Planes, smoke, pyrotechnics and lasers
by Shannow. 03/26/19 08:55 AM
Rust paint that works? Canada
by nobb. 03/26/19 07:19 AM
Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
bgm6881, machv5, freewayken, JustMatt, DCDMan
67626 Registered Users
92 registered members (ARCOgraphite, andyd, 2010Civic, aquariuscsm, AdditiveOCD, 11 invisible), 1,671 guests, and 69 spiders.
Topics286,446
Posts4,908,437
Members67,626
Most Online2,967
Mar 10th, 2019
How long does oil last. #4535961
10/07/17 07:32 AM
10/07/17 07:32 AM
kutztown, pa
jfairchild327 Offline OP
kutztown, pa
I received a company vehicle and put very few miles on my Cobalt 2.2 these days. Maybe 2,000 miles a year. My question is how long is my oil good for inside the crankcase? I only run Pennzoil Platinum or Amsoil SS. Can I leave this oil in for 3 years? I will not use dino oil due to the chatter when started up in the winter.
2001 F250 7.3 powerstroke
1993 F250 7.3 turbo
1983 F250 6.9 483,000 miles and counting
Re: How long does oil last. [Re: jfairchild327] #4535977
10/07/17 07:53 AM
10/07/17 07:53 AM
Michigan
ZZman Offline
ZZman  Offline
Michigan
The standard always mentioned is 1 year or x amount of miles. One oil change a year is cheap.
2003 Mercury Grand Marquis. PP HM 5w-30 and Fram TG
2008 Sebring Hardtop convertible. PP HM 5w-30 and Fram Ultra
2006 Kawasaki Vulcan 900 LT. Motul 7100 10w-40 and K&N
Re: How long does oil last. [Re: jfairchild327] #4535979
10/07/17 07:55 AM
10/07/17 07:55 AM
Michigan
BobsArmory Offline
BobsArmory  Offline
Michigan
Amsoil says X miles or 1 year. I'm pretty sure GM has a 1 year limit as well.
Keeping the forces of evil at bay
2016 Chevy Malibu LT 1.5 Liter Turbo
2017 Chevy Equinox LT 2.4 Liter
Re: How long does oil last. [Re: ZZman] #4535994
10/07/17 08:09 AM
10/07/17 08:09 AM
On the road Midwest
Ihatetochangeoil Offline
On the road Midwest
Please point out the abnormalities in this 5 year old oil?
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4190879/1992_Surburban_Big_Block_-_M1_
I currently have almost 40K on my Amsoil SS 5W30; full disclosure I'm running two bypass filters (and other goodies) in series, and I have test lab reports every 4-5K...
My two cents to the OP is to run the oil to where you think you need to change it...then run an oil sample. I can pull a sample from a warmed and running engine by removing the oil filler cap and drawing out a small amount at a time with a plant nutrient syringe...http://www.ebay.com/itm/150ml-Large-Hydroponics-Nutrient-Disposable-Measuring-Syringe-Tools-Plastic/122729935019?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
The idea of running a used oil analysis is not to waste money but to set precedent. Anything anyone says about a "standard" of time or mileage is pure speculation (however conservative or not) until an oil analysis is done.
And yes, there's LOTS of speculation out there...
Whatever
Re: How long does oil last. [Re: jfairchild327] #4536011
10/07/17 08:33 AM
10/07/17 08:33 AM
Michigan
BobsArmory Offline
BobsArmory  Offline
Michigan
Oil analysis will cost about $28 from Blackstone, add in the cost of TBN TAN and he has exceeded the cost of an annual oil change using Pennzoil Platinum and a nice filter to boot. A decent bypass filter set up starts at about $300.
Oil is cheap.
Re: How long does oil last. [Re: jfairchild327] #4536026
10/07/17 08:55 AM
10/07/17 08:55 AM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: How long does oil last. [Re: BobsArmory] #4536028
10/07/17 08:58 AM
10/07/17 08:58 AM
On the road Midwest
On the road Midwest
Oil is cheap.
And the OP nor you know anything about the oil that was thrown away. Would it have been perfectly fine for 2-3 years? Analysis from Horizon (Amsoil) is $27 and includes TBN. I can present facts, learning is optional.
Do whatever lets you sleep at night. As I said, lots of speculation out there...
