Cordless Impact buying questions.
Hudson, NH
I need to learn about cordless impact wrenches before making a purchase so I have some questions.
Do they hammer same as air?
Can you set them for different torque settings?
What torque is good for anything around the house including my truck, lugs, etc
What is the difference between the 18v and 20v? They both provide similar torque ratings. Are there any more?
What is the trending/newest/longest lasting/best battery type?
I read descriptions like Hog ring, anvil ring, friction ring, and detent pin. What are the benefits of each, which is desirable?
Experienced cordless impact users, how reliable are they compared to air? Does the battery slowly degrade like lithium?
Anything else to consider
Thanks everyone.
What's your application?
I have the Craftsman and it's great and people say the Milwaukee is even better. It runs off a lithium battery. I don't know of any household uses for it besides working on cars/trucks.
Cordless should not be viewed as a replacement for air but more as a valuable supplement. The larger 1/2" cordless are not one of my favorite tools, they are 5Lb+, large and use pin clutch mechanisms which is the least desirable for automotive work.
There is no other way of generating that much torque from a battery operated electric motor that is small enough to used in a compact hand held package. The problem with pin clutches is they generate 100% torque right out of the gate and are not very controllable, this isn't a real issue with smaller 1/4 and 3/8 drive tools.
Many times I will set my air impact on low in reverse (not all air impacts can do this) or feather the trigger to hammer rusted bolts vibrating them to work penetrating oil into the threads before turning up the power, its works well. With a pin clutch this isn't happening, it will usually just either loosen it or break it off.
Most 1/2" and lower use friction rings aka hg rings, split rings, they work okay and are convenient and easy to replace. On big stuff you want a detent pin meaning you need to depress the pin when you want to remove the socket, not convenient if your changing sockets often on a job.
Some of the most powerful impacts I own do not have the highest torque on paper but have big hammers and that's what loosens the bolt, pay no attention to nut busting torque, its meaningless advertising hype, most impacts are in the 400-500 ft.lb range of real torque.
My favorite guns are the mini 1/2 air with twin hammer and the 1/4 and 3/8 cordless Makita 18V, For bigger stuff I have a full size 1/2, 3/4 and 1". I bought this one but like the rest of them this size I didn't like it for general automotive work.
^^This
I have a Dewalt battery impact. It's awesome for all the small stuff working on cars and small engines. I still have my big air impact for the really big stuff. The battery impact is good for pretty much everything I'd use a normal ratchet on. The Dewalt is powerful enough to take off lug nuts if I needed to, but that is probably the max of it's capability.
Originally Posted By: zzyzzx
Why not get a corded one instead?
They are cheaper and better.
not true.
many cordless are much stronger than most corded electric impacts.
If you have a compressor go AIR, or cordless for convenience.
if you don't have air go cordless.. unless you are in some type of industrial shop using
specialty tools.
For just zipping wheels off and on, anything 1/2" will work. For swapping wheels I have one of these 1/2" impact heads and if you have a decent cordless drill already it does the trick. I'm guessing it does atleast 150ft-lbs as any lugs I've used it on take no time at all to bust loose. 4" 3/8" lag screws into wood either strip the hole or break with it as well. They used to sell them at Canadian Tire for $20 on sale.
For actual mechanical work I have a corded 1/2" electrical and it is a bit large at times, so I can see why going with an air gun is the way to go for even a weekend mechanic.
not true.
specialty tools.
I actually have all three.
The corded one is in between the air and the battery for power. The corded one is an industrial Dewalt I bought refurbished off eBay, so it had almost the power of the air impact. It is to the point where I only break out the air impact for the tough stuff like rusty axle nuts.
The power of each one really depends on the brand and specs. I've used cheapo air impacts from harbor freight that couldn't loosen a lug nut, and battery ones that were very powerful for their size.
I had an IR corded electric it was around 300lb-ft and worked ok.
The dewalt dcf899 I replaced it with hits much harder.. has variable settings also.
