARB's regulations also mandate them for aftermarket replacement on newer cars no aftermarket cat will last as long as OEM. Federal cats don't have as much precious metal loading or construction as the CA units do.
Since you're in a non-emissions area, you can get high-flow metal matrix cats from Flowmaster and Magnaflow. I'd just get an appropriately-sized cat. I used Walker and that helped me pass smog but killed performance. If I had to do it again, Magnaflow.
Re: The best "UNIVERSAL" catalytic converter???? [Re: crazy_raccoon] #4538817
10/10/17 08:13 AM
10/10/17 08:13 AM
NJ
UG_Passat Offline
UG_Passat  Offline
NJ
HJS is the best, but you also pay for it, as they are quite expensive
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: The best "UNIVERSAL" catalytic converter???? [Re: crazy_raccoon] #4538946
10/10/17 10:35 AM
10/10/17 10:35 AM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
I have Walker cats on my Jeep, and they have been on for 50,000+ miles without issue.
2000 Jeep Cherokee 4.0L (180k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (33k) - Castrol Edge Euro 0w40, MANN HU816X
Re: The best "UNIVERSAL" catalytic converter???? [Re: crazy_raccoon] #4540591
10/11/17 08:03 PM
10/11/17 08:03 PM
USA
USA
I'm leaning towards a direct fit magnaflow cat but I've read that the California cats they offer are loaded with more metals to curb even more emissions . Not sure if you can get one for a non California vehicle? Anyways, I'm still on the hunt for a decent cat.
'07 Scion tc
- 98K miles
- FRAM Ultra
- 128K miles
- FRAM TG
Re: The best "UNIVERSAL" catalytic converter???? [Re: crazy_raccoon] #4540789
10/11/17 11:19 PM
10/11/17 11:19 PM
Birmingham, AL
01rangerxl Offline
01rangerxl  Offline
Birmingham, AL
I think Magnaflow makes quality products, but doesn't do as much test fitting as Walker in some cases. I initially bought a direct fit Magnaflow for my Ranger, but it would not clear the shift cable. I contacted them about it and they said they had other complaints about fitment on FFV 3.0 Rangers...all of which are automatics. All of the non-FFV 3.0s that year were manuals. I suspect it was only ever tested for fitment on a manual trans truck. I returned it for the Walker, which fit perfectly. Not mandrel bent like the Magnaflow, but it fits. I bought a Dynomax (Walker) cat-back exhaust system for another Ranger I had and it also fit perfectly, along with a few Walker direct fit converters for various GM cars and trucks (GMT800s, W-bodies, etc.) I have bought for customer cars...never a problem.
Re: The best "UNIVERSAL" catalytic converter???? [Re: crazy_raccoon] #4541133
10/12/17 12:12 PM
10/12/17 12:12 PM
California
nthach Offline
nthach  Offline
California
If you know the part number, you can order it off RockAuto or Amazon.
In NY, you can get get CARB cats as they are mandated for newer cars with 50-state emissions.