Whatever
Re: How long does oil last. [Re: jfairchild327] #4536044
10/07/17 09:23 AM
10/07/17 09:23 AM
Deep in the heart of Jersey
BigCahuna Offline
BigCahuna  Offline
Blackstone's stand is an oils condition is based on usage , not age. If you sent a sample to them and asked how old the oil was, they couldn't tell you. They could say it meets this or that standard, or what wt it tested out as, but not how old it is.,,,
Re: How long does oil last. [Re: jfairchild327] #4536051
10/07/17 09:30 AM
10/07/17 09:30 AM
Texas
GMBoy Offline
GMBoy  Offline
Texas
As stated, the "standard most common answer" is 1 year. Based on your useage you may consider going to a semi-synthetic hi mileage oil for the stronger additives and the seal conditioners since the car is sitting a lot which can allow seals to dry out. Figure a jug of max life and an ST filter for under $25 a year and call it good.
Re: How long does oil last. [Re: jfairchild327] #4536063
10/07/17 09:38 AM
10/07/17 09:38 AM
Michigan
BobsArmory Offline
BobsArmory  Offline
Michigan
Pen Platinum is $23 and a fram tough guard filter is about $6. That's $29 per year considering no sales or rebates if the OP does an annual oil change.
Like I said Blackstone is $28 plus TBN TAN. Amsoil is $34 postage paid or $24.60 non postage paid (i just looked).
The OP sure can extend past 1 year by using analysis and feel safe in doing so. But for me the juice aint worth the squeeze.
Re: How long does oil last. [Re: jfairchild327] #4536083
10/07/17 09:59 AM
10/07/17 09:59 AM
Michigan
ZZman Offline
ZZman  Offline
Michigan
It would be similar in asking, Could my oil last to 5000 or 7500 miles and still be OK?
The answer is probably yes.
Re: How long does oil last. [Re: BobsArmory] #4536102
10/07/17 10:34 AM
10/07/17 10:34 AM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Oil is cheap.
This! I change oil twice a year in my Corolla total cost with quality filter and Full Synthetic $60 dollars a year total cost or less depending on sales.
My Duramax it going to go 18 month this time. Due to a lack of driving and the Oil monitor says 80% remaining. Total oil change cost $62 DIY Rotella T6 Full Synthetic and new filter or $129 plus tax at the dealership with Synthetic blend. I'll change it out next spring just before the towing season.
Oil is cheap!
2004 Corolla 130035
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: How long does oil last. [Re: JohnnyJohnson] #4536118
10/07/17 10:55 AM
10/07/17 10:55 AM
Minnesota
philipp10 Offline
philipp10  Offline
Minnesota
Oil is cheap.
Oil is cheap!
There is no sense in having this site if the pat answer is "oil is cheap". Yeah we get that. The question was, is 3 year old oil with 6000 miles on it still good? Only one poster attempted to answer that. You have to realize that the auto manufacturers had to give you SOME timeframe and since very few people would ever land over more than a year OCI, they picked that change interval as safe. Doesn't mean they did any tests. I design potentially perishable items from time to time. Usually when asked, I hold my thumb up and make a reasonable period of time that I know is acceptable for the item to last while not making it so long as to look ridiculous. The safe bet is to say change the oil since no manufacturer can predict the exact environmental conditions however, a one time UOA would answer that question. I'll bet anything, the oil would easily be good over that 3 year period. This site at times, is like listening to a bunch of ninnies.....all worried about an engine that could probably run oil out 20k and not matter.....jeez.
Re: How long does oil last. [Re: jfairchild327] #4536121
10/07/17 11:00 AM
10/07/17 11:00 AM
The Garden State
Whimsey Online content
Whimsey  Online Content
The Garden State
I really think it depends on the conditions the vehicle is run for. I did an UOA on my 1996 Contour using PP 5W-30 run for almost 8,800 miles over 18 months or slightly more. It was a mixture of highway and "local", almost no stop and go, driving. Wear metals were low and the TBN was 3.5, plenty of life left in the oil after ~8,800 miles and over 18 months of use. As stated here previously, oil does not know time only how it's used. My BIL bought a used Porsche Boxster, 5 years old with 9,000 miles on it with the factory fill. He did a UOA on the FF and it came back with not bad wear metals and plenty of life left in the oil. This Porsche was a "fun" vehicle used only in nice weather conditions and warmed up totally before garaging again. I'd be more concerned with the type of use, does the oil get hot, up to temp when it's used vs short trips where the oil never gets hot.
Whimsey
Re: How long does oil last. [Re: philipp10] #4536122
10/07/17 11:00 AM
10/07/17 11:00 AM
Wet side WA
Wet side WA
Well early changes give some that warm fuzzy. But I go both ways on my Corolla I change twice a year with no UOA which means one OCI is free. But if you want to go for extended OCI only a UOA is going to give you the truth you may or may not like the answer. If you don't well its just wear you can't get back.
Oil is cheap
Its even cheaper if you shop.
2004 Corolla 130035
2006 Duramax 74725
