S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
Ford Unibody Pickup
by SubLGT. 03/25/19 05:52 PM
Flow How: PourPoint warmer than CCV "0w" Temperature 0w20
by oil_film_movies. 03/25/19 05:31 PM
Oil filter material list?
by shibby6600. 03/25/19 04:49 PM
Insights on commission paying jobs?
by Pat in Speedway. 03/25/19 04:29 PM
Decode a vehicle VIN for production Month & Year?
by Ed_Flecko. 03/25/19 04:29 PM
Wix 51522 vs Fram XG9837
by RDY4WAR. 03/25/19 04:13 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
116 registered members (2015_PSD, anndel, AndyB, 2010Civic, ARB1977, agpatel, 16 invisible), 2,059 guests, and 65 spiders.
Topics286,429
Posts4,908,099
Members67,622
Most Online2,967
Mar 10th, 2019
What do you think about this data sheet? 10w60 #4535896
10/07/17 03:31 AM
10/07/17 03:31 AM
Sweden
lars11 Offline OP
lars11  Offline OP
Sweden
A 10w-60 synth SM/CF A3/B3. Thinking of running it in a 5.0 Mercruiser EFI, oci 40-60 hrs. What's your verdict?
Test Specification Method
Appearance Clear & Bright Brown Oil T11
Kinematic Viscosity @ 40C 135 155 cSt T34
Kinematic Viscosity @ 100C 23.0 26.0 cSt T34
Oil Color Lovibond 3.0 4.0 T89
Density @ 15C 0.856 0.876 T90
Calcium (%w/w) 0.276 0.338 XRF
Phosphorus (%w/w) 0.077 0.093 XRF
Zinc (%w/w) 0.084 0.102 XRF
TYPICAL DATA
Test Value Method
Cold Crank Simulator @ -25C 6 100 cps T55
Total Base Number
(mgKOH/g)
10.1 ASTM D445
Sulfated Ash 1.26 ASTM D874
Viscosity Index 173 T87
Pour Point (C) -39 ASTM D97
Flash Point (C) 220 ASTM D93
Re: What do you think about this data sheet? 10w60 [Re: lars11] #4535904
10/07/17 05:23 AM
10/07/17 05:23 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
What does your manual say?
Here, they want a 25w-40 changed every 50 hrs.
Many guys just run a mineral 15w-40.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: What do you think about this data sheet? 10w60 [Re: lars11] #4535913
10/07/17 05:48 AM
10/07/17 05:48 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
It will be a 40 grade before you get too many hours on it.
Start with a stout 40 grade, such as suggested above.
Re: What do you think about this data sheet? 10w60 [Re: lars11] #4535914
10/07/17 05:51 AM
10/07/17 05:51 AM
ST Augustine, FL
exShuttlemech Offline
ST Augustine, FL
Is this all year round use in Scandinavia?
2010 Rav4 4cyl 131K QSUD 0W20 Baldwin bypass filter
2003 4Runner 4.0L 219K 0W40 M1 Frantz bypass
2007 F150 4.2L 169K 5W30 QSUD
2016 NV2500
2017 RAV4
Re: What do you think about this data sheet? 10w60 [Re: lars11] #4535924
10/07/17 06:13 AM
10/07/17 06:13 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
It looks just fine for 50 hours use.
Re: What do you think about this data sheet? 10w60 [Re: lars11] #4535928
10/07/17 06:24 AM
10/07/17 06:24 AM
ST Augustine, FL
ST Augustine, FL
0W40 would be the thickest that I would go in Arctic conditions.
2016 NV2500
2017 RAV4
Re: What do you think about this data sheet? 10w60 [Re: exShuttlemech] #4535934
10/07/17 06:36 AM
10/07/17 06:36 AM
ST Augustine, FL
ST Augustine, FL
Aren't we talking about a 305 cu. in. Chevy engine that runs at a steadily higher RPM as a car/truck but in the cooler temp range? Then why are the boat engine manufacturers stuck in the 1960's for super thick oil viscosity?
2016 NV2500
2017 RAV4
Re: What do you think about this data sheet? 10w60 [Re: lars11] #4535963
10/07/17 07:37 AM
10/07/17 07:37 AM
Reno, Nevada
Langanobob Offline
Langanobob  Offline
Reno, Nevada
Because they don't care about incremental gains in fuel economy and because boat engines run at max HP or close to it for extended periods. Additive packages in low viscosity oils are fine but viscosity is still the first line of defense against wear.
Re: What do you think about this data sheet? 10w60 [Re: lars11] #4536002
10/07/17 08:21 AM
10/07/17 08:21 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
15W-40 HDEO will do fine.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: What do you think about this data sheet? 10w60 [Re: lars11] #4536228
10/07/17 01:27 PM
10/07/17 01:27 PM
Sweden
lars11 Offline OP
lars11  Offline OP
Sweden
Ok, will go with delvac mx again
Re: What do you think about this data sheet? 10w60 [Re: exShuttlemech] #4536853
10/08/17 07:54 AM
10/08/17 07:54 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
1. A boat at cruising is like towing a heavy trailer uphill in second gear.
2. Oil temps on the models not fortunate enough to have an oil cooler are severe.
3. Oil temps on models with an oil cooler can still be severe.
4. Volvo Penta tried to get away with using a synthetic SAE 30 diesel engine oil for the Chevy small block based engines and got bad wear results.
20w50 is as good as it gets unless living in ice.
Re: What do you think about this data sheet? 10w60 [Re: lars11] #4536889
10/08/17 08:45 AM
10/08/17 08:45 AM
Sweden
lars11 Offline OP
lars11  Offline OP
Sweden
my engine has no oil cooler, and volvo recommends 15w50 mineral or 15w40 diesel VDS-3 rated oil for this engine up until 2008 (when they added catalysts).
So I bought volvo penta VDS-3 oil as it was cheaper (????) than Mobil delvac MX that I used to run.
Makes me think volvo is aiming at minimum 40 hot viscosity and a diesel add pack for wear.
Mercruiser seem to use oil coolers and their standard oil is the 25w40 so it seems fair to say the gm v8 need a 40, at least.
Re: What do you think about this data sheet? 10w60 [Re: Langanobob] #4536898
10/08/17 08:58 AM
10/08/17 08:58 AM
ST Augustine, FL
ST Augustine, FL
Turbine oil is very thin, why doesn't this theory apply to them?
2016 NV2500
2017 RAV4
Re: What do you think about this data sheet? 10w60 [Re: exShuttlemech] #4537158
10/08/17 01:23 PM
10/08/17 01:23 PM
Sweden
lars11 Offline OP
lars11  Offline OP
Sweden
Why should it? depends on the film reqs and also the surface properties of the parts. Maybe the bearings in a comp is tight and controlled temp?
Re: What do you think about this data sheet? 10w60 [Re: exShuttlemech] #4539900
10/11/17 08:14 AM
10/11/17 08:14 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Apples to oranges.
Just the mere fact that a turbine engine has no reciprocating parts is a major factor. There are 1000 others.