I have an aircat which is pretty nice for air impact. I end up using the dewalt 95% of the time.
I wouldnt mind adding a smaller one although most of the time
my impact driver does ok.
Almost all corded electric impacts you will find in a store such as tractor supply or home depot will be 5-8amps and 180-350lb-ft
https://www.amazon.com/Kawasaki-841426-2...6E6XG6EDKQSSBVC
https://www.amazon.com/Kobalt-120-Volt-C...6E6XG6EDKQSSBVC
https://www.amazon.com/DEWALT-DW292K-2-I...6E6XG6EDKQSSBVC
Granted you can find monsters such as this 800$ makita but not optimal
https://www.amazon.com/Makita-TW1000-1-I...6E6XG6EDKQSSBVC
IIRC I paid around $260 for my dewalt dcf899 with a 5ah battery.
It is pretty legit.. although heavy esp under the car.
https://www.amazon.com/DEWALT-DCF899P1-Brushless-Torque-Impact/dp/B00X52TWA4
I went with a cordless Makita- great for track days and switching out winter/summer tire and wheel sets.
If you want to remove a lug nut use an impact wrench. It will have the hex or square male end at the tip that you attach sockets to. If you want to drill a screw into a piece of wood, use an impact drill. Those are the typical chucks that you put bits in. You wouldn't think that it'd matter, but I found out the hard way when I was shopping for one.
The impact drills I bought was not strong enough to loosen lug nuts. I thought it was just because I bought a cheap entry level Ryobi. I then tried a more expensive DeWalt, but still no luck. Then my pops told me the difference and I'm beyond happy with my Black and Decker bolt-on impact wrench attachment. Already came in handy for MANY crusty, stuck bolts, not just for removing lug nuts.
My dad has a 30 year old Snap On air impact wrench. Still works. My air impact wrench is about 8 years old. I bet I will still be using it in 30 or 40 years.
Air is the way to go for longevity. Batteries have come a long way, but an air impact will still be working in 30 years (residential use), while a battery powered one will have been obsoleted 7 times by then. Add up the battery replacement cost over its lifetime and .....
Battery powered is certainly convenient. But my honest opinion... if you have a compressor at the house, its hard to beat a good air impact. And if you dont have an air compressor at the house, then buy one.
This conversation is not about impact drills.
You should somewhat consider what other cordless tools you have or want so you can buy one maybe two batteries and many bare tools.
The newer cordless motors are brushless. I got a Milwaukee M18 Fuel High Torque impact. It does everything I need which are usually rusted lug nuts on a trailer.
As a home owner, I had a bunch of Ryobi tools and batteries, so it was a no brainer to get the Ryobi 1/2" impact. Some reviews say its an identical copy to the Craftsman C3. Pictures look alike. Not the strongest, but I didn't need to invest in new batteries. Gets all the lug nuts and suspension nuts/bolts I've used it for without a problem. 3 speeds is gimmicky, but useful for those moments you don't need all the beans.
I've been itching for the Gen 2 Milwaukee M18 impacts though, either the mid torque or the high torque versions. Smaller size, more power vs. their Gen 1. Supposed to be coming out ASAP.
What ever brand you go with, plan a few tools out. Makes it easier/affordable to buy just the tool when you already have the battery and charger at home.
18 VS 20 volts is just marketing. It just depends on how the voltage is measured. 5 cells x 4.2 max volts for 20vdc, or 5 cells x 3.6 volts nominal for 18vdc.
Like TRAV said , cordless is not a replacement for air. As a professional I use both at about 60/40 air to cordless. If you are a DIY guy and keep your projects simple then cordless might be a good choice. One thing about buying cordless is to look at what you need them to do for you. If you are gearing more for automotive diy , then Milwaukee certainly fits the bill. Milwaukee M18 and M12 lines offer impressive automotive tools i.e ratchets and impact wrenches. Makita and DeWalt are great choices as well , just with less automotive diy friendly tools. I own the Milwaukee M18 full size impact , Ive got no complaints about it.
