VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Zahndkile, duradick, Harold1031, Skendread, NGK
67590 Registered Users
50 registered members (4WD, avi1777, antik, billt460, AurionX2, 97K15004WD, 7 invisible), 719 guests, and 57 spiders.
Topics286,270
Posts4,905,647
Members67,589
Most Online2,967
Mar 10th, 2019
Did the 9006 to 9012 bulb mod #4533086
10/03/17 03:41 PM
10/03/17 03:41 PM
The Northeast
mclasser Offline OP
mclasser  Offline OP
The Northeast
The 2 yr old Silverstars in my Accord were still going strong but I got the itch to try this mod out. I haven't gotten a chance to do a night drive yet but I'm excited to see if the extra lumens these Philips 9012s are touted for actually make a difference. Just by looking at them during the daytime, it's obvious the light is a murkier yellow than the Silverstars.
And on a side note, these bulbs are made in Poland. Other Philips bulbs I've gotten in the past were all made in Germany.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Did the 9006 to 9012 bulb mod [Re: mclasser] #4533151
10/03/17 05:43 PM
10/03/17 05:43 PM
Texas
4WD Online confused
4WD  Online Confused
Texas
So it is a direct fit where 9006 was mounted/is it a higher wattage?
Re: Did the 9006 to 9012 bulb mod [Re: 4WD] #4533172
10/03/17 06:05 PM
10/03/17 06:05 PM
The Northeast
mclasser Offline OP
mclasser  Offline OP
The Northeast
It isn't direct fit but very easy to do; all that's needed is a little trimming of one of the bulb tabs with a nail clipper. Wattage is the same 55W as OEM.
Re: Did the 9006 to 9012 bulb mod [Re: mclasser] #4533173
10/03/17 06:05 PM
10/03/17 06:05 PM
New England
gathermewool Offline
New England
The 9012 is much brighter, with similar power usage. simply need to trim a couple of tabs.
I did a similar mod on my previous '08 Civic and what low-beams changed from almost worthless to adequate.
I tried using a couple of different nail clippers and it didn't even come close to working. What do you have LLoyd Christmas nails!?
I used a dremil.
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter (40,803 miles)
Re: Did the 9006 to 9012 bulb mod [Re: gathermewool] #4533181
10/03/17 06:12 PM
10/03/17 06:12 PM
The Northeast
mclasser Offline OP
mclasser  Offline OP
The Northeast
I used a dremil.
Nope, regular nails here!
Re: Did the 9006 to 9012 bulb mod [Re: mclasser] #4533288
10/03/17 07:53 PM
10/03/17 07:53 PM
Staten Island, NY
michaelluscher Offline
Staten Island, NY
I did that mod in my OEM Camry headlights
Well worth the effort/cost, as long as you have good glare control (a glare cap)
I've since moved on to Projectors and HID's, but the 9012 mod is a solid and effective way to boost stock light output, without blinding everyone else
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
Re: Did the 9006 to 9012 bulb mod [Re: mclasser] #4533410
10/03/17 10:17 PM
10/03/17 10:17 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
I did the mod on my corolla and was happy at first until I had a 9012 burn out within two years. Since then, ive switched to LED bulb replacements and im not looking back. Im using Yumseen brand LED lights 6000k color temp, bright white. Doesnt blind anyone but really clarifies the roads, even better than the 9012's and will be less likely to cloud your headlight lenses. Regardless the 9012's will be an improvement for you.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Did the 9006 to 9012 bulb mod [Re: mclasser] #4533420
10/03/17 10:43 PM
10/03/17 10:43 PM
Georgia
AVB Offline
AVB  Offline
Georgia
I did this to my Avalanche earlier this year. Nearly everything I read said to use toenail clippers to trim the tabs, and take a little off at the time. If not the plastic can break. I used a pair of the small dikes made for electronics.
Re: Did the 9006 to 9012 bulb mod [Re: Rolla07] #4533639
10/04/17 10:16 AM
10/04/17 10:16 AM
Alberta, Canada
Smokescreen Offline
Smokescreen  Offline
Alberta, Canada
So the Chinese made 6000K COB LED bulbs in a halogen enclosure was better than the high output halogen bulb 9012 with perfect color rendition made for the enclosure?
There is no way...I think the laser blue 6000K is messing with your eyes.
13 Civic Si 2.4L- 69Kkms(43Kmi)-PP,Wix
05 LeSabre 3.8L-210Kkms(134Kmi)-PP,Wix
03 Sierra 2500 6.0L-204Kkms(127Kmi)-PP,Wix
All with mpg > EPA
