Can't get Unifi AP V2 to work on TDS...
by WhizkidTN
50 minutes 9 seconds ago
Need mini grease gun
by Duffyjr
Today at 07:02 AM
Mazda 6 O2 sensor - CA emission
by Chester11
Today at 06:57 AM
Brake Bleeder
by supton
Today at 06:56 AM
As close to blowing out as you can get
by wwillson
Today at 06:04 AM
changing tranny filter
by Dennisistheman
Today at 06:04 AM
From small things...
by Silk
Today at 05:57 AM
Anyone signing up for the Space Force
by Shannow
Today at 03:58 AM
Pennzoil Platinum at Walmart
by TheLawnRanger
Yesterday at 11:21 PM
Mopar OEM and Fram Ultra Oil filters, '18 Jeep JL
by IndyFan
Yesterday at 10:45 PM
What’s the odds..
by Eric Smith
Yesterday at 09:51 PM
Who can relate?
by Reddy45
Yesterday at 09:43 PM
No more oil changes
by goodtimes
Yesterday at 09:19 PM
Separating toddlers from their parents?
by fdcg27
Yesterday at 08:50 PM
gm 8.6 truetrac
by Spitter
Yesterday at 08:45 PM
New addition to my garage: 2000 Corvette FRC
by MrHorspwer
Yesterday at 08:34 PM
Rockauto 5% off
by Spitter
Yesterday at 08:32 PM
fumoto oil valve
by Santo
Yesterday at 08:19 PM
Grand solar minimum...
by ridgerunner
Yesterday at 07:57 PM
Pentofrost coolant $10 Autozone
by PD001
Yesterday at 07:49 PM
Theraven, battleman13, Shassis, Santo, aligoodn
65276 Registered Users
100 registered (2004tdigls, andyd, 2009Edge, aquariuscsm, 14ecocruze, 12 invisible), 1266 Guests and 40 Spiders online.
65276 Members
67 Forums
285637 Topics
#4534252 - 10/05/17 12:28 AM Briggs & Stratton 799868 Carburetor
Merkava_4 Offline
Loc: Clovis, CA
Can you imagine; $7.98 for a carburetor ? ebay link
You might say, don't buy a Chinese knock off, but the O.E.M. carburetor is made in China too. shrug
Is the Genuine Briggs & Stratton carburetor (which is made in China) better quality ? ???
Genuine Briggs & Stratton, $39.99 ebay link
#4534277 - 10/05/17 04:24 AM Re: Briggs & Stratton 799868 Carburetor [Re: Merkava_4]
Lubener Offline
Loc: N.Ohio
A basically obsolete carb. which has little to go wrong with it compared to the diaphram carbs mostly seen today.
The "thinking" man's friend.
#4534300 - 10/05/17 06:04 AM Re: Briggs & Stratton 799868 Carburetor [Re: Merkava_4]
danez_yoda Offline
Loc: texas
In one-off cases I spend the ransom money so I can sleep. If there is any engine problem after replacing the carb you will kick yourself blaming the cheap carb for a leak (running lean) or loose particle getting out and scoring the cylinder walls.
#4534359 - 10/05/17 07:18 AM Re: Briggs & Stratton 799868 Carburetor [Re: Merkava_4]
philipp10 Offline
Loc: Minnesota
These cheap carbs are fine. My brother buys them all the time.
#4534372 - 10/05/17 07:47 AM Re: Briggs & Stratton 799868 Carburetor [Re: philipp10]
Linctex Offline
Loc: Waco, TX
The Tecumseh carbs retain all three adjustment screws. They are OK, not perfect - but the original Tecumseh carbs are usually [censored] anyway.
Good to know!
#4534403 - 10/05/17 08:54 AM Re: Briggs & Stratton 799868 Carburetor [Re: Merkava_4]
nwjones18 Offline
Loc: Warner Robins, GA
I've had good luck with the cheap carbs on mowers, generators and my old honda ATC200.
1988 F-150. 4.9 I6 247k. 10w-40 Castrol Syn-blend ACDelco UPF2.
2005 Cadillac STS N* 108k. 5w-30 Castrol Magnatec ACDelco Classic PF61
#4534439 - 10/05/17 09:26 AM Re: Briggs & Stratton 799868 Carburetor [Re: Merkava_4]
Panzerman Offline
Loc: Port Orange, Florida
The diagram carbs aren't always direct replacement sometimes you have to change the throttle or choke hook up which involves changing parts from the old carb. I bought a Honda replacement carb once and there was a big weight difference between it and the original Honda carb. It worked but the quality was poor.
