Rotella 10W40
by jakewells
06/19/18 10:43 AM
Extend WiFi Range at the Laptop?
by clarkflower
06/19/18 10:40 AM
Silicone containing waxes
by mjoekingz28
06/19/18 09:44 AM
Matrix totaled
by circuitsmith
06/19/18 08:32 AM
Door rust problems
by Dave Sherman
06/19/18 07:51 AM
2016 Honda Civic problems
by dbias
06/19/18 07:39 AM
Royal purple 75-140 in a subaru rear
by 91camarosRS
06/19/18 07:32 AM
OCI. With short trips. Nissan 4 liter
by Gawardawg
06/19/18 06:52 AM
Approach Watching on the Beach @ St Maarten ...
by LoneRanger
06/19/18 06:41 AM
Honda Accord Needs Shocks; Front, Back, or Both?
by tc1446
06/19/18 05:50 AM
How much oil does your oil filter hold?
by Snagglefoot
06/19/18 05:44 AM
better day
by mx5miata
06/19/18 05:26 AM
BRAVO to Officer Wheeles......
by Sayjac
06/19/18 05:17 AM
People Watching ....Airport style.
by ZZman
06/19/18 04:24 AM
Subaru's at play...
by OneEyeJack
06/19/18 03:50 AM
Treating a 2003 Jetta
by llmercll
06/19/18 01:41 AM
Brakes not working - brake pedal sinks
by tookien
06/19/18 12:42 AM
Dave thinks I can make it 12--15k
by Marco620
06/19/18 12:26 AM
'05 Impala front wheel "squeal". Cost !
by Lee4212
06/19/18 12:16 AM
One Dollar Per Gallon?
by Y_K
06/18/18 11:53 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
92 registered (Andy636, ArrestMeRedZ, 853okg, 2strokeNorthstar, 2015_PSD, 8 invisible), 1616 Guests and 43 Spiders online.
65265 Members
67 Forums
285589 Topics
Page 1 of 2 1 2 >
#4534227 - 10/04/17 10:52 PM When mounting a tire...
Rockrz Offline
Loc: State
I'm fixing to buy a set of Bridgestone tires and I'm trying to remember... it is the little yellow circle on the sidewall that needs to be aligned with the valve stem or the little white circle?
The tire manufacturer claims they place a little circle on the side way and if it is lined with the valve stem then the tire / wheel will be closer to being balanced even before taking it to the balance machine... which results in less weight to balance the tire / wheel combination.
I just couldn't remember if it was the little yellow circle or the little whiter circle?
#4534230 - 10/04/17 10:57 PM Re: When mounting a tire... [Re: Rockrz]
FordBroncoVWJeta Offline
Loc: KS
It will sometimes have a red and a yellow dot. Always red dot. If just a yellow dot then do yellow. Im pretty sure the white dots are manufacture dots.
17 Volkswagen Jetta 1.4T
15 Honda CRV 2.4
12 Volkswagen Jetta 2.0
01 Pontiac Sunfire 2.2
#4534269 - 10/05/17 03:17 AM Re: When mounting a tire... [Re: Rockrz]
ArcticDriver Offline
Loc: USA
Are you mounting these yourself?
If not then the tire shop knows the proper procedure.
Multiple Diesel and Gasoline vehicles
#4534284 - 10/05/17 04:55 AM Re: When mounting a tire... [Re: ArcticDriver]
demarpaint Offline
Loc: NY
One would hope......After having Mavis Tire ruin not one but four of my center caps during a tire replacement job I have my doubts. Knowing the proper procedure could help the OP know if the job was done correctly. Some of these high volume tire shops hire some real gems for help.
God Bless Our Troops
#4534289 - 10/05/17 05:22 AM Re: When mounting a tire... [Re: Rockrz]
Superflan Offline
Loc: Reunion Island
This. I see many tire shops mount tires in a random orientation, not aligning red dot to the valve hole at all. Frustrating me to see that or to drive knowing it. Iím still OCD on this...
Yaris 1.0 201mkm 5W40 ACEA A3/B4
Kangoo 1.5 DCi 15W40 ACEA E7
Wife's Koleos 2.0 dCi DPF 6AT eco-map 162mkm 5W40 C3
#4534311 - 10/05/17 06:18 AM Re: When mounting a tire... [Re: Rockrz]
CapriRacer Offline
Loc: Somewhere in the US
Rockrz,
First, matching dots is about uniformity (think out-of-round and you'll be close). It's NOT about balance.
Second, there is no universal standard. Each tire manufacturer does his own thing and it even varies from plant to plant. For example, (if I remember correctly) BMW and Mercedes require white dots, where Ford requires fluorescent green.
And it's the same for wheels.
