Storing Car Outside
by Delta. 09/21/18 10:47 AM
Looking at a cheap commuter!
by ryan2022. 09/21/18 09:46 AM
Does Your 3.5EB Make Oil
by Gene K. 09/21/18 09:07 AM
F150 Front Differential
by hatt. 09/21/18 08:45 AM
EU version of Subaru 2.5 FB engine
by IMPALA08. 09/21/18 08:40 AM
New “rules” changing your choice of car?
by daves87rs. 09/21/18 06:04 AM
WIX51334XP Oil Filters
by CB900F2. 09/21/18 05:14 AM
Signal Oil Company radio advertising
by 21Rouge. 09/21/18 04:07 AM
Anyone "Wim Hof"ing ?
by Shannow. 09/21/18 02:35 AM
New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
ScottRousell, Direct_Rejection, donatom, Sylent_Snyper, Ajizzle
66034 Registered Users
94 registered members (2015_PSD, 2013ecof150, andyd, 9050lx, 2010Civic, 9 invisible), 1,653 guests, and 40 spiders.
Topics290,754
Posts4,849,705
Members66,034
Most Online3,590
Jan 24th, 2017
Valvoline SynPower Dexos1 Gen2 PDS - 9/22/17 #4534696
10/05/17 03:27 PM
10/05/17 03:27 PM
Kendall, FL
wemay Offline OP
wemay  Offline OP
Kendall, FL
'18 KIA Sportage LX AWD: Mobil Super Synthetic 10w30
'13 Hyundai Santa Fe Sport 2.0T: EDGE 5w30
Re: Valvoline SynPower Dexos1 Gen2 PDS - 9/22/17 [Re: wemay] #4534723
10/05/17 04:02 PM
10/05/17 04:02 PM
Danh Offline
Danh  Offline
Thanks for posting.
Two questions:
1) With the proliferation of DI/TGDI engines and resulting fuel dilution, why are reformulated oils becoming "thInner" at operating temperature? Can't imagine this is a consequence of the Dexos1 Gen2 requirements.
2) As an 0w-20 presumably requires better base stocks than a 5w-20, why is the Noack volatility of 0w-20 so much higher than the 5w-20?
As an 0w-20 user, I'll pass.
Re: Valvoline SynPower Dexos1 Gen2 PDS - 9/22/17 [Re: wemay] #4534745
10/05/17 04:28 PM
10/05/17 04:28 PM
New England
Virtus_Probi Offline
New England
M1 5W30 AP has a Gen 2 license # and is quite thick at 100C for a 5W30, 11.7cSt...HTHS is only 3.0, though.
As for 0W20 vs. 5W20, I'd guess the former has more VIIs and/or pour point depressants that contribute to a higher NOACK loss. I would welcome a formulator correcting me on that if I'm full of it.
2014 Forester XT, 86000 miles
Last Change;
M1 5W30 d1G2
Tokyo Roki 15208AA170 filter
Re: Valvoline SynPower Dexos1 Gen2 PDS - 9/22/17 [Re: Virtus_Probi] #4534762
10/05/17 04:44 PM
10/05/17 04:44 PM
Kendall, FL
wemay Offline OP
wemay  Offline OP
Kendall, FL
My thoughts on that as well.
Re: Valvoline SynPower Dexos1 Gen2 PDS - 9/22/17 [Re: Virtus_Probi] #4534765
10/05/17 04:46 PM
10/05/17 04:46 PM
Danh Offline
Danh  Offline
Guess that's my point: why would Valvoline formulate its 5w-30 @ 10.2 when Mobil chooses 11.7? In DI/TGDI applications the Valvoline product is a lot more likely to dilute to a 20-weight. The Valvoline/Mobil gap is narrower in 20 weights but still significant: 8.2 vs 8.7 cSt.
Re: Valvoline SynPower Dexos1 Gen2 PDS - 9/22/17 [Re: wemay] #4534770
10/05/17 04:55 PM
10/05/17 04:55 PM
Kendall, FL
wemay Offline OP
wemay  Offline OP
Kendall, FL
I wish Valvoline supplied HTHS numbers and M1, Noack. Can't have everything i guess.
Re: Valvoline SynPower Dexos1 Gen2 PDS - 9/22/17 [Re: wemay] #4534841
10/05/17 06:30 PM
10/05/17 06:30 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
That is exactly what I wish for, then you can compare products. Still I would happily use any of the big names SynPower, M1, Edge, SOPUS (PP, SHU).
