Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
Clutch Engaging too low
by Spetz. 09/23/18 09:41 PM
SMA - Krown previously, Fluid Film Application
by StevieC. 09/23/18 09:21 PM
First Paint Correction
by RayCJ. 09/23/18 08:33 PM
2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
Counterfeit MANN filter???
by IllinoisSparky. 09/23/18 06:54 PM
The smell of an oil: VME adds?
by fdcg27. 09/23/18 06:48 PM
Classic road brake pads
by buck91. 09/23/18 06:18 PM
Air up your vehicle's tires
by Papa Bear. 09/23/18 06:07 PM
A cool litttle Fall foliage site
by Papa Bear. 09/23/18 06:02 PM
Suggestion: "Likes"
by SnowDrifter. 09/23/18 05:36 PM
Condensation in headlights?
by irv. 09/23/18 05:06 PM
Nissan VQ V-6 Engines
by Al. 09/23/18 04:57 PM
List of dexos licensed oils?
by k1xv. 09/23/18 04:24 PM
High flow oil pump? Thinner oil?
by SnowDrifter. 09/23/18 04:06 PM
Lilshady, SevenDu, sigpro, RayCJ, yellow97tt6spd
66055 Registered Users
40 registered members (Ag76, Bailes1992, BKlab, Blkstanger, AndyB, 4 invisible), 1,022 guests, and 35 spiders.
Topics290,918
Posts4,852,501
Members66,055
Most Online3,590
Jan 24th, 2017
painting around door window inserts #4534661
10/05/17 02:29 PM
10/05/17 02:29 PM
indianapolis in
bmwjohn Offline OP
bmwjohn  Offline OP
indianapolis in
Hi: I have 2 typical prehung doors, Mastercraft brand, and they both have window inserts. They have screws in a plastic frame around the glass. It looks like unscrewing the plastic frame and painting it seperately would be the best thing, but store says if I unscrew the frame glass might fall out and I will have to recaulk the glass anyway. Correct? Suggestions?
Re: painting around door window inserts [Re: bmwjohn] #4534670
10/05/17 02:43 PM
10/05/17 02:43 PM
PV Az
AZjeff Offline
AZjeff  Offline
PV Az
I'd take the screws out, holding the glass and see what happens. Can you see caulk behind frame? If you can't get it off and it's a multi-pane looking insert there's a liquid mask product that could make the job easier than masking.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: painting around door window inserts [Re: AZjeff] #4534709
10/05/17 03:45 PM
10/05/17 03:45 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
Get a helper in case the window wants to fall out after you loosen the screws.
2015 Grand Caravan SXT Plus 5w-20 PPPP/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: painting around door window inserts [Re: bmwjohn] #4534714
10/05/17 03:54 PM
10/05/17 03:54 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Why not just tape off the plastic window frame?
Re: painting around door window inserts [Re: bmwjohn] #4534767
10/05/17 04:48 PM
10/05/17 04:48 PM
North TEXAS
oldoak2000 Offline
oldoak2000  Offline
North TEXAS
Just paint it (brush), then use razor-blade to easily scrape paint off of glass . . . works!
Re: painting around door window inserts [Re: bmwjohn] #4534852
10/05/17 06:44 PM
10/05/17 06:44 PM
Cincinnati, USA
Dave9 Offline
Dave9  Offline
Cincinnati, USA
No need to remove it, masking tape and newspaper over the glass, OR if you have a lot of painting experience, it can be faster to just hold a thin piece of cardboard (or sheet metal tool made for this) up against the edge, moving it along as you paint.
Re: painting around door window inserts [Re: oldoak2000] #4535235
10/06/17 08:54 AM
10/06/17 08:54 AM
Northern Arizona
funflyer Offline
funflyer  Offline
Northern Arizona
That's exactly what do. I first clean the glass before I paint using 0000 steel wool and glass cleaner.
2016 Prius 1.8L
2001 Tacoma 2.4L
1966 GTO 6.5L
2015 Cub Cadet
Honda CT70 (X6)
