18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
Recommend on oil for 2017 Kia Sportage 2.4
by SlavaB. 12/17/18 02:57 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
97 registered members (25ring, 2012AccentSE, 97prizm, aba4430, 08z06, 2009Edge, 11 invisible), 1,545 guests, and 33 spiders.
Topics295,210
Posts4,930,000
Members66,711
Most Online2,553
Oct 27th, 2018
Harbor Freight Generator #4534388
10/05/17 07:39 AM
10/05/17 07:39 AM
Baltimore, MD
racer12306 Offline OP
Baltimore, MD
A coworker had a little 800W 2 stroke generator sitting around. It used to work fine, but lately he wasn't able get it started so asked if I wanted it. I'm a little more mechanically inclined than he is I believe, so I took it home yesterday to see if I will be able to get it running.
Should be a fun project this weekend.
16 Ford Focus/2.0/6A
04 Dodge Neon SXT/2.0/MTX
17 Chrysler Pacifica/3.6/9A
Re: Harbor Freight Generator [Re: racer12306] #4534391
10/05/17 07:41 AM
10/05/17 07:41 AM
Upstate NY
Donald Online content
Donald  Online Content
Upstate NY
Don't spend too much $$ on getting it working.
2015 Ford F250 w/Powerstroke
Re: Harbor Freight Generator [Re: racer12306] #4534392
10/05/17 07:41 AM
10/05/17 07:41 AM
Onondaga County
Miller88 Offline
Miller88  Offline
Onondaga County
It's the fuel shutoff.
The one on mine doesn't work 100%. If I leave it off for more than a week with the fuel "on", it won't start unless I pull the plug and clean it off. And spray in some starting fluid.
OR ... the fuel is shut off and you are trying to start it. Mine will run with the fuel shut off ... but won't be able to get enough fuel to restart.
18 Forester 2.5I 6M
00 Jeep Cherokee
01 Ford F-350 XL 4x4 5M
Re: Harbor Freight Generator [Re: racer12306] #4534424
10/05/17 08:06 AM
10/05/17 08:06 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I fix a lot of these.
Usually just a gummed up carb from ethanol fuel.
Re: Harbor Freight Generator [Re: racer12306] #4534431
10/05/17 08:15 AM
10/05/17 08:15 AM
Jupiter, Florida
Cujet Online content
Cujet  Online Content
Jupiter, Florida
Known issues include crummy original spark plug, fuel line degradation and fuel shut off valve failure.
These things should be addressed even on new machines!
Re: Harbor Freight Generator [Re: racer12306] #4534434
10/05/17 08:23 AM
10/05/17 08:23 AM
Port Orange, Florida
Panzerman Offline
Panzerman  Offline
80% of the time it's a dirty carb due to ethanol and failure to treat the gas.
I had one bad spark plug once in a Honda that threw me for a loop because that never happens until it did.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: Harbor Freight Generator [Re: racer12306] #4534447
10/05/17 08:32 AM
10/05/17 08:32 AM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
I'm not a fan of Seafoam in a modern auto engine, but for this project I think you should consider using it. Drain the tank, add fresh gas with the Seafoam in it. Then try getting it running. In addition to some lube and cleaners, the IPA removes water and seems to give small engines an octane boost.
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 152k ST HM 10w30
Re: Harbor Freight Generator [Re: racer12306] #4534515
10/05/17 10:05 AM
10/05/17 10:05 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
There is a bolt with a 10mm head that holds the bowl onto the carb. take it and the bowel off. then poke wire through the jets etc. That and get ride of the chinese spark plug.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Harbor Freight Generator [Re: racer12306] #4534573
10/05/17 11:44 AM
10/05/17 11:44 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
Like any cheap Chinese import OPE, the plastic and rubber parts are the weakest areas. Replacement carburetors and recoil assemblies are cheap and easy to mail order. Check the spark plug on it too. It's probably the original no-name piece of garbage. Replace it with a name brand, try fresh pre-mix and give it a go. Luckily these are pretty simple and cheap enough to keep a new one in the box for when you need it. These little 800-1000w guys are nice to have. They're fairly quiet and fuel efficient for a 2-stroke.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Harbor Freight Generator [Re: racer12306] #4534678
10/05/17 01:54 PM
10/05/17 01:54 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Old 2stroke gasoline....2strokes are very sensitive here! Or gunked carburetor!
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Harbor Freight Generator [Re: racer12306] #4534732
10/05/17 03:08 PM
10/05/17 03:08 PM
Canada
boraticus Offline
boraticus  Offline
Canada
If it has reliable spark and reasonable compression Clean the carb.and the exhaust. Also replace the spark plug if the spark isn't there or weak.
Re: Harbor Freight Generator [Re: Panzerman] #4534738
10/05/17 03:14 PM
10/05/17 03:14 PM
Canada
boraticus Offline
boraticus  Offline
Canada
Stangely enough, I had two recent incidents with spark plug failure. My Jonsereds 630 chain saw wouldn't fire so I swapped out the plug from my 670 and the 630 fired right up.
This spring, my 2006 Arctic Cat 500 failed to fire after sitting all winter. I changed the plug and it fired right up. Considering my decades of experience with dozens of pieces of equipment and only one previous spark plug failure some 30 years ago, I found this to be very unusual. To make things even more perplexing was that both plugs were NGKs.
Re: Harbor Freight Generator [Re: racer12306] #4535386
10/06/17 11:37 AM
10/06/17 11:37 AM
Baltimore, MD
Baltimore, MD
Thanks for the tips.
Re: Harbor Freight Generator [Re: racer12306] #4551773
10/23/17 08:09 AM
10/23/17 08:09 AM
Baltimore, MD
Baltimore, MD
Minor update, haven't had a bunch of time work really dig in, but I have done a couple diagnostic things that lead me to believe the carburetor needs a good cleaning.
I drained the tank and dumped some TruFuel in it and it will start and run on starting fluid but won't run on it's own.
Re: Harbor Freight Generator [Re: racer12306] #4552472
10/23/17 08:38 PM
10/23/17 08:38 PM
Watertown, New York
cronk Offline
cronk  Offline
Watertown, New York
Avoid using starting fluid in a 2 stroke. Since there is no oil in it like there is with 2 stroke mixed fuel, it is basically like running the engine with no oil.
2008 Ford F350
2003 Chevy Cavalier
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
