The best in personal defense (Humor)
by StevieC. 01/15/19 11:10 PM
best way to buy a new vehicle?
by WhyMe. 01/15/19 11:07 PM
Cat Humor
by StevieC. 01/15/19 11:06 PM
Lightning McQueen (Humor)
by StevieC. 01/15/19 11:04 PM
Fastest Land Mammal (Humor)
by StevieC. 01/15/19 11:01 PM
Wifes says decorate the baby's room (Humor)
by StevieC. 01/15/19 11:00 PM
Taco Bell (Humor)
by StevieC. 01/15/19 10:57 PM
Van full of money (Humor)
by StevieC. 01/15/19 10:56 PM
Amazon Packaging (Humor)
by StevieC. 01/15/19 10:55 PM
Star Spangled Banner in school (Humor)
by StevieC. 01/15/19 10:52 PM
Maybe on to something? (Batman Humor)
by StevieC. 01/15/19 10:49 PM
Canadian Breakfast (Humor)
by StevieC. 01/15/19 10:48 PM
Tinder Anyone? (Humor)
by StevieC. 01/15/19 10:45 PM
(NEW) Wix 51522 Cut Open
by rooflessVW. 01/15/19 10:23 PM
Is this guy for real? (HUMOR)
by StevieC. 01/15/19 10:18 PM
Elf 4T moto tech 10w50 is good?
by firstime911. 01/15/19 09:25 PM
New Champ Filter
by CapitalTruck. 01/15/19 08:30 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
38 registered members (billt460, 4WD, Astro14, alcyon, Black_Thunder, anndel, 1 invisible), 913 guests, and 38 spiders.
Topics296,627
Posts4,955,932
Members66,950
Most Online2,577
Jan 14th, 2019
FZ-07 winter/summer recommendation for Phoenix AZ #4535389
10/06/17 11:40 AM
10/06/17 11:40 AM
Phoenix, AZ
grj Offline OP
grj  Offline OP
Phoenix, AZ
Greetings,
New Yamaha FZ-07 owner here - year-round daily work commuter. I'm preparing for the first oil change at 600 miles. Dec-Jan early morning temps can get into the mid-low 30s here in Phoenix. The bike is garage parked at night so it is unlikely I would start it up below ~50 deg F. Based on the chart from the manual, I should run 15W-40 for winter and 20W-50 for summer:
I'd like to stay within Yamaha recommendation under warranty but as far as I know there is no Yamalube in 15W-40 or 20w-40.
Any Phoenix commuters here? What do you use? Is it OK to run 20W-50 all year long or 10w-40 for winter?
Thanks!
2017 Yamaha FZ-07 ABS
Re: FZ-07 winter/summer recommendation for Phoenix AZ [Re: grj] #4535399
10/06/17 11:51 AM
10/06/17 11:51 AM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Hows that air conditioner work out when its 120 plus?
2004 Corolla 128175
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74615
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: FZ-07 winter/summer recommendation for Phoenix AZ [Re: JohnnyJohnson] #4535402
10/06/17 11:56 AM
10/06/17 11:56 AM
Phoenix, AZ
grj Offline OP
grj  Offline OP
Phoenix, AZ
Last year I commuted year round on my Honda - even in August! Luckily my commute is only about 15 minutes mostly freeway so it is tolerable and no A/C needed smile
Re: FZ-07 winter/summer recommendation for Phoenix AZ [Re: grj] #4535405
10/06/17 11:58 AM
10/06/17 11:58 AM
Twin Cities MN USA
Inspecktor Offline
Inspecktor  Offline
Twin Cities MN USA
welcome Either grade would be fine. Amsoil makes a 20W-40 synthetic oil in addition to a 10W-40. HDEOs will work, and are available in 5W-40 and 15W-40, although my bike does not shift as well with 5W-40 Rotella as it does with 10W-40 synthetic bike oil.
2001 Ranger 3.0 165,000 mi
2006 Dakota 4.7 156,000 mi
1986 GL1200A 73,500 mi
2001 Buick LeSabre Limited 292,000 mi
Re: FZ-07 winter/summer recommendation for Phoenix AZ [Re: grj] #4535426
10/06/17 12:45 PM
10/06/17 12:45 PM
New England
Virtus_Probi Offline
New England
Seems like 15W50 would be perfect for you year round, guess that's not a common grade?
2014 Forester XT, 95000 miles
Last Change;
M1 0W30 AFE d1G2
Tokyo Roki 15208AA170 filter
Re: FZ-07 winter/summer recommendation for Phoenix AZ [Re: grj] #4535433
10/06/17 12:58 PM
10/06/17 12:58 PM
South Carolina
alarmguy Offline
alarmguy  Offline
South Carolina
20/50 would be ok all year.
Me personally, based on your post, 15/40 winter and 20/50 as soon as the low temps are in the 60+ range.
or if available in an MA, 15/50 as someone else said.
I use a 15/50 non Jaso oil all year, I do ride a few times a month over winter when temps are in the upper 50s to low 70s. However the oil is not shared with the clutch so no concerns about moly or other slippery stuff. I dont think you will find a reasonably priced 15/50 with an MA rating but I could be wrong on that.
You could mix 2 20/50 and 2 10/40 of standard Motorcycle oil of the same brand and exact type, though I think mixing is not ideal because we assume (most likely correct though) it has the same additives.
I did that with my last Metric and used conventional Valvoline 4 stroke motorcycle oil which I think is underated. Ran UOAs on it and posted them in here, that was years ago.
Inexpensive, good stuff, $4 a quart in Walmart and no matter how little you use the bike over the winter, you can throw it away in the spring at little cost.
