Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Lisle funnel for radiator drain & fill
by paulri. 03/21/19 07:45 PM
Rattle in Catalytic Converter 2003 Suburban
by Fitz98. 03/21/19 05:59 PM
Mobil1 5W-30 EP, 8317mi, 2007 Prius Touring, 98133
by DuckRyder. 03/21/19 05:32 PM
Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
scottjeffrey, Mowata, LoneWolf04, Paperboy, Flinch
67579 Registered Users
33 registered members (bradepb, BigShug681, bmod305, Brian123, 4 invisible), 583 guests, and 50 spiders.
Topics286,220
Posts4,904,517
Members67,579
Most Online2,967
Mar 10th, 2019
Easiest Oil Change Ever! #4532513
10/02/17 11:04 PM
10/02/17 11:04 PM
Southeast United States
TheLoneRanger Offline OP
The mower is a self-propelled LawnBoy with a Kohler engine.
Today I changed the oil by simply removing the dipstick and
tilting it on it's side to drain the oil. Worked great.
Is this SOP for push mowers, or is there a better method?
Some days you eat the bear, some days the bear eats you.....
Re: Easiest Oil Change Ever! [Re: TheLoneRanger] #4532523
10/02/17 11:19 PM
10/02/17 11:19 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
Some mowers have a drain plug underneath.. I prop up the front edge with a block of wood or something and drain it that way. Less messy than tilting it on the side.
Re: Easiest Oil Change Ever! [Re: TheLoneRanger] #4532530
10/02/17 11:37 PM
10/02/17 11:37 PM
CA
raytseng Offline
raytseng  Offline
CA
used an oil extractor and didnt spill a drop.
Re: Easiest Oil Change Ever! [Re: raytseng] #4532543
10/03/17 12:30 AM
10/03/17 12:30 AM
Texas
FZ1 Offline
FZ1  Offline
Texas
This ^^^^^
Re: Easiest Oil Change Ever! [Re: TheLoneRanger] #4532549
10/03/17 01:15 AM
10/03/17 01:15 AM
USA
oldhp Offline
oldhp  Offline
USA
+1 on the extractor.
2018 RAM 1500 3.6/8 speed.
2017 Jeep Sahara Unlimited 3.6
"U kan't fixe it......if'n it ain't broke."
Re: Easiest Oil Change Ever! [Re: TheLoneRanger] #4532563
10/03/17 02:39 AM
10/03/17 02:39 AM
Central Wisconsin
dwendt44 Offline
dwendt44  Offline
Central Wisconsin
Yes, most mower engines these days call for the
'Tip it over' method. Cheaper than machining and installing
a drain plug.
In part due to 'all thumbs' home mechanics that don't install
drain plug properly and they work free and dump the oil killing
the engine.
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: Easiest Oil Change Ever! [Re: TheLoneRanger] #4532579
10/03/17 04:47 AM
10/03/17 04:47 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Almost all new units have no drain plug. Myself, I would rather have a drain plug as it would be best for getting all wear metals out with the oil.
The "thinking" man's friend.
Re: Easiest Oil Change Ever! [Re: TheLoneRanger] #4532709
10/03/17 08:19 AM
10/03/17 08:19 AM
The land of USA-made Subies!
SubieRubyRoo Offline
Yes, I just tip my mower over into the big drain pan, then lift the front of the mower and prop it up so it all drains out. Best to run the mower out of gas and drain it then, plus the oil is nice and hot and should take all the particulates with it.
My mower liked RT6 but since I only fill it with surplus and not specific oil, it has had PP 5W-30 and some Mobil1 0W-40 in it as well. I dosed the last fill with some Lubegard BioTech. Just because I can, and push mowers are cheap smile
Re: Easiest Oil Change Ever! [Re: Reddy45] #4532712
10/03/17 08:21 AM
10/03/17 08:21 AM
Boston, MA
Bgallagher Offline
Bgallagher  Offline
Boston, MA
+1 I am usually under the deck anyways taking the blade off for sharpening. I usually drain it using the plug. The tipping method is also pretty easy.
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
Re: Easiest Oil Change Ever! [Re: TheLoneRanger] #4532765
10/03/17 09:03 AM
10/03/17 09:03 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I tell people to run the gas tank dry first before tipping anything on it's side.
Re: Easiest Oil Change Ever! [Re: TheLoneRanger] #4532776
10/03/17 09:09 AM
10/03/17 09:09 AM
Canada
boraticus Offline
boraticus  Offline
Canada
Any idea of how many mowers live long productive lives with no oil changes?
I've worked on mowers that had a substance more similar to black grease in their crankcases that were still running after 20 plus years of obvious abuse. Keep the oil up and a mower will likely never have oil related problems.
Not that I'm against proper maintenance which includes oil changes, I'm simply stating that if there's oil in the machine, it will likely run for many, many years without ever changing the oil. As a matter of fact, I've seen ads for mowers now that claim no oil changes required.
Re: Easiest Oil Change Ever! [Re: TheLoneRanger] #4532790
10/03/17 09:17 AM
10/03/17 09:17 AM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
When I talked to a Power Equipment servicer this past summer about my lawnmower issue, they said that the vast majority of failures are from the carbs. Change the engine oil all you want. But, keep the carb clean as well. In the half dozen or so small push mowers I've had, it's either been all but once that killed them beyond the cost to repair. The other one was from rust due to not cleaning the underside frequently enough. I do change the oil at least once per year for 50-100 hrs of use.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Easiest Oil Change Ever! [Re: TheLoneRanger] #4532844
10/03/17 09:55 AM
10/03/17 09:55 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
I have been tipping the lawn mowers to drain the oil for the last 30 years. The technique works well
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Easiest Oil Change Ever! [Re: 69GTX] #4532894
10/03/17 10:48 AM
10/03/17 10:48 AM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
I do agree that is mostly what causes people to buy new mowers. Before craigslist me and a group of friends used to spend our summers picking up curbside mowers, cleaning the carbs, and flipping them for profit. We made a nice profit to fund our ATV hobby. Now people know enough to just throw it on Craigslist for $20-30 even if the thing is missing parts.
Dealership markup on parts doesn't help either. I had a guy bring me a fairly new chainsaw that wouldn't start. He said the dealer told him it needed a new carburetor for $200 + labor. The saw was maybe $300 new. Before buying another saw for $300 he asked if I could look at it. I looked online and the whole carburetor was $100, but the rebuild kit was $18. We chanced on the rebuild kit and it took me an hour to clean the carb and install the kit. So for $18 + an hour of labor he was good to go. I feel a lot of the dealers don't want to mess with carbs and just say they need to be replaced, which usually means to the customer it is cheaper to buy a new machine.
2000 Jeep Cherokee 4.0L (181k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (38k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Easiest Oil Change Ever! [Re: raytseng] #4532972
10/03/17 12:42 PM
10/03/17 12:42 PM
Midwest
Rab6715 Offline
Rab6715  Offline
Midwest
I bought an oil extractor that you pump up and then release the valve. It works pretty good, but for me it only seems to pull about 80% of the oil out of my lawn mower. Tilting the lawn mower on its side and letting it rest there for 5-10 minutes gets 98+% of the oil out. You can attach a funnel to the filler tube to reduce spills when tilting the mower. I like getting the most oil out as possible, so I've stopped using the extractor for mower changes. If I was changing my mower oi1 dozens of times per year, i'd probably use the extractor, but I'm only changing it once a year, so the tilt method serves me well.
