AAP 25% Off
by Egg_Head
06/22/18 06:03 AM
GM Ecotec 2.4 - Cracked Exhaust Manifold
by The Critic
06/22/18 05:05 AM
Half Price - Shell Helix HX7, Castrol Edge and GTX
by SR5
06/22/18 03:59 AM
Why hang your bicycle from the ceiling?
by mjoekingz28
06/22/18 03:47 AM
Oil For High Sustained RPM on BMW S52
by ZEK
06/21/18 10:41 PM
Chevy brought the blazer back
by WiskyBadger
06/21/18 10:07 PM
LC20 and uses in modern motor oil
by synman
06/21/18 10:01 PM
Full Synthetic CJ-4 or > 5W-30 or 10W-30
by LeTempt
06/21/18 09:57 PM
2018 RAM 1500 EcoDiesel
by OVERKILL
06/21/18 08:37 PM
Fram SureGrip coating
by mobilaltima
06/21/18 08:24 PM
Manual transmissioned electric car
by mjoekingz28
06/21/18 06:45 PM
1991 Toyota Previa New JDM engine Redline
by Kurtatron
06/21/18 06:26 PM
8 yr old channeling John Bonham
by Toy4x4
06/21/18 06:02 PM
Traveller nlgi 2
by Spitter
06/21/18 05:33 PM
Upgrading the Kohler 7000 series air cleaner
by Patrick0525
06/21/18 05:08 PM
Any nano reefers here?
by RichardS
06/21/18 05:04 PM
ARC remanufactured Power Steering Pump
by Pajero
06/21/18 04:58 PM
John Deere "Easy Change" System gimmick
by SnowmanCO
06/21/18 04:55 PM
Oz Planstic Bag Bans - not so green.
by Shannow
06/21/18 04:31 PM
help me choose...
by chaindrive
06/21/18 04:07 PM
Fatbrowndog0822, DRNJR, ZEK, Dudewayne, kmdz
65294 Registered Users
57 registered (billt460, cjcride, Astro14, BrewCityR, bullwinkle, ccs368, 4 invisible), 1017 Guests and 24 Spiders online.
65294 Members
67 Forums
285754 Topics
Page 1 of 2 1 2 >
#4534177 - 10/04/17 09:10 PM What technique to remove stuck bleeders?
ZZman Offline
Loc: Michigan
I am getting ready to flush my brake lines and have never done it before. I am expecting some stuck bleeders due to all the under vehicle rust. Youtube shows different techniques. What have you used that works well?
2003 Mercury Grand Marquis. Rotella T6 Multi-Vehicle oil
2008 Sebring Hardtop convertible. Rotella T6 Multi-Vehicle oil
2006 Kawasaki Vulcan 900 LT. Amsoil Metric 10w-40
#4534179 - 10/04/17 09:13 PM Re: What technique to remove stuck bleeders? [Re: ZZman]
maxdustington Offline
Loc: Toronna
I think it was Trav on here who recommended smacking the top of the bleeder with a hammer while applying rotational force with a box end wrench. Worked like a charm for me.
03 Jetta AWP/09A 200k kms
Edge 0W40 + Mann 719/30
#4534180 - 10/04/17 09:16 PM Re: What technique to remove stuck bleeders? [Re: ZZman]
michaelluscher Offline
Loc: Staten Island, NY
Soak with penetrating oil before starting
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
#4534185 - 10/04/17 09:21 PM Re: What technique to remove stuck bleeders? [Re: ZZman]
cpayne5 Offline
Loc: Virginia
I resort to penetrating oil and vise grips for bleeders that don't want to come out with a socket or wrench (ie, rounded off...). Wiggle it each way until you get some movement, then they usually will spin out without much trouble. You can also use some heat on it, if you have it.
#4534186 - 10/04/17 09:22 PM Re: What technique to remove stuck bleeders? [Re: ZZman]
3800Series Offline
Loc: Gulf Coast, MS
Be prepared to replace, they are fragile and even when done carefully they can still snap off.
#4534200 - 10/04/17 09:56 PM Re: What technique to remove stuck bleeders? [Re: ZZman]
andyd Offline
Loc: Marshfield , MA
I would start with a few passes with a wire brush. Then a spritz of penetrating oil. And the hammer tap.I have a 4 oz ball peen. Percussion works great. Be gentle, I have never successfully removed a sheared bleeder. If you remove the caliper, you could heat it up with a torch. Give the brake lines a hard look too. I quit messing with the bleeders on the Rat's front calipers when the bleeders started twisting apart and used them as cores for a pair of remans from Auto Zone. Please post follow up. TIA.
