125 years.
by Silk. 09/19/18 12:38 AM
How a VW DSG Transmission works
by StevieC. 09/18/18 10:42 PM
Full Synthetic vs HM Full Synthetic
by SierraMan. 09/18/18 10:06 PM
Champion AGM batteries
by bbhero. 09/18/18 08:53 PM
General opinion about Cooper CS5 Ultra?
by dan_erickson. 09/18/18 08:37 PM
Rotella Online Rebate
by PumpPusher. 09/18/18 08:13 PM
Audi A4 vs Volkswagen CC...or good old Passat?
by KCJeep. 09/18/18 07:19 PM
GM 454 engine
by dirtymudder. 09/18/18 07:13 PM
High Performance Motorcycle oil...which one?
by Neiz15. 09/18/18 06:50 PM
Need help High Performance Motorcycle oil?
by Neiz15. 09/18/18 06:38 PM
MC FL-500S CUT OPEN
by 53' Stude. 09/18/18 05:15 PM
FORD FACTORY FILTER CUT OPEN
by 53' Stude. 09/18/18 05:06 PM
2019 Harley Davidson FXDR 114
by DuckRyder. 09/18/18 04:59 PM
USS Forrestal question
by cjcride. 09/18/18 03:52 PM
Breaker Box
by Throt. 09/18/18 03:00 PM
Honda metal fuel tank seam leak
by wing0. 09/18/18 02:49 PM
Cracked single stage paint
by JHZR2. 09/18/18 01:45 PM
Options versus dealer oil changes
by Schmoe. 09/18/18 01:34 PM
Longevity of Mercon LV in a 2017 Ford Escape?
by mrdctaylor. 09/18/18 01:24 PM
vortex64, 19074, Redright9, Clif67, scotstr
66011 Registered Users
24 registered members (Atesz792, alcyon, cb4017, carloz, BlakeB, carlprop, 2 invisible), 861 guests, and 28 spiders.
Topics290,617
Posts4,847,564
Members66,011
Most Online3,590
Jan 24th, 2017
My Luck with Coolant Hose Clamps! #4533448
10/04/17 12:56 AM
10/04/17 12:56 AM
Australia
B320i Offline OP
B320i  Offline OP
Australia
With the help of a friend, I recently replaced the heater hose, flange and flange gasket (paper) on the back of my BMW's M50 engine. Given this necessitated removal of the manifold, it wasn't exactly a "fun" repair. Here is a photo of the 24 year old, leaking heater hose: http://gdurl.com/mQPC
Anyway, we got it all back together again, bled the cooling system and things were fine for the first few drives. After several drives, I noticed there was a slight weep from the hose or the flange itself again. By a couple of drives later, it was leaking enough to drip on the ground...
Now, if this were a sealing issue on the water flange itself, that would've manifested straight away, I think. I've had plenty of issues with worm-drive hose clamps expanding after a few drives and beginning to seep - I'm just wondering if anyone else has had the issue?
I don't tighten things down as hard as I can (I could've, given this is a metal flange), but the hose was by no means loose.
Any suggestions? I've got another six hoses to replace shortly, all of which are far more accessible. However, I'd like to avoid this irritating phenomenon if I can!
Makes me wonder how mechanics can remove and reseat coolant hoses everyday without having things start seeping everywhere.
'93 BMW 320i 217,000km - Valvoline Engine-Armour 15w40, Mann Filter.
Re: My Luck with Coolant Hose Clamps! [Re: B320i] #4533452
10/04/17 02:21 AM
10/04/17 02:21 AM
NorCal
Seventh Offline
Seventh  Offline
NorCal
Was the sealing surface for the flange on the head pitted and corroded? I've seen that before
Re: My Luck with Coolant Hose Clamps! [Re: Seventh] #4533474
10/04/17 05:35 AM
10/04/17 05:35 AM
Australia
B320i Offline OP
B320i  Offline OP
Australia
Nope, used a brand new flange as I anticipated the old one would be old and crusty.
Re: My Luck with Coolant Hose Clamps! [Re: B320i] #4533477
10/04/17 05:40 AM
10/04/17 05:40 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I always coat the flange with a little Hylomar M before putting the hose on. It doesn't harden so removing the hose later is no problem and is superior to silicone or #2, it will never leak again.
Use a constant tension clamp in place of worm clamps, the OE BMW worm clamps are much better than the five and dime junk available in parts stores these days but are not as good as constant tension ones, the only downside with them is price.
