BMW V8 Oil Consumption Fix
by doc540
06/18/18 11:25 AM
More info on Valvoline Modern Engine Oil
by buster
06/18/18 11:07 AM
Shelf life of synthetic 2 stroke engine oil ?
by ScottMill
06/18/18 10:34 AM
Oil sample extraction
by Tikka
06/18/18 10:30 AM
Re-using building materials esp nails
by andyd
06/18/18 08:57 AM
Central A/C [censored] out
by TOMJ
06/18/18 08:43 AM
08 Scion tC under valve cover pics
by Highboy
06/18/18 08:39 AM
Storing extension ladded in garage?
by maverickfhs
06/18/18 08:27 AM
Do you let your tool batteries go dead in storage
by Snagglefoot
06/18/18 07:20 AM
Any news on what happened to this plane?
by Exhaustgases
06/18/18 02:36 AM
E4OD fluid ?
by Exhaustgases
06/18/18 02:23 AM
Update password ?
by meadows
06/17/18 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
06/17/18 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
06/17/18 10:07 PM
ceratec with redline 5w30?
by 08z06
06/17/18 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
06/17/18 09:50 PM
I hate stuck thermostats
by jakewells
06/17/18 09:49 PM
Mag1 75w90
by SavagePatch
06/17/18 09:32 PM
WtsTacoma01, Orion62, Revd, blinky1041, mostdecent
65262 Registered Users
88 registered (1JZ_E46, 5AcresAndAFool, AndyB, aquariuscsm, 4WD, 8 invisible), 1653 Guests and 45 Spiders online.
65262 Members
67 Forums
285519 Topics
Page 1 of 2 1 2 >
#4534165 - 10/04/17 08:42 PM Winter storage in a carport?
OCDriver Offline
Loc: Canada
I've been debating in my head whether I want to pickup a winter beater and store my car, making it a spring/summer/fall car only. The only thing I have access to is a metal carport (where I currently park). I can pretty much seal up the ends with heavy duty tarp. The metal panels are ribbed, leaving a series of ~1 sq in. gaps between the frame and the panels. The floor is made up of concrete patio blocks, with a foot or so of dirt and/or gravel between the edges of the blocks and the bottom of the frame.
I've never stored a vehicle before. Is this a workable option or is it going to allow too much moisture to sit on the car?
#4534168 - 10/04/17 08:49 PM Re: Winter storage in a carport? [Re: OCDriver]
earlyre Offline
Loc: Lima, Ohio, USA
the real trouble isn't moisture, the moisture is bad enough, but for storage the problem is Rodents finding a home in your car. plugging the exhaust, chewing up the wiring, and chewing up the seat foam/ insulation for nesting material.
also their droppings can carry nasty diseases
to keep them out, you need to plug any openings bigger than a dime.
crafty little buggers they are.
last winter my brother rented a storage unit for his Challenger. cost him about $80/month.
Edited by earlyre (10/04/17 08:50 PM)
Mine:
09 Mercury Sable : 6qts AutoQuest(Meijer/Warren) 0w20, WIX 51516
Mine to Maintain:
03 Pontiac Vibe : 4.5qts VWB 5w30,WIX 51394
#4534183 - 10/04/17 09:20 PM Re: Winter storage in a carport? [Re: OCDriver]
Brybo86 Offline
Loc: Chicago, IL
Can you buy one of those bags you drive it into?
08 Honda Accord EX-L 2.4L M1 EP 0w20 145k
01 Kymco People 50
95 Lexus LS400 M1 AFE 0w30 193k
95 Yamaha Jog
#4534241 - 10/04/17 11:38 PM Re: Winter storage in a carport? [Re: OCDriver]
dparm Offline
Loc: Chicago, IL
Moisture won't be the problem. You will need to protect against rodents and bugs, as someone else mentioned. These are problems even in garages -- possibly worse because animals are looking for shelter during inclement weather and a garage is quiet and warm.
2017 Chevrolet Corvette Grand Sport
#4534244 - 10/04/17 11:50 PM Re: Winter storage in a carport? [Re: OCDriver]
Linctex Offline
Loc: Waco, TX
It needs to be up on four metal jackstands...