Thick oil is better grin2
#4534216 - 10/04/17 10:37 PM Re: What technique to remove stuck bleeders? [Re: ZZman]
blupupher Offline
Loc: Katy, Republic of Texas
if you are replacing the bleeders, then fill the hollow core with some aluminum.
Get a piece just longer and about the diameter of the bleeder screw opening (welding wire works great for this). Put it in then hammer it gently into place. This fills the hollow cavity with metal and reduces the chance of breakage. If it does break, aluminum is easily drilled out if you have to easy-out the bleeder screw.
1994 Honda VT1100C: Peak 15w-40/TG/2500 mile OCI
2002 Ford F150: GTX HM 5w-20/EcoGard Syn/1yr OCI
2012 Scion xB: QSUD 0w-20/CQ Blue/5k OCI
#4534248 - 10/05/17 12:12 AM Re: What technique to remove stuck bleeders? [Re: ZZman]
oldhp Offline
Loc: USA
Clean with wire brush, a dab of MMO or PB Blaster, let it sit 2-3 mins. Heat area around the bleeder with torch pretty good, as fast as you can, put ice on the bleeder screw. If it tings/pings, it should come right out. Always worked for me. Cheers2
#4534281 - 10/05/17 04:41 AM Re: What technique to remove stuck bleeders? [Re: ZZman]
dlundblad Offline
Loc: Indiana
When I did my truck's, (I am assuming it was never done as well.) I sprayed them with liquid wrench the week before. I did end up buying new anyways because the old ones looked pretty sad.
I think my bleeders are 8mm. I ended up using a long handled 3/8" ratchet with a 1/4" to 3/8" adapter. They came right off.
Edited by dlundblad (10/05/17 04:42 AM)
03 Jeep WJ 4.0 199k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 145k Rotella T5 10w30 Fram TG3980
#4534285 - 10/05/17 04:57 AM Re: What technique to remove stuck bleeders? [Re: ZZman]
Char Baby Offline
Loc: ROCHESTER, NY
Living where I personally believe that we use more road salt than anywhere in the world smile , I do what most others have said:
*Use a wire brush first!
*Then spray with your favorite penetrating lube long before you plan on trying to remove the bleeder.
*Once the bleeder is removed, replace with an new one. I keep extras around for this reason.
"Retired"
'06 Mazda 3i 2.0L
'15 Nissan Altima 2.5 SV
#4534342 - 10/05/17 07:03 AM Re: What technique to remove stuck bleeders? [Re: oldhp]
ZZman Offline
Loc: Michigan
Our city mechanic said something similar. Heat well and then pour cold water on it.
#4534348 - 10/05/17 07:09 AM Re: What technique to remove stuck bleeders? [Re: ZZman]
rollinpete Offline
Loc: West Ma.
This method works real well...
https://www.youtube.com/watch?v=XV85K8g6SCs
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive183k miles
Last Change;
Penn. Plat. HM 5w30
Fram xg8a, Fram CA8141
(Oil) Where would we be with out it.
#4534360 - 10/05/17 07:20 AM Re: What technique to remove stuck bleeders? [Re: ZZman]
Donald Offline
Loc: Upstate NY
And of course always use a 6 point wrench or socket.
2015 Ford F250 w/Powerstroke
#4534373 - 10/05/17 07:53 AM Re: What technique to remove stuck bleeders? [Re: ZZman]
buck91 Offline
Loc: West Michigan
Kroil or liquid wrench daily for a week if this is a Michigan car. I've had good results with drilling and using the bleeder repair kit. If the hydraulics are that neglected might just consider new calipers.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
#4534400 - 10/05/17 08:51 AM Re: What technique to remove stuck bleeders? [Re: ZZman]
LeakySeals Offline
Loc: Hudson, NH
If its just one, replace the entire caliper with a reman. Its easy to do, and remans are so cheap these days its not worth the aggravation of fiddling with a stuck or stripped bleeder..
06 Escalade 6.0L AWD 160k. M1 5w30 Fram TG
03 Maxima 3.5L 149k ST HM 10w30
Page 1 of 2 1 2 >
