Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
31 registered members (bbhero, alcyon, anndel, Bailes1992, 5 invisible), 543 guests, and 57 spiders.
Topics286,442
Posts4,908,263
Members67,622
Most Online2,967
Mar 10th, 2019
Drain and Fill ATF Interval? #4532640
10/03/17 06:53 AM
10/03/17 06:53 AM
VA
Gebo Offline OP
Gebo  Offline OP
VA
I'm using a synthetic ATF. I drain out 2-3 qts every so often to maintain a fairly clean ATF. How often would you do a partial drain and fill with this information? Transmission capacities vary between 8-9 qts
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Schaeffer in the first two.
Re: Drain and Fill ATF Interval? [Re: Gebo] #4532650
10/03/17 07:05 AM
10/03/17 07:05 AM
MD
ET16 Offline
ET16  Offline
MD
Every other oil change, or a little longer.
Re: Drain and Fill ATF Interval? [Re: Gebo] #4532661
10/03/17 07:24 AM
10/03/17 07:24 AM
VA
Gebo Offline OP
Gebo  Offline OP
VA
How many miles would that be for you?
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Re: Drain and Fill ATF Interval? [Re: Gebo] #4532671
10/03/17 07:40 AM
10/03/17 07:40 AM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
I do a quick drain/fill with Dex VI in my Cherokee's AW-4 every year. Usually between 6 and 10K miles.
I'm not easy on it.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Drain and Fill ATF Interval? [Re: Gebo] #4532680
10/03/17 07:55 AM
10/03/17 07:55 AM
NC
fenixguy Offline
fenixguy  Offline
NC
In the Hondas I stick with a 30,000 mile drain and fill. I may do a 20k drain and fill interval with the Frontier (per the severe service interval in the manual).
If you're changing the ATF regularly, you're already doing more than 90% of car owners. Pick an interval that works for you and stick with it.
'16 Frontier SV 4x4-PP/Nissan OEM
'08 CR-V EX AWD-Valvoline Syn MaxLife/Fram TG
'01 Civic EX-Valvoline Syn MaxLife/Fram UG
'00 Civic LX-PYB/Fram UG
Re: Drain and Fill ATF Interval? [Re: Gebo] #4532689
10/03/17 08:02 AM
10/03/17 08:02 AM
The land of USA-made Subies!
SubieRubyRoo Offline
Once a year D&F should be fine to replenish additives, reduce TAN, and get out any particulates in the pan or on the magnet. Unless you drive more than 30k in a year, this should be plenty regardless of the transmission.
I do my 06 Odyssey every 20k (1 gallon of Maxlife ATF) and my 11 Fusion every 30k (1 gallon of Amsoil ATL)... but thinking about it, every 3rd change I will likely do Honda's "full" 4x D&F... if I have the van that long.
Re: Drain and Fill ATF Interval? [Re: Gebo] #4532714
10/03/17 08:23 AM
10/03/17 08:23 AM
Boston, MA
Bgallagher Offline
Bgallagher  Offline
Boston, MA
I typically do a drain and fill every 20k. It is pretty easy so I will do it whenever I am close to that mark and due for an oil change.
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
Re: Drain and Fill ATF Interval? [Re: Gebo] #4532715
10/03/17 08:24 AM
10/03/17 08:24 AM
Central Florida
Mr Nice Offline
Mr Nice  Offline
Central Florida
ATF is cheap, I do it every 30K miles.
Re: Drain and Fill ATF Interval? [Re: Gebo] #4532832
10/03/17 09:47 AM
10/03/17 09:47 AM
Minnesota
2010Civic Offline
2010Civic  Offline
Minnesota
I have a 2008 and 2010 Civic and do a drain/fill every 25k miles. Costs less than $20 for me to drain 2.5 quarts of Honda ATF and refill.
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
Re: Drain and Fill ATF Interval? [Re: Gebo] #4532854
10/03/17 10:06 AM
10/03/17 10:06 AM
Texas
440Magnum Offline
440Magnum  Offline
Texas
I wouldn't bother much more often than every 30k miles, unless its an AT known for generating a lot of clutch dust. ATF has a pretty easy life compared to engine oil- no combustion byproudcts, no acids, no moisture other than atmospheric moisture, no carbon, no sulfur, no unburned fuel / fuel additives. Just clutch dust and gradual depletion of some components of the additive package, that's why they really can live "for life" (and have "life" be > 200k miles sometimes) on a single fluid fill if the owner chooses that level of neglect.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
Re: Drain and Fill ATF Interval? [Re: Gebo] #4532866
10/03/17 10:21 AM
10/03/17 10:21 AM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
Every 5 years or 80,000 miles. Drop the pan and change what fluid I can. Maybe less often than this.
Re: Drain and Fill ATF Interval? [Re: Gebo] #4532888
10/03/17 10:41 AM
10/03/17 10:41 AM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
I do a drain/fill around every 30k on average.
yup
Re: Drain and Fill ATF Interval? [Re: Gebo] #4532889
10/03/17 10:41 AM
10/03/17 10:41 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
About every 30K smile
Re: Drain and Fill ATF Interval? [Re: Gebo] #4532903
10/03/17 11:01 AM
10/03/17 11:01 AM
Anaheim, CA
zorobabel Offline
zorobabel  Offline
Anaheim, CA
On the 2004 Corolla with added remote filter, inline cooler and T-IV ATF used - at 30k, the drained fluid (roughly 50% of capacity) looked somewhat dark. Castrol IMV went in.
On the 97 Maxima with added remote filter, inline cooler and Maxlife Syn ATF used - at 30k, the drained fluid (roughly 50% of capacity) looked very good. I'm contemplating going to 60k ATF drain and fills on the Maxima.
1997 Maxima 197k, Castrol GTX Synblend 5W-30, FL400S
2004 Corolla 197k, VWB + SSS + Rislone cocktail, MGL51516
Re: Drain and Fill ATF Interval? [Re: Gebo] #4532913
10/03/17 11:10 AM
10/03/17 11:10 AM
VA
Gebo Offline OP
Gebo  Offline OP
VA
I'm thinking every 20k with 2 qts. That way after every 4 changes, I would have a "complete" change.
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
