Float chargers?
by buck91. 04/21/19 05:32 PM
Toyota factory pink mixed with zerex coolant
by Rohan. 04/21/19 04:48 PM
Schaeffer 204SAT and 205A
by Gebo. 04/21/19 04:32 PM
Oil for old Chevy TBI 350
by RonRonnster. 04/21/19 04:19 PM
2012 chevy equinox transmission fluid
by krdoss. 04/21/19 03:50 PM
How Often Change Fuel Filters?
by Gebo. 04/21/19 03:17 PM
New Hyundai Elantra tell me all I need to know
by DONWATERS. 04/21/19 02:28 PM
How much balance weight is too much
by Hitman70. 04/21/19 02:02 PM
bought steel cut oats by mistake
by andyd. 04/21/19 01:50 PM
Mobil1 Synthetic Lubricating Spray
by EvanR. 04/21/19 01:01 PM
List of cars you've owned
by SLO_Town. 04/21/19 12:30 PM
Email Notice
by borgward. 04/21/19 12:14 PM
Why would 10w burn more than 5w?
by D1dad. 04/21/19 11:57 AM
02 Silverado 5.3L, LT, Low Oil Pressure
by Gito. 04/21/19 11:54 AM
0 to 60 in 1.9 seconds...
by JeffKeryk. 04/21/19 11:16 AM
Luxury Car Owners Switching to Pickup Trucks
by SubLGT. 04/21/19 11:05 AM
Easiest Way to Gravity Bleed Brakes
by jims5600. 04/21/19 10:55 AM
Newcastle Brown Ale replacement?
by Reddy45. 04/21/19 10:31 AM
Easter Sunday
by gman2304. 04/21/19 10:17 AM
Texas72, RamblerReb, rchapin, js1956, krdoss
67865 Registered Users
95 registered members (2015_PSD, alphadog, AdditiveOCD, 53' Stude, 2009Edge, AndyB, 9 invisible), 1,945 guests, and 25 spiders.
Topics287,854
Posts4,935,613
Members67,865
Most Online2,967
Mar 10th, 2019
Benz I-5 diesel wake-up? #4532651
10/03/17 07:08 AM
10/03/17 07:08 AM
Campbellsville, KY
Alex_V Offline OP
Alex_V  Offline OP
Campbellsville, KY
Just acquired a 1982 Mercedes 300CD with the OM617 turbo diesel. The PO, a friend, lives over 400 mi. away from me so I'm storing it at a friend's shop nearby for a few weeks until I can come back and hopefully drive it home. It was driven as recently as a year ago, and started only a few months ago. It started and pulled itself onto the trailer, and ran for about 30 mins. once I unloaded it. Of course, before making the trek home it will get an oil change and new fuel filters, etc., and a thorough mechanical inspection, but the one thing I'm puzzled and feel it may take me some time to sort out is that it seems very weak until the turbo spools - I'll take off and it accelerates very sluggishly until maybe 1/3 engine speed, then comes on hard and shoots up to the shift point. It does the same thing sitting in park, actuating the throttle by hand.
Any suggestions to at least steer me in the right direction? I understand how diesel work but am not experienced with troubleshooting them.
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: Benz I-5 diesel wake-up? [Re: Alex_V] #4532669
10/03/17 07:38 AM
10/03/17 07:38 AM
Rainville, USA
JEL01 Offline
JEL01  Offline
Rainville, USA
These engines are simple and insanely durable, likely your problem is something easy like the banjo bolt/line at the back if the exhaust manifold assuming the fuel filters are ok. Very rarely is it compression loss or a turbo issue, google the banjo bolt cleaning, as well as diesel purge procedure for that engine, typically that takes care of it (had quite a few of these cars). When was the last time the valves were adjusted that you know of?
Cars I maintain:
02 Mercedes CLK430-Edge 0w40
05 Honda Accord V6-Maxlife 5w30
13 Lexus RX350 AWD-M1 AFE 0w20
02 Toyota Tundra 4x4 M1 5w30
Re: Benz I-5 diesel wake-up? [Re: Alex_V] #4532692
10/03/17 08:05 AM
10/03/17 08:05 AM
NY
joegreen Offline
joegreen  Offline
NY
I have an 84 300d with same engine. Banjo bolt and pressure line check is a good idea. It sounds relatively normal though. I know if I rev mine up a little in park it will reach a certain rpm and the engine will quickly rev up without me giving it any more throttle. Same when driving. Give it 1/4 throttle and it takes off slow and then all the sudden it will pick up speed and rpm without giving it any more throttle. Your car sounds like its fine.
