"SG(+)" 15w40 or better oil 1987 BBC 454
by F239141. 12/14/18 03:52 PM
All Mazda 3’s have bad OCV’s?
by buster. 12/14/18 03:44 PM
Bad cylinder 3 misfire.
by Hemispheres. 12/14/18 02:49 PM
Small leak at toilet base - bad wax ring?
by Oro_O. 12/14/18 02:38 PM
Ok I take it back about Keurig
by StevieC. 12/14/18 02:29 PM
Edge 5W-30 7.9k miles '13 F150 5.0
by dustyroads. 12/14/18 02:11 PM
Stick with WSS-M2C946-A?
by BlueFog. 12/14/18 01:42 PM
How engine capacity affects fuel consumption?
by NICAT. 12/14/18 01:12 PM
Pep Boys
by Zee09. 12/14/18 12:41 PM
How early in engines life can I start to extend OCI
by Doublehaul. 12/14/18 12:33 PM
EFB and AGM batteries charge faster?
by slybunda. 12/14/18 11:20 AM
97.5 Regal GS climate control illumination
by 71Chevyguy. 12/14/18 11:04 AM
Cool train site for Canadians
by Papa Bear. 12/14/18 10:09 AM
Putting together a groups 3/4/5 synthetic list
by MrWideTires. 12/14/18 10:02 AM
VW Atlas V6 Oil
by motech. 12/14/18 09:32 AM
Great shakes, it's Yahtzee... or a Taurus
by redhat. 12/14/18 09:03 AM
MWI Micro Wave Ignition
by Danno. 12/14/18 08:52 AM
8k Miles on M1 EP 2017 Subaru 3.6
by BISCUT. 12/14/18 08:47 AM
Wrong ATF Fluid in my 07 Chevy Impala
by CM613. 12/14/18 08:39 AM
wsalopek, jcr1293, maxwellk, BlueFog, Frank_G35
66682 Registered Users
92 registered members (A310, andyd, 77GrandPrix, 94astro, 03s, 2009Edge, 7 invisible), 1,959 guests, and 46 spiders.
Topics295,070
Posts4,927,230
Members66,682
Most Online2,553
Oct 27th, 2018
Possible overfill? #4534002
10/04/17 03:08 PM
10/04/17 03:08 PM
California
EMT_760 Offline OP
EMT_760  Offline OP
California
I recently changed my oil on my 17 Tacoma 4x4. The manual calls for 6.2 quarts with the transmission cooler. I always drain my vehicles semi warm to get the oil. I keep getting a reading that says i'm 1/4" of a inch high. Not really much at all. I put back roughly 6.2 measuring the back of the bottle.
I check it by starting it up. Let it cool down for 5-10 mins with the dipstick out and wipe and recheck.
The level looks like this below. Maybe even a bit less.
Re: Possible overfill? [Re: EMT_760] #4534005
10/04/17 03:11 PM
10/04/17 03:11 PM
Cedarbrae, Ontario
xxch4osxx Offline
xxch4osxx  Offline
Cedarbrae, Ontario
I wouldn't worry about that.
2015 RAM SXT Crew Cab 5.7 with 6 speed tranny.
2008 Mazda 3 GS Sport Hatchback 5sp MT (Girlfriend's car)
Re: Possible overfill? [Re: EMT_760] #4534008
10/04/17 03:17 PM
10/04/17 03:17 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
Oil has wiggle room. ATF can be finicky.
I echo xxch4, I wouldn't worry about it.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: Possible overfill? [Re: Leo99] #4534010
10/04/17 03:18 PM
10/04/17 03:18 PM
California
EMT_760 Offline OP
EMT_760  Offline OP
California
This is engine oil. I just said transmission cooler because it uses a bit more oil vs non.
Re: Possible overfill? [Re: EMT_760] #4534025
10/04/17 03:40 PM
10/04/17 03:40 PM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
Don't worry be happy:) I have almost the same on my big Ford right now. Put about 3600 miles on it last weekend making it a long weekend humping relatives belongings to central AZ and back and Friday will be taking the camper to KY another 1000.