Re: My Luck with Coolant Hose Clamps! [Re: Trav] #4533482
10/04/17 05:57 AM
10/04/17 05:57 AM
North Carolina
Egg_Head Offline
Egg_Head  Offline
North Carolina
+1 BMW OEM clamps, then light a candle and say a prayer
1979 Garelli Rally Sport
2009 Cub Cadet LT1042
2002 BMW 540 M Sport (totaled)
Re: My Luck with Coolant Hose Clamps! [Re: B320i] #4533492
10/04/17 06:18 AM
10/04/17 06:18 AM
NE Ohio
knerml Offline
knerml  Offline
NE Ohio
German OEM's use spring tension clamps. They automatically adjust to changes in the hose over time.
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2555940
2015 Hyundai Elantra Sport 2.0 GDI Mobil 1 5W20 & OEM/Mann W811/80 Filter
2018 Hyundai Santa Fe Sport 2.0T Castrol Edge 5W40 & OEM/Mann W811/80 Filter
Re: My Luck with Coolant Hose Clamps! [Re: knerml] #4533519
10/04/17 07:03 AM
10/04/17 07:03 AM
Trav Offline
Trav  Offline
Really?
https://www.ecstuning.com/b-genuine-bmw-parts/hose-clamp-worm-gear-stainless-steel/07129952113/
German OE can be crimp, worm or spring, they use many types.
Re: My Luck with Coolant Hose Clamps! [Re: Trav] #4533535
10/04/17 07:21 AM
10/04/17 07:21 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Really?
Usually any hose that carries coolant, which causes a large temperature variance, will not have a gear clamp. A gear clamp will not maintain constant tension during heat/cool cycles. So you will only find gear clamps on things like fuel hoses and such.
Never use gear clamps on anything that gets hot.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: My Luck with Coolant Hose Clamps! [Re: Trav] #4533550
10/04/17 07:47 AM
10/04/17 07:47 AM
MI
doitmyself Offline
doitmyself  Offline
MI
Trav, why the Hylomar M vs. the universal blue? Their website implies that the blue is the more "go to" product. I have never used either. Thanks.
Re: My Luck with Coolant Hose Clamps! [Re: Egg_Head] #4533567
10/04/17 08:18 AM
10/04/17 08:18 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
I haven't had a problem at all with the BMW OEM clamps (typically NORMA brand). Despite my personal attraction to the spring clamps on my Asian cars, I have to say the BMW ones haven't leaked either.
1994 BMW 530i, 228K
1996 Honda Accord, 263K
1999 Toyota Sienna, 400K
2000 Toyota ECHO, 271K
Re: My Luck with Coolant Hose Clamps! [Re: mightymousetech] #4533577
10/04/17 08:32 AM
10/04/17 08:32 AM
Trav Offline
Trav  Offline
Really?
Lots of companies use worm clamps OE on cooling systems, they are cheap, look at more than domestics. Notice BMW uses a protective sleeve on this larger hose. Honda uses worm clamps almost exclusively on every coolant hose on some of their bikes. I agree they are not the best option by far.
All the Hylomar blue products are very similar but the M is slightly thicker and less runny, you can find it on ebay cheaper than Amazon. Once you use it you will never be without it.
Re: My Luck with Coolant Hose Clamps! [Re: B320i] #4533624
10/04/17 09:58 AM
10/04/17 09:58 AM
NorCal
Seventh Offline
Seventh  Offline
NorCal
[quote=B320i
Nope, used a brand new flange as I anticipated the old one would be old and crusty.[/quote]
I was asking about the surface on the head.
And BMW has always used only worm gear clamps or oetiker clamps up until E46 was introduced.
Edit: I'm a big fan of hylomar products as well, also there is an equivalent version made by wurth, called DP 300
Re: My Luck with Coolant Hose Clamps! [Re: B320i] #4533631
10/04/17 10:09 AM
10/04/17 10:09 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
You need constant tension hose clamps and Mayhew 28680 pliers to go with them. Problem solved.
Re: My Luck with Coolant Hose Clamps! [Re: B320i] #4533740
10/04/17 11:41 AM
10/04/17 11:41 AM
Colorado Springs
Drew99GT Offline
Drew99GT  Offline
Colorado Springs
I just dealt with this very issue a month ago; the easiest and most readily available option is constant tension worm gear clamps; Napa usually has them in stock or can get them in a day; same with Oreilly Auto. They are easy to install without having to remove the hose.
https://bobistheoilguy.com/forums/ubbthr...gear_hos#UNREAD
Re: My Luck with Coolant Hose Clamps! [Re: B320i] #4533743
10/04/17 11:45 AM
10/04/17 11:45 AM
Colorado Springs
Drew99GT Offline
Drew99GT  Offline
Colorado Springs
Oops, I see you're in Australia. You can order the constant tension worm gear clamps if you can't find them locally.
