Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
Why don't owner's manuals specify the oil type
by OilUzer. 12/16/18 07:13 PM
belt tensioner problems
by mobilaltima. 12/16/18 06:57 PM
How bout them Patriots
by 53' Stude. 12/16/18 06:36 PM
Hand held Ham radio suggestions
by littleant. 12/16/18 05:20 PM
Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
Oil analysis pump tube?
by maximum6. 12/16/18 03:56 PM
Mahle charcoal lined filter..the best!
by TiGeo. 12/16/18 03:45 PM
Diesel engines and emissions
by spasm3. 12/16/18 03:31 PM
Experiment time
by 53' Stude. 12/16/18 02:52 PM
2019 2.7L EB - Edge ST & Catch Can
by -SyN-. 12/16/18 02:51 PM
stantaur, Brandon9797, Landngroove, DanielH, Cpcz9382
66700 Registered Users
55 registered members (Black_Thunder, bdcardinal, ABomb369, BigShug681, 1345, anndel, 4 invisible), 1,364 guests, and 47 spiders.
Topics295,169
Posts4,929,073
Members66,700
Most Online2,553
Oct 27th, 2018
So What is Oil 'Scuffing'? #4535215
10/06/17 07:15 AM
10/06/17 07:15 AM
Mississippi
Speak2Mountain Offline OP
Mississippi
http://www.underhoodservice.com/gdi-syst...-intake-valves/
Since oil formulation is a work in progress, Iíll summarize by saying that oils used in GDI, particularly in turbocharged GDI (TGDI) engines, must meet much higher standards than the generic oils intended for conventional, naturally aspirated fuel-injected engines.
Oils intended for use in a GDI engine must have enough scuff resistance to protect the camshaft that drives a high-pressure mechanical fuel pump capable of developing well over 2,500 psi of fuel pressure. [u][/u][i][/i][color:#FF0000][/color]
Re: So What is Oil 'Scuffing'? [Re: Speak2Mountain] #4535217
10/06/17 07:16 AM
10/06/17 07:16 AM
Mississippi
Mississippi
and thx ahead of time
Re: So What is Oil 'Scuffing'? [Re: Speak2Mountain] #4535221
10/06/17 07:21 AM
10/06/17 07:21 AM
PA
d00df00d Online content
d00df00d  Online Content
PA
I don't think scuff resistance means "oil scuffing" is a thing. I think it means the oil prevents scuffing in engine parts.
2008 BMW M3
Re: So What is Oil 'Scuffing'? [Re: Speak2Mountain] #4535228
10/06/17 07:38 AM
10/06/17 07:38 AM
Danh Offline
Danh  Offline
While the camshaft-driven high pressure fuel pump is an added complication, higher quality oils don't always go with DI/TGDI engines. Ford, for example, allows the use of conventional engine oils in its DI/TGDI engines.
Even GM's new Dexos1 Gen 2 spec seems aimed more at preventing LSPI than accommodating whatever extra stress a high pressure fuel pump places on an engine oil.
Re: So What is Oil 'Scuffing'? [Re: Speak2Mountain] #4535290
10/06/17 09:36 AM
10/06/17 09:36 AM
Central Wisconsin
dwendt44 Offline
dwendt44  Offline
Central Wisconsin
IS the oiling system even part of the
high pressure fuel pump?
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: So What is Oil 'Scuffing'? [Re: dwendt44] #4535302
10/06/17 09:56 AM
10/06/17 09:56 AM
Mississippi
Mississippi
I know right?
Re: So What is Oil 'Scuffing'? [Re: Speak2Mountain] #4535314
10/06/17 10:21 AM
10/06/17 10:21 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
2014 Nissan Rogue S CVT, OC#10 47272mi-QSUD10W30+5w20 Toughguard Filter; '17 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: So What is Oil 'Scuffing'? [Re: ARCOgraphite] #4535576
10/06/17 03:36 PM
10/06/17 03:36 PM
PA
PA
^^ Wow!
2008 BMW M3
Re: So What is Oil 'Scuffing'? [Re: Speak2Mountain] #4535602
10/06/17 04:15 PM
10/06/17 04:15 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
I'd think they would use some kind of roller setup on the high pressure fuel pump if the stress is high on the actuating lobe.
Re: So What is Oil 'Scuffing'? [Re: Speak2Mountain] #4535633
10/06/17 05:01 PM
10/06/17 05:01 PM
NE,Ohio
Rand Online content
Rand  Online Content
NE,Ohio
there is no "oil scuffing"
oil needs to prevent scuffing wear
Re: So What is Oil 'Scuffing'? [Re: Speak2Mountain] #4537764
10/09/17 07:40 AM
10/09/17 07:40 AM
N.H, U.S.A.
N.H, U.S.A.
Agree. Just poor engine design or poor materials.
Re: So What is Oil 'Scuffing'? [Re: Speak2Mountain] #4537787
10/09/17 08:29 AM
10/09/17 08:29 AM
Balearic Islands , Spain
FordCapriDriver Offline
A liquid cannot suffer from scuffing.
Simple as that.
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort Mk4 Xr3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Finnish expat in Spain.
Re: So What is Oil 'Scuffing'? [Re: FordCapriDriver] #4537802
10/09/17 08:55 AM
10/09/17 08:55 AM
Texas & Global
4WD Offline
4WD  Offline
Texas & Global
Oil scuffing is when you bash someone elseís choice in oil to make yourself feel superior
2018 Chevy 1500 Z71 4WD
2017 Chevy Tahoe LT 4WD
2014 Fusion Hybrid Titanium
2013 Cruze LTZ - RS Turbo
Re: So What is Oil 'Scuffing'? [Re: Speak2Mountain] #4537816
10/09/17 09:08 AM
10/09/17 09:08 AM
Douglas County, Colorado
bigj_16 Offline
bigj_16  Offline
The upside to oil scuffing, is that when it happens, because it is liquid, it will buff right out. smile
Re: So What is Oil 'Scuffing'? [Re: bigj_16] #4537865
10/09/17 09:51 AM
10/09/17 09:51 AM
Texas & Global
4WD Offline
4WD  Offline
Texas & Global
True. ÖOr it goes out to the drain pan Ö laugh