Edited by Panzerman (10/05/17 09:26 AM)
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
#4534444 - 10/05/17 09:31 AM Re: Briggs & Stratton 799868 Carburetor [Re: Merkava_4]
Bgallagher Offline
Loc: Boston, MA
it is a carb for OPE. If it doesn't work buy another and slap a new one on. For that price go for it.
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
#4534568 - 10/05/17 12:31 PM Re: Briggs & Stratton 799868 Carburetor [Re: Merkava_4]
jeepman3071 Offline
Loc: Storrs, Connecticut
I replace a lot of carbs for customers.
I've found it is best not to buy the CHEAPEST one, but maybe the one that is a few notches up from the cheapest. I've installed many of the really cheap ones only to have the jets not be properly drilled out and the engine runs like garbage. It isn't a big problem with Briggs and Honda carbs, but Tecumsehs seem really sensitive to minor adjustments and any problems with a new carburetor will cause issues.
Luckily with Tecumsehs there is usually a wide variety to pick from on eBay, so I pick the $20 dollar carb instead of the $8 one. Judging by the pictures you can also tell if everything is really cheap. For me, the extra couple bucks is negligible, and means less time the machine is sitting in my garage half apart since I don't usually have to send them back.
2000 Jeep Cherokee 4.0L (179k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (32k) - Castrol Edge Euro 0w40, MANN HU816X
#4534589 - 10/05/17 01:01 PM Re: Briggs & Stratton 799868 Carburetor [Re: Merkava_4]
JTK Offline
Loc: Buffalo, NY
I'm on my second $20 eBay carb for my 18hp Briggs 31P777 series engine in matter of weeks. When I received the first one, it wasn't packaged well and the choke plate and plastic choke plate shaft were dislodged from the carb body. I got it back together, but the choke shaft broke after a few weeks allowing the choke plate to suck into the carb a bit! I stuck the OEM choke assy in it, but the shaft binds too much. 2nd replacement is intact, but I have to get out there and get it installed. Like said above, these Chinese carbs are identical looking in every way to the OEM. There's not a single marking or p/n on them, but they mostly match right up.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
#4534601 - 10/05/17 01:19 PM Re: Briggs & Stratton 799868 Carburetor [Re: JTK]
jeepman3071 Offline
Yep, definitely be careful and make sure everything is tight when buying a Chinese carb. I had a Briggs come in a few months ago. Owner bought a new carb and slapped it on. The screws started loosening on the butterfly, and one came out and went into the engine. The screw nicked the intake valve and scored the cylinder a bit. Luckily a new intake valve and some valve lapping got it back to running shape.
#4534659 - 10/05/17 02:27 PM Re: Briggs & Stratton 799868 Carburetor [Re: jeepman3071]
JTK Offline
Loc: Buffalo, NY
^ Great advice on checking all screws, etc. I just installed my 2nd replacement and mowed with it for 30min or so. The electrical connector for the fuel shut-off solenoid doesn't snap-in and lock quite right on replacement carb #2, but she runs nice. Idle isn't quite right, but I don't really idle it anyway. There is a single mixture screw on these carbs, but I can't seem to get them dialed in like the OEM carb was.
#4534721 - 10/05/17 04:01 PM Re: Briggs & Stratton 799868 Carburetor [Re: Merkava_4]
bubbatime Offline
Loc: South Florida
When I had my small engine shop I bought and used hundreds of these cheap Chinese carbs. I often found them to be BETTER than the OEM carb. The OEM carbs are coming with super small (lean) jets due to EPA guidelines, which makes them surge or run terribly. It seems to me that the cheaper Chinese carbs often have larger jets which makes them run like the engine is supposed to. The OEM carbs will have sealed mixture screws as well. The cheap Chinese ones are often not sealed, so they are adjustable.
So DEFINITELY buy that $7 carburetor. It will be fine.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
12 Suzuki S40 Rotella 15W40
10 Acura TSX 2.4 PZL Plat 5W30
06 GMC Sierra Nextgen 10W30
