Treating a 2003 Jetta
by llmercll
06/19/18 01:41 AM
Brakes not working - brake pedal sinks
by tookien
06/19/18 12:42 AM
Dave thinks I can make it 12--15k
by Marco620
06/19/18 12:26 AM
'05 Impala front wheel "squeal". Cost !
by Lee4212
06/19/18 12:16 AM
One Dollar Per Gallon?
by Y_K
06/18/18 11:53 PM
Walmart Tightening up Returns
by John_K
06/18/18 10:21 PM
flare nut wrench set
by spasm3
06/18/18 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
06/18/18 09:45 PM
How much is too much?
by Sealbilly
06/18/18 09:34 PM
Correct oil filter for a Vovlo S60, 2003
by earthworm
06/18/18 09:17 PM
Prestone coolant $3.50 Target YMMV
by pda1122
06/18/18 09:13 PM
Need Windows 7 Pro ISO
by MONKEYMAN
06/18/18 08:33 PM
PEAK Full Synthetic -- Anyone Try It ??
by johnnyz73
06/18/18 07:40 PM
Why high resale value on Jeeps if frames rust out?
by Vern_in_IL
06/18/18 06:48 PM
Wearever Silver Semi-Metallic Brake Pads- Break In
by ET16
06/18/18 06:37 PM
Where to Buy Motul Oil in Stores?
by Hot_Ajax
06/18/18 06:13 PM
2011 Chevy equinox overheating
by hardcore302
06/18/18 06:00 PM
Are my rotors warped?
by Dylan1303
06/18/18 05:44 PM
Ultimate Fast Finish on sale at CDN tire.
by irv
06/18/18 05:23 PM
96 Civic 5w20 Castrol GTX Ultraclean UOA
by researcher
06/18/18 04:52 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
31 registered (clinebarger, 1WildPig, ctechbob, Backwoods41695, David2431, 2 invisible), 900 Guests and 47 Spiders online.
65265 Members
67 Forums
285573 Topics
#4532783 - 10/03/17 09:12 AM Taurus Trans Slip
Sluggo0018 Offline
Loc: Long Valley, NJ
My daughter is away at school in RI and will be coming home this Columbus Day weekend. She has mentioned an infrequent problem with the 2008 Ford Taurus AWD that she uses for transportation to student teaching on a daily basis. She describes the problem as severe slipping. The engine will race and the car will barely move. Then it will catch and all seems well. It happens very infrequently, maybe once every month or two. There doesn't seem to be any correlation to temperature, car being on an angle, etc. Appears to be completely random. The problem has never occurred when I am driving it. I try to get her to tell me about any problems with the car right away, no matter how trivial, but she says this has been occurring for over a year. Again, it is very infrequent. I have driven the car for decently long trips (over 600 miles round trip) with no issues. All other transmission factors seem normal (smooth shifting, downshifts properly, etc.).
The Taurus has roughly 170,000 miles on it. I got it at 90,000 miles and have performed ATF drain and fills roughly every 20-30,000 miles. Not sure of the exact date of the last drain and fill since my maintenance log is in the car in RI. I am not sure if the trans has ever been serviced before we got the car.
According to what I have read, the filter for the Ford 6F50 transmission is not easily replaced. The trans must be somewhat taken apart just to get to it. Hoping to avoid this if possible.
I will likely do another set of two drain and fills this coming weekend when she comes home and was wondering if anyone had any other suggestions. I am generally not a believer in additives for fixing problems, but there may be some magical elixir that others been successful with. I'd love to hear about it. I am looking to avoid her call that tells me the car wont move and she is several hundred miles away. Also not looking to throw a bunch of money in the form a new/rebuilt transmission at a car with high mileage.
Thanks for any advice that you can provide.
#4532799 - 10/03/17 09:23 AM Re: Taurus Trans Slip [Re: Sluggo0018]
zzyzzx Offline
Loc: Baltimore, Maryland, USA
How does one check the transmission fluid level on this vehicle? I am wondering if the fluid level is low, or restricted by that hard to get to filter. is it possible to raise the transmission oil pressure (like it was on older cars that used a cable?)
#4532804 - 10/03/17 09:26 AM Re: Taurus Trans Slip [Re: Sluggo0018]
69GTX Offline
Loc: Connecticut
That probably takes the Mercon V. That's a pretty long life on a Ford transmission that you got at 90K miles. Not bad at all. If it were me, I'd also add 12 oz of Lubeguard (red?) on your last D&F. It can improve/restore some of the frictional qualities of the fluid, especially since you'll still have 30-50% old fluid in there after 2 D&F's.
Lubeguard
Catalog
I always figured Ford filters were in the trans pan, and that all of them were easy to drop. What year is the Taurus?
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
#4532806 - 10/03/17 09:27 AM Re: Taurus Trans Slip [Re: zzyzzx]
14Accent Offline
Loc: MN
It has a dipstick. There is no way to "raise" transmission pressure. It's electronically controlled.
Have her get the codes pulled. I'd be willing to bet there's something stored, even if the CEL didn't come on.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
#4532841 - 10/03/17 09:52 AM Re: Taurus Trans Slip [Re: 14Accent]
Sluggo0018 Offline
Do you pull the transmission codes in the same manner as engine codes? I have an Autel Maxiscan MS509 scanner that I can try when she gets home. If there is a code stored, how can I determine what it means?
#4532851 - 10/03/17 10:04 AM Re: Taurus Trans Slip [Re: 14Accent]
zzyzzx Offline
Supposedly there is a way to do that, electronically. Look it up. Not sure if that is applicable to all cars that use electronics to regulate transmission oil pressure.
