VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
duradick, Harold1031, Skendread, NGK, Thomas1
67589 Registered Users
30 registered members (4WD, A1O, antik, billt460, bfleeman, ctechbob, 4 invisible), 497 guests, and 57 spiders.
Topics286,267
Posts4,905,521
Members67,589
Most Online2,967
Mar 10th, 2019
Shortage? #4536521
10/07/17 08:50 PM
10/07/17 08:50 PM
AZ
ron17571 Offline OP
ron17571  Offline OP
AZ
I wanted a gallon of ATF(MERCON) For my trans fluid change.Walmart had only one jug of super tech.And that was it.I get a funny vibe about the stuff.So, I went to NAPA.Only really pricey Amsoil and purple stuff there.I finally ended up at O'Reilys and picked up a gallon of Valvoline ATF. Good Luck to others wanting ATF from Walmart.
2003 Dodge Caravan 140.000 miles
1992 Ford f-250 217,000 miles
Re: Shortage? [Re: ron17571] #4536528
10/07/17 08:55 PM
10/07/17 08:55 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
My local WM hasn't had anything except Supertech ATF the last 9+
months, either. My local Napa (where I get all the parts I can, anyway) keeps a good selection of their ATF's on hand so I just buy their stuff when I can, but if they're out or I want something a little better O'Reilly's has regularly had VML ATF in stock... and they'll price match to Wally World. laugh
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: Shortage? [Re: ron17571] #4536553
10/07/17 09:20 PM
10/07/17 09:20 PM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
Why the 'funny vibe'? Whoever makes ATF for Walmart is plenty fine for pretty much any car they spec for.
Re: Shortage? [Re: ron17571] #4536855
10/08/17 07:59 AM
10/08/17 07:59 AM
MI
joeparker54 Offline
joeparker54  Offline
MI
Super tech ATF fluids are manufactured by large well known manufacturers like Citgo or Warren (one or both of em). Their Mercon LV is the only reasonably priced fluid I've found aside from the Ford dealership (somehow $.25/qt less). Not only is it "suitable" for use in my vehicle, it is licensed by Ford. I would trust it to more completely meet the specs of the original fluid over something like Maxlife (well - the old non LV Maxlife).
If you ever want to know who makes something for Walmart, you can punch the UPC into their MSDS site.
Re: Shortage? [Re: Bottom_Feeder] #4536856
10/08/17 08:01 AM
10/08/17 08:01 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
Just for clarity.....All MERCON today means MERCON V, yes?
There is an LV and a "special version" of the stuff too, no?
Re: Shortage? [Re: ron17571] #4536877
10/08/17 08:37 AM
10/08/17 08:37 AM
Fairfax, VA
TinyVoices Offline
TinyVoices  Offline
Fairfax, VA
Never had an issue getting different varieties of ATF but trying to buy gl4 gear oil from a brick and mortar is maddening.
2010 Mazda RX8 Sport - 37k miles - ????
2006 Toyota Matrix XR AWD (Wife) - 130k miles - Valvoline Max Life 5w30
Re: Shortage? [Re: Kira] #4537063
10/08/17 11:52 AM
10/08/17 11:52 AM
MI
joeparker54 Offline
joeparker54  Offline
MI
Originally Ford said no to backwards compatibility, but then stopped making/licensing old Mercon and said V was fine to use - it's a semi-synth fluid and holds up pretty well. Just make sure you do a FULL flush to get rid of all the old fluid if changing over from Merc/Dex3.
Be aware that most of what I have seen for Mercon V is a dedicated product - some stores still sell an old Dex/Merc formulation that would require additional friction modifier additive (if you can even still find it) in certain applications. Note that MercV is not suitable for transfer cases - Ford released a new fluid just for that purpose.
LV stands for Low Viscosity - it is a full synthetic fluid and incompatible with Mercon V/Mercon.
Walmart Mercon V is great fluid at a great price ($1.50 cheaper than Ford Dealership - they sell Mercon V and LV at same price) and is licensed by Ford, not just "suitable for use". I can't remember if they carry gallons or not though - only needed 2 quarts for my P/S fluid exchange, as the trans takes LV.
Side note, I'm not really sure what Ford did in 09 to the 4R75E transmission that magically made it incompatible with MV, but I sure don't mind the extended service intervals afforded by the full synthetic LV formulation.
