Phone Books
by csandste. 09/23/18 12:11 AM
Inside the Fuel Tank / EVAP system
by StevieC. 09/22/18 10:31 PM
Toyota Pink + RMI-25 10 years
by burla. 09/22/18 10:27 PM
Cartridge filter?
by Camprunner. 09/22/18 10:23 PM
Should have changed it?
by parshisa. 09/22/18 10:14 PM
Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
Redline D6 ATF substituting for Toyota WS
by Patrick0525. 09/22/18 05:29 PM
XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
transmission fluid and filter exchange
by Dennisistheman. 09/22/18 04:53 PM
Why people should change oil+filter!
by 53' Stude. 09/22/18 04:50 PM
HondaTech250, SandCruzer, sbgti96, cosmoblau, Sarrge
66044 Registered Users
33 registered members (Bailes1992, 10ecfarmer, Brigadier, aquariuscsm, BlakeB, 2 invisible), 996 guests, and 39 spiders.
Topics290,865
Posts4,851,547
Members66,044
Most Online3,590
Jan 24th, 2017
Weed Eater Featherlight Minimum & Maximum RPM #4535040
10/05/17 10:52 PM
10/05/17 10:52 PM
Planet Earth
TurboDieselPoint Offline OP
Planet Earth
Hi All,
I have a "Weed Eater Featherlight" 25cc 2 cycle, much like the one in the link below, which I will be converting to run on compressed air for my controls project. Have a quick question for you all:
When it is running properly on gasoline, approximately how fast will the engine be running at idle and at full throttle?
https://www.amazon.com/dp/B019V9EUW4/ref...la-310628748614
Thank you so much!
TurboDieselPoint
Re: Weed Eater Featherlight Minimum & Maximum RPM [Re: TurboDieselPoint] #4535082
10/06/17 01:26 AM
10/06/17 01:26 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I'm guessing 7,000-8,000 rpm?
Maybe more. I know when the string breaks off, the RPM's get really, really high.
You can get small handheld tachometers for pretty cheap.
Curious - - why compressed air?
How do you plan to lubricate it?
Re: Weed Eater Featherlight Minimum & Maximum RPM [Re: TurboDieselPoint] #4535087
10/06/17 01:38 AM
10/06/17 01:38 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Max spindle speed 10,000RPM, so 7-8 sounds right. manual
Re: Weed Eater Featherlight Minimum & Maximum RPM [Re: TurboDieselPoint] #4535097
10/06/17 02:46 AM
10/06/17 02:46 AM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
Cool, how many psi will it take to blow the top end off. lol
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Weed Eater Featherlight Minimum & Maximum RPM [Re: TurboDieselPoint] #4535242
10/06/17 09:00 AM
10/06/17 09:00 AM
Canada
boraticus Offline
boraticus  Offline
Canada
My Echo trimmers are set to run around 2500 rpm low speed and 7500ish at high speed with fresh strings. As mentioned above, speed will increase as the strings get shorter.