#4532858 - 10/03/17 10:08 AM Re: Taurus Trans Slip [Re: 69GTX]
earlyre Offline
Loc: Lima, Ohio, USA
Lubeguard
Catalog
it does take Merc V. it's an 08 per the Op, with the 6F50(6 speed auto Co developed with GM, this is fords version, variants of it used in practically everything) you have to split the trans case open to access the filter.
Mine:
09 Mercury Sable : 6qts AutoQuest(Meijer/Warren) 0w20, WIX 51516
Mine to Maintain:
03 Pontiac Vibe : 4.5qts VWB 5w30,WIX 51394
#4532884 - 10/03/17 10:38 AM Re: Taurus Trans Slip [Re: Sluggo0018]
BrocLuno Offline
Loc: Kalifornia Kollective
Since it is electronically controlled, I suspect a solenoid is sticking, or not activating ... Most likely a bad wire connection somewhere ...
My first inclination is to add some new grounds to the system. The car is getting long in the tooth and has seen some winters. She prolly parks outside (?). Slush, rain, snow all eventually get to the ground contact points in the form of crevice corrosion which makes them semi-conductors at best...
#4 cable with crimped and soldered lugs. One from battery neg clamp bolt to engine block. One from another handy bolt on engine block to fire-wall. And in this case one from a tranny bolt to the chassis somewhere.
Maybe find the ECU and partially (carefully) pull the connector part way and reseat so all the pins have new metal contact.
I have found that new grounds cure all sorts of issues with ECU controlled systems. There is voltage on the applied side to move the current, But on the ground side it is just current and anything interfering will cause gremlins ...
#4532953 - 10/03/17 12:14 PM Re: Taurus Trans Slip [Re: Sluggo0018]
carguy996 Offline
Loc: Illinois
You might want to try the LiquiMoly ATF Additive as well. I was having some intermittent slipping with my Sebring, after adding the ATF Additive to fresh ATF +4 fluid, the car has performed flawlessly for the last 6000 miles.
2018 Nissan Rogue Platinum AWD w/ ProPilot
2014 Honda Odyssey Touring Elite 3.5
2013 Chrysler 200 Convertible 3.6
#4532969 - 10/03/17 12:38 PM Re: Taurus Trans Slip [Re: Sluggo0018]
Bgallagher Offline
Loc: Boston, MA
My first thought is low fluid or an electrical issue. Perhaps a bad ground etc. I would consider doing a drop and fill with Maxlife ATF and throw in a bottle of LGR
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
#4533008 - 10/03/17 01:25 PM Re: Taurus Trans Slip [Re: Bgallagher]
SatinSilver Offline
Loc: OH
Seems to be the most common problem with the 08 Taurus, transmission issues:
https://www.carcomplaints.com/Ford/Taurus/2008/
Check out the tsbs, many involving what you're describing. Too bad it's not the FWD version with an Aisin trans in it. Maybe trade it for one of those if you can. They seem to be cheap.
#4533073 - 10/03/17 03:26 PM Re: Taurus Trans Slip [Re: SatinSilver]
earlyre Offline
you're confusing the 08-09 Taurus(Sable,Taurus X) with the 05-07 Five Hundred(Montego,Freestyle) the asin was never available in this configuration.
in the Five Hundred, et all(05-07), you got the old Duratec 3.0 and either a ZF CVT(vast majority),or an Asin 6 Speed.
Dad had an 05 Freestyle, AWD CVT. His Twin brother bought an 07 Freestlye, FWD CVT.
once they brought back the Taurus, and Sable Nameplates(and got away from the stupid "Fords have to start with an F, Mercury's with an M" failed experiment) they made a few changes,among them a facelift, and different drive train, replacing the Duratec 3.0, with the 3.5l Cyclone(originally known as the Duratec 3.5), the CVT/or Asin transmissions with the 6f units.
then for the 09 model year, they did a full body redesign, retired the Sable(as part of phasing out Mercury)and replaced it with the Lincoln MKS.(which it self has now been discontinued and replaced with the Continental, which is a gussied up version of the 7th Gen Taurus, Currently on sale in China(we Still get the 6th Gen), which is built on the same platform as the Fusion, but with a 5 inch Stretch.)
Edited by earlyre (10/03/17 03:31 PM)
Mine:
Mine to Maintain:
#4533106 - 10/03/17 04:24 PM Re: Taurus Trans Slip [Re: Sluggo0018]
eljefino Offline
Loc: ME
The older fords used to have issues with the resistive-multiplex PRNDL switch. So the car would be hydraulically in Drive but electronically in Neutral with the hilarity that ensues.
The catch for this would be a data stream scan tool when it acts up reporting the selected gear.
Or she could drive around in 3rd the whole time, b/c the worst that could happen is she gets "regular Drive" since it's "off by one".
#4533292 - 10/03/17 07:55 PM Re: Taurus Trans Slip [Re: eljefino]
michaelluscher Offline
Loc: Staten Island, NY
FORScan would be excellent for looking at these Data PIDs
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
#4533316 - 10/03/17 08:17 PM Re: Taurus Trans Slip [Re: earlyre]
GaleHawkins Offline
Loc: Murray KY USA
Great details on the non Taurus name years. We have a 2006 Ford 500 with the Aisin 6 speed with is still an awesome car that the son is driving to college due to the MPG of his 2002 5.9L Ram 1500 quad cab. These years were the 1st Gen Volvo S-80 chassis (then owned by Ford) with Ford 3.0L engine and electronics. At 150K miles it still as good as the 2010 Subaru Forester 2.5X on fuel.
