Corrosion in the garage - salt or humidity?
by Kurtatron
14 minutes 34 seconds ago
Darn dogs
by AZjeff
Today at 10:21 PM
New GC?
by Bullwinkle007
Today at 10:04 PM
The guy with the plexiglass head on you tube
by andyd
Today at 09:21 PM
'07 Pacifica Timing Belt Replacement success
by 92saturnsl2
Today at 09:10 PM
SAE 90 v 85/140
by Knuckle078
Today at 09:10 PM
Mobil 1 5W30-HM 5,011 mi, 1999 Ford Escort
by WA1DH
Today at 08:45 PM
what happened to merk
by ernied
Today at 08:34 PM
Schaeffer's oil reviews on Amazon
by zfasts03
Today at 07:41 PM
Decent MP3 player
by Ed_T
Today at 07:08 PM
Letgo
by Donald
Today at 06:52 PM
Tire buying advice
by supton
Today at 06:23 PM
Two versions of M1 5w30 ESP now?
by Patman
Today at 06:21 PM
No older cars in New York State?
by Oldtom
Today at 06:19 PM
2009 Taurus strut mount noise
by terry274
Today at 04:38 PM
A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
Today at 03:36 PM
2003 Honda power steering problem
by hogpops
Today at 03:29 PM
Public Service Announcement: Flush Your HW Heater
by gathermewool
Today at 03:25 PM
Fellow 2AZ-FE toyota owners: what oil are you usin
by car51
Today at 03:21 PM
Castrol 0W40 vs 5W40??
by Realfine69
Today at 03:02 PM
lozpxs, danthemanx07, FunktasticLucky, Knuckle078, penncove
65317 Registered Users
70 registered (154cm, 77GrandPrix, 1JZ_E46, 2015_PSD, 4WD, Aero540T, 8 invisible), 1153 Guests and 56 Spiders online.
65317 Members
67 Forums
285949 Topics
Page 1 of 2 1 2 >
#4535618 - 10/06/17 05:41 PM Almost new genset with 100 hours
henni Offline
Loc: key largo,fl
So, in the storm aftermath, a few top end gensets are hitting the open market and I have a chance to pickup one top+of+the+line honda inverter at about 20% off new price.
This one appears to be (have not performed a close inspection yet, just phone interview to check out credentials and scam radar detection..) installed new this year and run almost non-stop for hundred hours and I suspect based on the vague answers, no oil changes were done. No idea also what oil they put in since new.
Assuming my worst fears are true and that I can perform a closer inspection before buying, how cautious should I be or just ignore it and assume it would be Ok with some immediate OC's at this point ? My assumption is that I would be allowed no more than 5 minutes to examine, perhaps start it, maybe connect some power tool to verify and that would be the limit. If the dipstick shows a metal sliver tar pit droplet, how much of a concern and how loud of an alarm should ring off ?
2014 Ridgeline RTL with Navi
#4535623 - 10/06/17 05:47 PM Re: Almost new genset with 100 hours [Re: henni]
madRiver Offline
Loc: New England
100 hrs is high mileage for 20% off new.
I would aim for 2/3 new price.
#4535630 - 10/06/17 05:57 PM Re: Almost new genset with 100 hours [Re: henni]
eljefino Offline
Loc: ME
If the seller doesn't have the receipt call the fuzz on him.
This genny will be cheaper next February when everyone forgets about hurricanes and needs money for Xmas bills.
IDK why someone would spontaneously buy a top shelf inverter generator to survive a storm unless they had no other option.
#4535642 - 10/06/17 06:12 PM Re: Almost new genset with 100 hours [Re: henni]
JimPghPA Offline
Loc: Pittsburgh,PA U.S.A.
Bring along enough electric heaters to load it down close to 100 percent of rated load and see if it can supply them for 15 minutes non-stop. If it can't then forget about it.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
#4535648 - 10/06/17 06:26 PM Re: Almost new genset with 100 hours [Re: eljefino]
madRiver Offline
Loc: New England
They likely did not want to chase fuel down. These invertor ones sip fuel.
#4535664 - 10/06/17 06:48 PM Re: Almost new genset with 100 hours [Re: henni]
JimPghPA Offline
When you bring along the electric heaters keep in mind that it probably only has two 120 Volt outlets, and if it requires more than two electric heaters to load it down close to 100 percent you will require extension cords with multiple outlets on it to branch the connections out to more than two connections.
How many Watts is it rated for?
JimPghPa
#4535686 - 10/06/17 07:32 PM Re: Almost new genset with 100 hours [Re: madRiver]
gathermewool Offline
Is that true? It's barely past break-in.
#4535706 - 10/06/17 07:55 PM Re: Almost new genset with 100 hours [Re: henni]
NormanBuntz Offline
Loc: Outer Banks, NC
I too think that 20% off a generator with 100 hours is not enough of a discount.If the seller won't let you demo the unit to your satisfaction, run away.
2017 Honda Odyssey SE, 14K
2013 Honda Accord LX, 58K
2007 Honda Ridgeline RTS, 86K
2007 Infiniti M35, 104K
#4535708 - 10/06/17 07:57 PM Re: Almost new genset with 100 hours [Re: eljefino]
DoubleWasp Offline
Loc: Fort Lauderdale, FL
Bingo. 4 months from now, you won't be able to give away a generator. Complete buyer's market.
#4535711 - 10/06/17 07:59 PM Re: Almost new genset with 100 hours [Re: henni]
motor_oil_madman Offline
Loc: Houston, Texas
What kind genset are we talking about?
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
#4535712 - 10/06/17 08:00 PM Re: Almost new genset with 100 hours [Re: henni]
Loc: Houston, Texas
Btw it's only called a genset when you have two.
#4535746 - 10/06/17 08:44 PM Re: Almost new genset with 100 hours [Re: henni]
philipp10 Offline
Loc: Minnesota
I don't understand why your worried about one continuous 100 hour run on the oil. That's nothing. I would say though, 20% off is not enough. I would thing 1/3 rd off would seem about right.
#4535753 - 10/06/17 08:49 PM Re: Almost new genset with 100 hours [Re: philipp10]
JimPghPA Offline
Actually, 100 hours is pushing the limits for an oil change on a generator.
JimPghPa
#4535766 - 10/06/17 09:03 PM Re: Almost new genset with 100 hours [Re: motor_oil_madman]
rubberchicken Offline
Loc: Maryland USA
In the boating industry they are called gensets. Come to think of it, in the commercial UPS / backup world they are commonly called gensets. No idea if this is a misuse of the term.
Edited by rubberchicken (10/06/17 09:04 PM)
#4535922 - 10/07/17 06:10 AM Re: Almost new genset with 100 hours [Re: henni]
Cujet Offline
Loc: Jupiter, Florida
A Honda generator will easily go 100 hours on it's first oil change. I'd run it, pull the dipstick, if it looks good, it very likely OK. However, folks in the Keys were without power much longer than 100 hours.
Page 1 of 2 1 2 >
