Galaxy S8+ weird app when clearing storage
by KrisZ. 09/25/18 10:18 PM
Brake bleeder - cfm ?
by hallstevenson. 09/25/18 09:43 PM
18' Corolla vs 18' Elantra
by wolf_06. 09/25/18 09:41 PM
Using Tc-w3 bad for my car?
by Floydian. 09/25/18 09:25 PM
I'm going to start using type F in my gm autos
by turtlevette. 09/25/18 09:17 PM
Cleaning deceased MIL condo and found $15K cash
by Mr Nice. 09/25/18 09:12 PM
Gluten
by StevieC. 09/25/18 07:55 PM
Amazon Prime delivering inside your house
by StevieC. 09/25/18 07:49 PM
2018 MB C300 M1 0W-40 3,475 Miles
by 2015_PSD. 09/25/18 06:44 PM
02-05 Silverado frame rot
by Oildudeny. 09/25/18 06:38 PM
Aftermarket Back Up Camera
by lancerplayer. 09/25/18 06:20 PM
Service champ filter CUT OPEN
by 53' Stude. 09/25/18 05:05 PM
Pressure washer pump life just 23 hours?
by HawkeyeScott. 09/25/18 05:01 PM
STP S 10590 CUT OPEN
by 53' Stude. 09/25/18 05:00 PM
2003 BMW M5-Unknown oil 2500 mi
by Audios. 09/25/18 04:54 PM
FRAM ULTRA XG 3593A CUT OPEN
by 53' Stude. 09/25/18 04:51 PM
MG 201-7, 7,500 MILES CUT OPEN
by 53' Stude. 09/25/18 04:44 PM
MG 301-1, 10,800 miles CUT OPEN
by 53' Stude. 09/25/18 04:34 PM
Anyone regret their cordless electric OPE?
by dlundblad. 09/25/18 04:21 PM
Pat_Roberts, Peppz, Jfa02, ibsfusion, Fearcat707
66070 Registered Users
101 registered members (4WD, ABomb369, 2004tdigls, 2015_PSD, 92saturnsl2, 1991AirCooled, 10 invisible), 1,135 guests, and 40 spiders.
Topics291,021
Posts4,854,579
Members66,070
Most Online3,590
Jan 24th, 2017
Jeep Liberty, 2012 ATF and filter change #4536211
10/07/17 12:54 PM
10/07/17 12:54 PM
Charleston, SC
steve40th Offline OP
Charleston, SC
I am changing the filter and fluid in the pan. Fluid was a little less pink and a hint of tan when on the paper towel. I will put a pan on with a drain plug so I can easily change it from now on.
It uses ATF+4 fluid. Is there a synthetic version that can be used in this, or will it make no difference.
I have 83,000 miles, and supposedly an auxiliary cooler within this AC/Condensor. Not sure how Jeep makes it work, but apparently all Jeep Libertys that had towing packages got it, but all 2012's got it.
Re: Jeep Liberty, 2012 ATF and filter change [Re: steve40th] #4536223
10/07/17 01:11 PM
10/07/17 01:11 PM
MN
14Accent Offline
14Accent  Offline
MN
I believe ATF+4 is already synthetic.
Lots of manufacturers have gone to the condenser/cooler setup. The top 4-5 rows of the "condenser" are actually the ATF cooler and the rest of it is the condenser. Makes you wonder just how good a job it does on s 100+ degree day with the Freon pouring heat back into the trans cooler.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: Jeep Liberty, 2012 ATF and filter change [Re: 14Accent] #4536242
10/07/17 02:05 PM
10/07/17 02:05 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
Originally Posted By: 14Accent
I believe ATF+4 is already synthetic. Lots of manufacturers have gone to the condenser/cooler setup. The top 4-5 rows of the "condenser" are actually the ATF cooler and the rest of it is the condenser. Makes you wonder just how good a job it does on s 100+ degree day with the Freon pouring heat back into the trans cooler.
You are correct sir, ATF+4 is all synthetic. And on the cooling...yep the whole system gets to work harder in hotter temps. But I haven't heard anything about the Liberty having cooling problems like the original Cherokees.
Let us know how the job is....GF's 08 will need some fresh fluid in the spring...
Thick vs Thin test: 15k / 43k miles complete
Re: Jeep Liberty, 2012 ATF and filter change [Re: steve40th] #4536245
10/07/17 02:12 PM
10/07/17 02:12 PM
WI
HoosierJeeper Offline
WI
Libertys don't have cooling problems really.
Are you sure the trans cooler is part of the condenser? I haven't looked at a KK in awhile but the KJ era had an aux cooler that sits in front of the condenser. (early ones had one built into the radiator)
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Jeep Liberty, 2012 ATF and filter change [Re: steve40th] #4536251
10/07/17 02:18 PM
10/07/17 02:18 PM
MN
14Accent Offline
14Accent  Offline
MN
Deleted
Re: Jeep Liberty, 2012 ATF and filter change [Re: steve40th] #4536300
10/07/17 03:41 PM
10/07/17 03:41 PM
USA
slacktide_bitog Online content
slacktide_bitog  Online Content
USA
AAP has Castrol ATF+4 on sale for $5.50/qt, 2 for $11 (but you have to buy in multiples of two)
That said, all licensed ATF+4 is the same, and uses a group III base oil. Every ATF+4 that appears on Chrysler's official ATF+4 approved list uses the same group III base oil and the same Lubrizol add pack. Castrol's is licensed, and so is Walmart's store brand ATF+4
However, the best ATF to use where ATF+4 is called for is Redline C+. Even though it is NOT licensed ATF+4 because it uses an unauthorized group V base oil, it does use the same Lubrizol add pack for licensed ATF+4
Re: Jeep Liberty, 2012 ATF and filter change [Re: steve40th] #4536682
10/07/17 11:47 PM
10/07/17 11:47 PM
Charleston, SC
Charleston, SC
Thanks for all the guidance everyone. I dont have a way to check temperature, other than a infared light. Its pretty accurate, but, nt sure where the Jeep transmission temp is most reliable to test at.
Redline C huh. I will look into that.
Supposedly all 2012 KKs got the towing transmission cooler, which is integrated with the ac condensor.
I will go shopping tomorrow at WalMart to see the ATF+4. The owners manual doesnt say its synthetic, like it does for rear gear oil, for example.