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: Possible overfill? [Re: EMT_760] #4534037
10/04/17 03:58 PM
10/04/17 03:58 PM
Florida
SilverSnake Offline
SilverSnake  Offline
Florida
I'll bet the dipstick has a warning on it..."Do Not Overfill." Adjust the oil level to be at or just below the FULL line.
2016 Charger, 6.4L-485 HP (PUP 0W-40)
2017 BMW 330i, 2L-248 HP (BMW 0W-20)
2018 Jeep GC, 5.7L-360 HP (PP 5W-20)
2008 20KW Generac (Amsoil 10W-30/30)
Re: Possible overfill? [Re: EMT_760] #4534053
10/04/17 04:17 PM
10/04/17 04:17 PM
CA
The Critic Online crying
The Critic  Online Crying
CA
This has been a common problem with some of the newer Toyota engines - 3.5, the new 1.8, etc. The published oil capacity is usually too much. I have found that 1/4 qt less than the published amount is usually perfect. Keep in mind that the oil level will rise a bit once the engine is warm, so your goal is to have the oil level read max (and no higher) when checked on a hot engine.
2011 Toyota Prius - 178k - Various 0W-20 (Brew)
2007 Honda Accord 2.4 - 133K - Mobil 1 EP HM 5W-30
Re: Possible overfill? [Re: EMT_760] #4534056
10/04/17 04:24 PM
10/04/17 04:24 PM
Long Island, N.Y.
incognito_2u Offline
Long Island, N.Y.
Hope I'm overstating the obvious, but is the vehicle on a smooth, level surface when checked?
*(On another post, I see that when you changed the Oil, you also changed the filter from an OEM Toyota to a Fram......not to familiar with these filters, but is it possible the Fram has slight less capacity than the OEM?)
2006 Jeep Commander 3.7 V6 -110k (PUP/XG3600)
2006 Toyota Corolla 1.8 VVTi -79k (PPHM/XG4386)
1999 Toyota Corolla 1.8 -80k (PUP/XG4386)
1998 Toyota Corolla 1.8 -62k (PUP/XG4386)
Re: Possible overfill? [Re: SilverSnake] #4534066
10/04/17 04:43 PM
10/04/17 04:43 PM
Texas
FZ1 Offline
FZ1  Offline
Texas
This^^^^^
Re: Possible overfill? [Re: The Critic] #4534079
10/04/17 05:05 PM
10/04/17 05:05 PM
California
EMT_760 Offline OP
EMT_760  Offline OP
California
yes this is the 3.5. So do you think I should drain a bit? I can't imagine it being that much. I put in 6.2 quarts. Maybe there was some residual hiding in the transmission cooler line?
Having that much in extra should not cause any foaming or any harm correct?
Re: Possible overfill? [Re: EMT_760] #4534091
10/04/17 05:18 PM
10/04/17 05:18 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Close the hood and forget it.
Re: Possible overfill? [Re: EMT_760] #4534102
10/04/17 05:35 PM
10/04/17 05:35 PM
Near Mobile
ffhdriver Offline
ffhdriver  Offline
Near Mobile
How does engine oil get into the transmission cooler lines?
Re: Possible overfill? [Re: ffhdriver] #4534106
10/04/17 05:40 PM
10/04/17 05:40 PM
California
EMT_760 Offline OP
EMT_760  Offline OP
California
I don't think their related. But for some reason the manual requires a bit more oil when equipped.
Re: Possible overfill? [Re: EMT_760] #4534122
10/04/17 06:24 PM
10/04/17 06:24 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
If I were you, I'd just shrug my shoulders, mutter "meh" and use six quarts even the next time.
FF for most vehicles seems to put the oil a bit above the full line on the dipstick, so the level you have should be of no concern.
Were it mine, I'd not mess with trying to drain or suck out a few ounces of oil.
Guess how much oil my 4.5 qt sumps always got?
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: Possible overfill? [Re: EMT_760] #4534132
10/04/17 06:39 PM
10/04/17 06:39 PM
California
EMT_760 Offline OP
EMT_760  Offline OP
California
Understood. I mean if it's at roughly 1/4th of a " or so. That's easily less than half a quart. Prob that .2 of a quart that would be needed to be drained out.
