I'm fixing to buy a set of Bridgestone tires and I'm trying to remember... it is the little yellow circle on the sidewall that needs to be aligned with the valve stem or the little white circle?
The tire manufacturer claims they place a little circle on the side way and if it is lined with the valve stem then the tire / wheel will be closer to being balanced even before taking it to the balance machine... which results in less weight to balance the tire / wheel combination.
I just couldn't remember if it was the little yellow circle or the little whiter circle?