These new SynPowers all look good. They all carry good TBN (9.3), good zinc (830 ppm) and the same SA (0.97 %). In terms or Noack volatility the 5W20 ( 7.6 %) and 10W30 (8.0 %) are both fairly low. The 5W30 wins on specs being both Dexos1-Gen2 and Euro A5/B5, and it's Noack of 9.3% is still under 10% which would do me fine.
Thanks for posting.
Penrite Vantage 10W40 SN & A3/B4 + Wesfil-Cooper Z154
Re: Valvoline SynPower Dexos1 Gen2 PDS - 9/22/17 [Re: Danh] #4534847
10/05/17 06:36 PM
10/05/17 06:36 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
Quote:
M1 5W30 AP, 11.7cSt...HTHS is only 3.0,
The way I see it, any oil that has a higher KV100 but a lower HTHS is probably heavily loaded with VII's and more prone to shear and probably has a higher Noack.
Re: Valvoline SynPower Dexos1 Gen2 PDS - 9/22/17 [Re: SR5] #4534928
10/05/17 08:27 PM
10/05/17 08:27 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
I bet you are correct in that SR5. Always great to see you on here.
Thank you Wemay for this information here. You are a true good help on here. Always good to see you on here too.
Nissan Altima 3.5 Coupe
Quaker State High Mileage 5w30 Purolator Boss 14610
"Treat your family like your friends and treat your friends like your family."
Re: Valvoline SynPower Dexos1 Gen2 PDS - 9/22/17 [Re: wemay] #4535147
10/06/17 06:17 AM
10/06/17 06:17 AM
NE Ohio
knerml Offline
knerml  Offline
NE Ohio
wemay,
Noticed you are using Synpower on your Sonata and Synpower Maxlife on your Santa Fe Turbo.
Why not use the same type of oil, other than viscosity, in both?
Also, why Fram over OEM filters?
I maintain 4 Kias and Hyundais with variations of these engines, and just looking for others' insights.
Thanks.
2015 Hyundai Elantra Sport 2.0 GDI Mobil 1 5W20 & OEM/Mann W811/80 Filter
2018 Hyundai Santa Fe Sport 2.0T Castrol Edge 5W40 & OEM/Mann W811/80 Filter
Re: Valvoline SynPower Dexos1 Gen2 PDS - 9/22/17 [Re: wemay] #4535175
10/06/17 06:58 AM
10/06/17 06:58 AM
Kendall, FL
wemay Offline OP
wemay  Offline OP
Kendall, FL
Hi knerml,
https://www.valvoline.com/our-products/compare-motor-oil
According to Valvoline (see link above), "Valvoline Full Synthetic w/Maxlife Technology" is supposed to be their top flight option. But I'll use either. Valvoline also happens to be my favorite brand. They've always been prompt at answering questions via phone or email so they still earn my $ even when a little more expensive. Mobil1 has been good at this too.
I've now owned four Hyundai myself, never had an oil filter issue (weird noises or rattling as described in some TSBs) using aftermarket brands. But i still use OEM as well.
Re: Valvoline SynPower Dexos1 Gen2 PDS - 9/22/17 [Re: wemay] #4535177
10/06/17 06:59 AM
10/06/17 06:59 AM
Soviet State of Washington
PimTac Online content
PimTac  Online Content
According to PQIA, NOACK for Valvoline Synpower 0w-20 was 11.6. That was March of this year and pre Gen2 though.
I would also like to find out wemay' reasoning for running those oils especially the TGDI.
2017 Mazda CX-5 Grand Touring
Valvoline Advanced Synthetic 0w20
Mobil 1 M108A EP filter
Re: Valvoline SynPower Dexos1 Gen2 PDS - 9/22/17 [Re: wemay] #4535198
10/06/17 07:55 AM
10/06/17 07:55 AM
NE Ohio
knerml Offline
knerml  Offline
NE Ohio
I think the noise issue is mainly from the 6 cylinder engines.
Re: Valvoline SynPower Dexos1 Gen2 PDS - 9/22/17 [Re: wemay] #4537588
10/08/17 10:48 PM
10/08/17 10:48 PM
Quick question on this; I was comparing the new PDS for Synpower 0w-20 against the old one. The KV40 is now 42.2 and the kv100 is 8.1. The old numbers were kv40 47. and kv100 8.8. This seems like a big change. Other numbers have also changed like the pour point which is now -39c versus the older pp of -45c.
What does this all add up to for a lay person? A thinner oil?
Re: Valvoline SynPower Dexos1 Gen2 PDS - 9/22/17 [Re: SR5] #4540875
10/12/17 06:22 AM
10/12/17 06:22 AM
Kendall, FL
wemay Offline OP
wemay  Offline OP
Kendall, FL
Thanks for posting.
+1