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Re: FZ-07 winter/summer recommendation for Phoenix AZ [Re: grj] #4535514
10/06/17 02:32 PM
10/06/17 02:32 PM
Texas
FZ1 Offline
FZ1  Offline
Texas
Amsoil 20w-50 shifts nice runs nice in my 02 FZ1. Try it,you'll like it. MY bike didn't like the Mobil Racing 10w-40. I think the thicker bottom 20w is better. Hope this helps.
Re: FZ-07 winter/summer recommendation for Phoenix AZ [Re: grj] #4535743
10/06/17 07:41 PM
10/06/17 07:41 PM
pa
benjy Offline
benjy  Offline
pa
just bought a case of spectro platinum 15-50 motorcycle oil @ $13 a L del, said to be all PAO, but usually has some Ester in the blend. in Pa it flows good enough for cooler riding as well as protects in the heat, when its cold i use a cage!!! it will suit all 3 bikes i own!!
Re: FZ-07 winter/summer recommendation for Phoenix AZ [Re: grj] #4535915
10/07/17 04:56 AM
10/07/17 04:56 AM
Phoenix, AZ
grj Offline OP
grj  Offline OP
Phoenix, AZ
Thanks everyone for the feedback! The 15W-40 Rotella T and Rotella T4 look good maybe for next winter after the warranty is up just because Yamaha does not recommend the SAE CD or higher diesel oils even though they are JASO MA friendly. There are plenty of 20w-50s out there specific for motorcycles that look great even Yamalube. But 15W-40s JASO MA/MA2 seem rare as hen's teeth!
For this year I'll probably go with 10w-40 for winter then change up to 20w-50 in the spring time. I have this snippet from the owner's manual too:
Re: FZ-07 winter/summer recommendation for Phoenix AZ [Re: grj] #4535966
10/07/17 06:40 AM
10/07/17 06:40 AM
South Carolina
alarmguy Offline
alarmguy  Offline
South Carolina
Interesting note regarding diesel oils from Yamaha, first I have ever seen.
I suspect because of the newer CK oils and increasing use of some substances in some formulas to increase fuel mileage.
Im sure it would be fine but I like you would just listen to the manual.
Quite honestly, there is no reason to not listen to the manual.
Valvoline motorcycle oils are well priced in both synthetic and conventional so the decision is simple.
07 Suzuki C50
Re: FZ-07 winter/summer recommendation for Phoenix AZ [Re: grj] #4536034
10/07/17 08:13 AM
10/07/17 08:13 AM
805, Ca
Analyzer Offline
Analyzer  Offline
805, Ca
First of all, congrats on the FZ-07, they're an awesome bike! What it really boils down to is if you want to utilize two separate oil viscosities per year (vs just one), and what you're willing to pay for a JASO MA rated oil. If you're okay spending around $15 per qt., the YAMALUBE full synthetic 15W50 (PAO/Ester based) would be a perfect oil year round. If you're looking for something around the $4 per qt. range the Valvoline motorcycle oil in 10W40/20W50 is a great bang for the buck and you can alternate between those two viscosities throughout the year. Keep in mind that you could run 10W40 all year (10 degrees on up to 110 degrees Fahrenheit), and as Alarmguy stated, even the 20W50 could be run year long with no ill effects.
2007 Yamaha FZ1
1986 Yamaha FZX700 Fazer
1997 Suzuki RM250
2016 Mazda 3 Sport
1992 Ford Explorer Eddie Bauer 4x4
Re: FZ-07 winter/summer recommendation for Phoenix AZ [Re: grj] #4536143
10/07/17 10:30 AM
10/07/17 10:30 AM
Phoenix, AZ
grj Offline OP
grj  Offline OP
Phoenix, AZ
Great suggestions guys - I like the idea of the Yamalube 15W50 synthetic but the Valvoline 10W40 and 20W50 as recommended by AlarmGuy and Analyzer are cheap grin
I see also the Castrol Actevo 20W50 is $19.98 / gal at Walmart - good price!
Re: FZ-07 winter/summer recommendation for Phoenix AZ [Re: grj] #4536786
10/08/17 04:27 AM
10/08/17 04:27 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
M1, 15W-50 and or M1 20W-50 are both very robust choices for hard working motorcycle engines in hot climates. Both have excellent low temp pour points.
Re: FZ-07 winter/summer recommendation for Phoenix AZ [Re: grj] #4536811
10/08/17 05:43 AM
10/08/17 05:43 AM
Nowhere NM
Smoky14 Offline
Smoky14  Offline
Nowhere NM
I ran 20-50 year around in Tucson for 85K miles in my Yamaha, sold the bike and he ran it 2 years before he crashed off mount Lemon.
YMMV
Smoky
99 Acura 2.3CL 5speed MT
12 Ford Fusion 2.5S 6speed MT
05 Suzuki Bandit 1200.
Re: FZ-07 winter/summer recommendation for Phoenix AZ [Re: grj] #4536874
10/08/17 07:32 AM
10/08/17 07:32 AM
South Carolina
alarmguy Offline
alarmguy  Offline
South Carolina
Ahhh ... yes, Castrol Activo from Walmart, good price, semi syn, I never used it but thought about it more then a few times when I owned metric bikes and actually wouldnt discredit it for my current bike.
Anyway, If I was you, I would buy it without hesitation and use it.
Its a great price, name brand oil, has been around a long time. The key once you do use it, like any oil in a bike with a shared sump, see how well the nice shifting holds up after some miles are put on it, I suspect it will be better then most.
If not, then try the Valvoline.
But if it was me, I would run out try the Activo right now since its a reasonable priced semi syn and maybe marketing has the best of me but I like the Castrol brand name. (long story) But a very long time ago, it was the go to oil, even by Consumer Reports.
07 Suzuki C50