1978 Chevrolet k20
Engine: Delo 10w30xle
Transmission: Castrol transmax dex/merc
1984 Mercedes-Benz 300 turbo diesel
Engine: Delo 400 15w40le
Re: Benz I-5 diesel wake-up? [Re: Alex_V] #4532914
10/03/17 11:10 AM
10/03/17 11:10 AM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
There's a guy on YouTube who works on these. I think his channel is Mercedes Benz source. He's an older guy who wears a Mercedes Benz blue coat and mainly works on 80s Mercedes.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Benz I-5 diesel wake-up? [Re: Alex_V] #4532995
10/03/17 01:09 PM
10/03/17 01:09 PM
Ajax,Ontario, Canada
Pelican Offline
Pelican  Offline
Is this your 1st diesel? Diesel don't accelerate, but gather speed slowly, till the turbo kicks in.
Re: Benz I-5 diesel wake-up? [Re: Alex_V] #4533013
10/03/17 01:36 PM
10/03/17 01:36 PM
Margate England
Claud Offline
Claud  Offline
Margate England
It's an old fashioned turbo-diesel, sounds like normal turbo lag for a car of this vintage.
Claud.
Re: Benz I-5 diesel wake-up? [Re: Alex_V] #4533019
10/03/17 01:46 PM
10/03/17 01:46 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Sounds like a turbo diesel to me
2015 Hyundai Sonata 2.4L 93k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Benz I-5 diesel wake-up? [Re: Alex_V] #4533061
10/03/17 02:57 PM
10/03/17 02:57 PM
Campbellsville, KY
Alex_V Offline OP
Alex_V  Offline OP
Campbellsville, KY
Thanks for the input, all. I just checked and cleaned the banjo bolt this morning - I have very faint pressure at the vacuum apparatus (can't remember the acronym for it) on the injector pump while revving, but the line to it from the banjo fitting on the intake runs through a valve on the firewall that may be why I'm not getting a direct signal. Yes? No doubt you're right about it just being a normal trait of the OM617. I'll inspect and adjust everything as soon as I have time and see how much good it does it. A 500-mile trip with Schaeffer's 9000 5w40 shouldn't hurt it, either. laugh
Not sure when the valves were last done but I'm sure they were at some point - I don't have all the maint. records for the car yet. I'll check them when I get it home, but until then I don't hear anything out of the ordinary from the top end.
I got it on a lift this morning and gave it a good once-over - needs a lot of tweaking but it's really a solid project.
Re: Benz I-5 diesel wake-up? [Re: Alex_V] #4533101
10/03/17 04:16 PM
10/03/17 04:16 PM
ME
eljefino Offline
eljefino  Offline
ME
I have one of these. Yes to the banjo bolt and yes to the valve adjustment.
You may also find yourself with stuck, overheating brakes! Go through them very well.
One of my w123s had the pad hardware swell up from rust and not move. The other had a miserable combo of sticky calipers and a master cylinder that wouldn't release pressure up into the reservoir when the pedal was all the way up. It is hard, when you have a car much slower than average, to notice a dragging brake until your fluid boils.
These'll do 85+ in half decent tune. laugh
Re: Benz I-5 diesel wake-up? [Re: Alex_V] #4533118
10/03/17 04:41 PM
10/03/17 04:41 PM
Campbellsville, KY
Alex_V Offline OP
Alex_V  Offline OP
Campbellsville, KY
Ha, I was actually just thinking I should bleed the brakes before heading home.
IIRC many owners confirm breaking 110 with them - speed limiting comes from meeting the redline right about then more than anything.
I really appreciate the way this thing's built. Refinement and luxury, but simple in a way and straightforward enough it's not
impossible to keep well maintained.
Re: Benz I-5 diesel wake-up? [Re: Alex_V] #4533480
10/04/17 05:55 AM
10/04/17 05:55 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Sounds like a typical old MB TD to me, don't forget the valve adjusting wrenches they are a must. Hazet 2769 and 2769-3 are discontinued but can be found on ebay cheap enough
Re: Benz I-5 diesel wake-up? [Re: Trav] #4536449
10/07/17 07:06 PM
10/07/17 07:06 PM
Eastern North Carolina
gonesurfing Offline
gonesurfing  Offline
I also just bought one of these. I've got a 78 Brown 300CD. Unbeknownst to me was the fact that the floorboards and front rockers were rusted. I pulled the carpet back and the accelerator pedal broke free from the floor. The passenger rocker was rusted back to the A pillar. I've been cutting and welding for 3 months and I'm nearing completion. I highly suggest checking your floors and rockers. If the undercoat is even a little cracked, better sand it back and inspect. Can't wait to actually enjoy this thing! Yours looks good in white.
Re: Benz I-5 diesel wake-up? [Re: Alex_V] #4537000
10/08/17 10:37 AM
10/08/17 10:37 AM
ME
eljefino Offline
eljefino  Offline
ME
I just put a cheap 14mm wrench on a grinder to make it a little thinner for valve adjusting.