- BUT -
The most common dot usage is a red dot that is matched up to the valve hole. Just keep in mind that this might not be doing any good. It won't be doing anything bad, but it just may be a waste of time and effort.
CapriRacer
Visit my web site: www.BarrysTireTech.com
#4534330 - 10/05/17 06:50 AM Re: When mounting a tire... [Re: Rockrz]
Traction Offline
Loc: iowa
After lining up the dot with the valve stem mostly for looks, I've had to break it back down and move it opposite the valve stem many times to true up the tire anyway. Plus whatever dot marking they use, there is no way to know how much weight or run out you are even dealing with. Could be very little, or a lot. Most tires are not even marked, so I don't think it is a big deal to put the dot anywhere in most cases. If you look at some of the OE tires that are marked, the red dots are never lined up with the valve stem, but a sticker on the wheel that is usually long gone when installing replacement tires.
Edited by Traction (10/05/17 06:54 AM)
Tire Industry Association Certified Tire Service Instructor since 2009
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
12 Camry
81 Camaro
55 Chevy C4
#4534413 - 10/05/17 08:58 AM Re: When mounting a tire... [Re: demarpaint]
Loc: USA
Aha...I see the reason for your diligence then.
#4534417 - 10/05/17 09:00 AM Re: When mounting a tire... [Re: CapriRacer]
Loc: USA
Originally Posted By: CapriRacer
Rockrz,
- BUT -
I have found the green dots offer better rotational balance on the front but the reds are a clear winner on the rears.
#4534426 - 10/05/17 09:08 AM Re: When mounting a tire... [Re: Traction]
Seventh Offline
Loc: NorCal
This.
I mount BMW/Mini OE tires on the regular. I line up the dot when it's present (normally it's not), and there aren't any that have two dots.
#4534536 - 10/05/17 11:25 AM Re: When mounting a tire... [Re: Rockrz]
Rockrz Offline
Loc: State
Yes, the dots do actually mean something... they have smart balancing machines now tat tell you were to place the tire on the wheels for best match mounting so it takes as little weight as possible to balance the tire/ wheel assembly
Problem is, most tire shops just throw the weights on and don't match mount the tire to the wheel according to what the smart balance machine is saying to do so these guys are useless the majority of the time.
This is why I'm having my tires shipped in (free shipping, no sales tax = best deal) so I can mark where I want the tire to be positioned related to the valve stem to get it match mounted based on the marking the tire manufacturer puts on the tire... and I have my own computerized spin balancer and I will balance them myself.
If any of these call for a large amount of weight I will take that one to a shop with a smart balancer and insist they turn the tire on the rim according to the position the smart balancer is saying to put it at
Edited by Rockrz (10/05/17 11:27 AM)
#4535251 - 10/06/17 09:24 AM Re: When mounting a tire... [Re: Rockrz]
mightymousetech Offline
Loc: Ontario, Canada
Lining up to the valve stem hole really does nothing. Unless you still have the mark on the rim where to line the tire up to, it really does not make much difference. Our OEM rims come with a mark to line the yellow dot up to ( a yellow sticker) but that gets removed after the tire is installed. It is never at the valve stem.
Edited by mightymousetech (10/06/17 09:24 AM)
Mighty Mouse Tech
Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
#4535255 - 10/06/17 09:29 AM Re: When mounting a tire... [Re: Rockrz]
You can see the sticker here. The yellow dot on the tire is on the inside of the rim. To have all four yellow dots on the outside would mean having four tires for the left hand side only.
Mighty Mouse Tech
Acura Tech
#4535362 - 10/06/17 12:08 PM Re: When mounting a tire... [Re: Rockrz]
nthach Offline
Loc: California
From what a motorcycle mechanic told me, yellow dot lines up to the valve stem or the "heaviest" point on the wheel. Bridgestone does this quite a bit.
I don't see cars with markings on their wheels for the purpose of tire mounting, Honda does mark some of their steelies with a blue dot from the factory. I worked at a dealer eons ago, and I did see base model CR-Vs with blue dots on the wheel rims.
#4535980 - 10/07/17 07:56 AM Re: When mounting a tire... [Re: mightymousetech]
CapriRacer Offline
Thanks for the photo. That should prove that the valve hole isn't always the low spot of the wheel.
And just so everyone understands, the matching of dots is about runout, not balance. It's used to make a *rounder* assembly.
And another FYI - I don't know of any automobile manufacturer who doesn't match mount - and I'll bet that if you watch as they unload cars off the transporter, you'll see these dots that we have been talking about (If they are large like the ones on the photo, they are supposed to be removed during presale prep.)
Oh and while I don't know that anyone is using this system, but I have seen marks that are only visible using black light.
CapriRacer
Page 1 of 2 1 2 >