1) keeps rodents out
2) keeps tires off the ground
#4534255 - 10/05/17 01:02 AM Re: Winter storage in a carport? [Re: OCDriver]
daves87rs Offline
Loc: Michigan
When we lived in an apartment, my cav had a carport spot.
In my case, I just kept it out of the salt. If we got some rain to wash away the salt, the car moved around some to keep animals and stuff out of it. Car stayed safe when it needed to, but never sat for too long of a period of time.
Mine did just fine....
Coming together is a beginning; keeping together is progress; working together is success.
Henry Ford
#4534328 - 10/05/17 06:46 AM Re: Winter storage in a carport? [Re: Brybo86]
OCDriver Offline
Loc: Canada
Go on...
#4534357 - 10/05/17 07:16 AM Re: Winter storage in a carport? [Re: OCDriver]
Miller88 Offline
Loc: Onondaga County
I'm not sure if they have a specific name - but there are car tent bag things that you drive your car into for storage. Keeps the rain and moisture out.
18 Forester 2.5I 6M
00 Jeep Cherokee
01 Ford F-350 XL 4x4 5M
#4534365 - 10/05/17 07:32 AM Re: Winter storage in a carport? [Re: Linctex]
2010Civic Offline
Loc: Minnesota
That won't keep mice out. And leaving the suspension uncompressed is not good for the rubber bushings. If you put the jack stands under the suspension that would be fine. When I store my car for the winter I use an old set of steel wheels with junk tires. That way I can bring my tires/wheels inside the house and the car/suspension is in a natural state.
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Honda oil filter
54,061 miles
#4534368 - 10/05/17 07:39 AM Re: Winter storage in a carport? [Re: Linctex]
dparm Offline
Loc: Chicago, IL
No it doesn't. Rodents can still get in, and the suspension is not designed to be hanging like that for an extended period. Tire flat-spotting is not going to be an issue unless the car is sitting for years.
#4534376 - 10/05/17 07:56 AM Re: Winter storage in a carport? [Re: OCDriver]
ZZman Online   content
Loc: Michigan
Buy a car cover for extra protection. For mice buy dryer sheets and put them in trunk, under the hood and inside the car.
2003 Mercury Grand Marquis. Rotella T6 Multi-Vehicle oil
2008 Sebring Hardtop convertible. Rotella T6 Multi-Vehicle oil
2006 Kawasaki Vulcan 900 LT. Amsoil Metric 10w-40
#4534415 - 10/05/17 08:59 AM Re: Winter storage in a carport? [Re: OCDriver]
Leo99 Offline
Loc: NJ
what kind of car are you wanting to store instead of drive?
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles
2004 Rav4 359,000 miles
2015 Camry 59,000 miles
#4534418 - 10/05/17 09:02 AM Re: Winter storage in a carport? [Re: OCDriver]
ArcticDriver Offline
Loc: USA
Go on...
Please...
Multiple Diesel and Gasoline vehicles
#4534423 - 10/05/17 09:04 AM Re: Winter storage in a carport? [Re: ZZman]
Loc: USA
D-Con rat poison around the car works nicely.
After pack rat damage to my vehicles at the ranch it is a full on war...take no prisoners.
#4534435 - 10/05/17 09:24 AM Re: Winter storage in a carport? [Re: OCDriver]
Seventh Offline
Loc: NorCal
An old boss of mine battled the rodents for years. Tried everything from dryer sheets to bars of soap, poison, cats, moth balls. There is even a product called "mouse blocker" that you wire it to 12v source and it emits some kind of noise that rodents are supposed to hate...
Still had problems after all that. He ended up getting smooth sheet metal panels and cutting them into 8' long strips about 18-20" wide. Riveted the ends together until they were long enough to encompass the perimeter of the vehicle when stood up like a little wall. Bolted the ends together and stored his vehicles like that.
That was the final solution. Rodents can't climb smooth metal surfaces. He stole the idea from a fancy tropical resort he visited once. They had sheet metal collars about 20" wide wrapped around palm tree trunks to keep the rodents from climbing them.
That's my cool story for the day
Page 1 of 2 1 2 >
